W681360RG TR
W681360RG TR
    NUVOTON(新唐)
    SSOP20_208MIL
    IC VOICEBAND CODEC 3V 1CH 20SSOP
W681360RG TR 数据手册
W681360 3V SINGLE-CHANNEL 13-BIT LINEAR VOICE-BAND CODEC Data Sheet Revision A.5 -1- W681360 1. GENERAL DESCRIPTION The W681360 is a general-purpose single channel 13–bit linear PCM CODEC with 2s complement data format. It operates from a single +3V power supply and is available in 20-pin SOG(SOP), SSOP and TSSOP package options. The primary function of the device is the digitization and reconstruction of voice signals, including the band limiting and smoothing required for PCM systems. The W681360 performance is specified over the industrial temperature range of –40C to +85C. The W681360 includes an on-chip precision voltage reference. The analog section is fully differential, reducing noise and improving the power supply rejection ratio. The V AG reference pin allows for decoupling of the internal circuitry that generates the reference voltage to the V SS power supply ground, minimizing clock noise on the analog circuitry when external analog signals are referenced to V SS. The data transfer protocol supports both long-frame and short-frame, synchronous and asynchronous communications for PCM applications. The W681360 accepts eight master clock rates between 256kHz and 4.800MHz, and an on-chip pre-scaler automatically determines the division ratio for the required internal clock. An additional on-chip power amplifier is capable of driving 300 loads differentially up to a level of 3.544V peak-to-peak. For fast evaluation a development kit (W681360DK) is available. For fast prototyping purposes a low-cost evaluation board (W681360ES) is also available. 2. FEATURES             Single +3V power supply (2.7V to 5.25V) Typical power dissipation: 9.8mW Standby power dissipation: 3µW Power-Down dissipation: 0.09µW Fully-differential analog circuit design for low noise 13-bit linear A/D & D/A conversions with 2s complement data format CODEC A/D and D/A filtering compliant with ITU G.712 Eight master clock rates of 256kHz to 4.800 MHz 256KHz – 4.8MHz bit clock rates on the serial PCM port On-chip precision reference of 0.886 V for a -5 dBm TLP at 600  (436mVRMS) Programmable receive gain: 0 to –21dB in 3dB steps Industrial temp. range (–40C to +85C) 20-pin SOG (SOP), SSOP and TSSOP as well as a QFN-32L package Pb-Free / RoHS package options available Applications  VoIP, Voice over Networks equipment  Digital telephone and communication systems  Wireless Voice devices  DECT/Digital Cordless phones  Broadband Access Equipment  Bluetooth Headsets  Fiber-to-curb equipment  Enterprise phones  Digital Voice Recorders -2- Publication Release Date: January 2011 Revision A.5 W681360 3. BLOCK DIAGRAM Transmit Receive PCM PCM Interface Interface BCLKR FSR PCMR BCLKT FST PCMT PAO+ PAOPAI G.712 CODEC ROAO AI+ AIHB Voltage reference 256 kHz 8 kHz VAGREF Power Conditioning PUI Pre-scaler VDD 256 kHz 512 kHz 1536 kHz 1544 kHz 2048 kHz 2560 kHz 4096 kHz 4800 kHz VSS MCLK VAG -3- Publication Release Date: January 2011 Revision A.5 W681360 4. TABLE OF CONTENTS 1. GENERAL DESCRIPTION .................................................................................................................. 2 2. FEATURES ......................................................................................................................................... 2 3. BLOCK DIAGRAM............................................................................................................................... 3 4. TABLE OF CONTENTS ...................................................................................................................... 4 5. PIN CONFIGURATION ....................................................................................................................... 6 6. PIN DESCRIPTION ............................................................................................................................. 7 7. FUNCTIONAL DESCRIPTION ............................................................................................................ 9 7.1. Transmit Path................................................................................................................................ 9 7.1.1 Input Operational Amplifier Gain ........................................................................................... 10 7.2. Receive Path............................................................................................................................... 11 7.2.1. Receive Gain Adjust Mode................................................................................................... 12 7.3. POWER MANAGEMENT ........................................................................................................... 12 7.3.1. Analog and Digital Supply .................................................................................................... 12 7.3.2. Analog Ground Reference Bypass ...................................................................................... 12 7.3.3. Analog Ground Reference Voltage Output .......................................................................... 12 7.4. PCM INTERFACE ...................................................................................................................... 13 7.4.1. Long frame sync ................................................................................................................... 13 7.4.2. Short frame sync .................................................................................................................. 13 7.4.3. Special 16-bit Receive Modes ............................................................................................. 14 7.4.3.1. Sign-Extended Mode Timing ............................................................................................. 14 7.4.3.2. Receive Gain Adjust Mode Timing .................................................................................... 15 7.4.4. System Timing ..................................................................................................................... 15 7.5. On-Chip Power Amplifier ............................................................................................................ 15 8. TIMING DIAGRAMS .......................................................................................................................... 16 9. ABSOLUTE MAXIMUM RATINGS .................................................................................................... 21 9.1. Absolute Maximum Ratings ........................................................................................................ 21 9.2. Operating Conditions .................................................................................................................. 21 10. ELECTRICAL CHARACTERISTICS ............................................................................................... 22 10.1. General Parameters ................................................................................................................. 22 10.2. Analog Signal Level and Gain Parameters ............................................................................... 23 10.3. Analog Distortion and Noise Parameters ................................................................................. 24 -4- Publication Release Date: January 2011 Revision A.5 W681360 10.4. Analog Input and Output Amplifier Parameters ........................................................................ 25 10.5.1. PCM Codes for Zero and Full Scale .................................................................................. 27 10.5.2. PCM Codes for 1kHz Digital Milliwatt ................................................................................ 27 11. TYPICAL APPLICATION CIRCUIT ................................................................................................. 28 12. PACKAGE DRAWING AND DIMENSIONS .................................................................................... 29 12.1. 20L SOG (SOP)-300mil ............................................................................................................ 29 12.2. 20L SSOP-209 mil .................................................................................................................... 30 12.3. 20L TSSOP - 4.4X6.5mm ......................................................................................................... 31 12.3. QFN-32L ................................................................................................................................... 32 13. ORDERING INFORMATION ........................................................................................................... 33 14. VERSION HISTORY ....................................................................................................................... 34 -5- Publication Release Date: January 2011 Revision A.5 W681360 5. PIN CONFIGURATION VREF ROPAI PAOPAO+ VDD FSR PCMR BCLKR PUI 1 20 2 19 3 18 4 17 W681360 SINGLE CHANNEL CODEC 5 6 7 8 16 15 14 13 9 12 10 11 VAG AI+ AIAO HB VSS FST PCMT BCLKT MCLK 32 31 AI+ NC NC VAG VREF NC NC SOG, SSOP,TSSOP 30 29 28 27 26 RO- 1 25 NC PAI 2 24 AI- PAO- 3 23 AO NC 4 22 HB PAO+ 5 21 NC VDD 6 20 VSS FSR 7 19 FST 18 NC PCMR 8 17 PCMT NC BCLKT 15 16 NC NC 13 14 MCLK 11 12 PUI 10 NC BCLKR 9 QFN-32L -6- Publication Release Date: January 2011 Revision A.5 W681360 6. PIN DESCRIPTION Pin Name Pin No. nonQFN Functionality QFN VREF 1 30 This pin is used to bypass the on–chip VDD/2 voltage reference for the VAG output pin. This pin should be bypassed to VSS with a 0.1F ceramic capacitor using short, low inductance traces. The VREF pin is only used for generating the reference voltage for the V AG pin. Nothing is to be connected to this pin except the bypass capacitor. RO- 2 1 Inverting output of the receive smoothing filter. This pin can typically drive a 2k load to 0.886VPEAK referenced to analog ground. PAI 3 2 Inverting input to the power amplifier. The non-inverting input is tied internally to VAG voltage. PAO- 4 3 Inverting power amplifier output. The PAO- and PAO+ can drive a 300 load differentially to 1.772VPEAK. PAO+ 5 5 Non-inverting power amplifier output. The PAO- and PAO+ can drive a 300 load differentially to 1.772VPEAK. VDD 6 6 Power supply. Should be decoupled to VSS with a 0.1F ceramic capacitor. FSR 7 7 8kHz Frame Sync input for the PCM receive section. FSR can be asynchronous to FST in either Long Frame Sync or Short Frame Sync mode. PCMR 8 8 PCM input data receive pin. The data needs to be synchronous with the FSR and BCLKR pins. BCLKR 9 9 PCM receive bit clock input pin. Can accept any bit clock frequency from 256 to 4800kHz. When not clocked it can be used to select the 16 sign-bit extended synchronous mode (BCLKR=0) or the receive gain adjust synchronous mode (BCLKR=1) PUI 10 12 Power up input signal. When this pin is tied to VDD, the part is powered up. When tied to VSS, the part is powered down. MCLK 11 13 System master clock input. Possible input frequencies are 256kHz, 512kHz, 1536kHz, 1544kHz, 2048kHz, 2560kHz, 4096kHz & 4800kHz. For performance reasons, it is recommended that MCLK be synchronous and aligned to the FST signal. This is a requirement in the case of 256 and 512kHz frequencies. BCLKT 12 16 PCM transmit bit clock input pin. Can accept any bit clock frequency from 256 to 4800kHz. PCMT 13 17 PCM output data transmit pin. The output data is synchronous with the FST and BCLKT pins. FST 14 19 8kHz transmit frame sync input. This pin synchronizes the transmit data bytes. VSS 15 20 This is the supply ground. This pin should be connected to 0V. -7- Publication Release Date: January 2011 Revision A.5 W681360 Pin Name Pin No. Functionality nonQFN QFN HB 16 22 High-pass Bypass. Determines if the transmit high-pass filter is used (HB=’0’) or bypassed (HB=’1’). When the high pass is bypassed the frequency response extends to DC. AO 17 23 Analog output of the first gain stage in the transmit path. AI- 18 24 Inverting input of the first gain stage in the transmit path. AI+ 19 26 Non-inverting input of the first gain stage in the transmit path. VAG 20 29 Mid-Supply analog ground pin, which supplies a VDD/2 volt reference voltage for all-analog signal processing. This pin should be decoupled to VSS with a 0.01F capacitor. This pin becomes high impedance when the chip is powered down. -8- Publication Release Date: January 2011 Revision A.5 W681360 7. FUNCTIONAL DESCRIPTION W681360 is a single-rail, single channel PCM CODEC for voiceband applications. The CODEC complies with the specifications of the ITU-T G.712 recommendation. The CODEC block diagram in Section 3 illustrates the main components of the W681360. The chip consists of a PCM interface, which can process long and short frame sync formats. The pre-scaler of the chip provides the internal clock signals and synchronizes the CODEC sample rate with the external frame sync frequency. The power conditioning block provides the internal power supply for the digital and the analog section, while the voltage reference block provides a precision analog ground voltage for the analog signal processing. The calibration level for both the Analog to Digital Converter (ADC) and the Digital to Analog Converter (DAC) is referenced to μ-Law with the same bit voltage weighing about the zero crossing, resulting in the 0dBm0 calibration level 3.2dB below the peak sinusoidal level before clipping, Based on the reference voltage of 0.886V the calibration level is 0.436 Vrms or –5dBm at 600Ω. VAG + - PAO+ - + PAOPAI 13 DATA Receive 13 bit linear DAC fC = 3400 Hz Smoothing Filter a Buffer1 Av=1 Smoothing Filter b High Pass Bypass 13 DATA Transmit 13 bit linear ADC fC = 200 Hz High Pass Filter RO- AO fC = 3400 Hz Anti-Aliasing Filter a - AI- + AI+ Anti-Aliasing Filter b FIGURE 7.1: THE W681360 SIGNAL PATH 7.1. Transmit Path The first stage of the A-to-D path of the CODEC is an analog input operational amplifier with externally configurable gain settings. A differential analog input may be applied to the Inputs AI+ and AI-. Alternately the input amplifier may be powered down and a single-ended input signal can be applied to either the AO pin or the AI- pin. The input amplifier can be powered down by connecting the AI+ pin to -9- Publication Release Date: January 2011 Revision A.5 W681360 either VDD or VSS which also determines whether AO or AI+ is selected as input according to Table 7.1. When the input operational amplifier is powered down the AO pin becomes high input impedance. TABLE 7.1: INPUT AMPLIFIER MODES OF OPERATION AI+ (Pin 19) VDD 1.2 to VDD-1.2 VSS Input Amplifier Input Powered Down Powered Up Powered Down AO (Pin 17) AI+, AI- (Pins 19, 18) AI- (Pin 18) When the input amplifier is powered down, the input signal at AO or AI- should be referenced to the analog ground voltage VAG. The output of the input operational amplifier is first fed through a low-pass filter to prevent aliasing at the switched capacitor 3.4kHz low pass filter. Subsequently the 3.4kHz switched capacitor low pass filter bandlimits the input signals well below 4kHz. Signals above 4kHz would be aliased at the sampling rate of 8kHz. A high pass filter with a 200Hz cut-off frequency prevents DC coupling. All filters are designed according to the G.712 ITU-T specification. The high-pass filter may be bypassed depending on the logic level on the HB pin. If the high pass is removed the frequency response of the device extends down to DC. After filtering the signal is digitized as a 13-bit linear PCM code and fed to the PCM interface for serial transmission at the sample rate supplied by the external frame sync FST. 7.1.1 Input Operational Amplifier Gain The gain of the input operational amplifier can be adjusted using external resistors. For single-ended input operation the gain is given by a simple resistive ratio. Ro AO A I- Ri V in - VAG + A I+ Gin = Ro/Ri FIGURE 7.2: INPUT OPERATIONAL AMPLIFIER GAIN – SINGLE-ENDED INPUT For differential input operation the external resistor network is more complex but the gain is expressed in the same way. Of course, a differential input also has an inherent 6dB advantage over a corresponding single-ended input. - 10 - Publication Release Date: January 2011 Revision A.5 W681360 Ro AO A I- Ri V in - + V in + A I+ Gin = Ro/Ri Ri Ro VAG FIGURE 7.3: INPUT OPERATIONAL AMPLIFIER GAIN – DIFFERENTIAL INPUT The gain of the operational amplifier will be typically be set to 30dB for microphone interface circuits. However the gain may be used for more than 30dB but this will require a compact layout with minimal trace lengths and good isolation from noise sources. It is also recommended that the layout be as symmetrical as possible as imbalances work against the noise canceling advantages of the differential design. 7.2. Receive Path The 13-bit digital input samples for the D-to-A path are serially shifted in by the PCM interface and converted to parallel data bits. During every cycle of the frame sync FSR, the parallel data bits are fed through the 13-bit linear DAC and converted to analog samples. The analog samples are filtered by a low-pass smoothing filter with a 3.4kHz cut-off frequency, according to the ITU-T G.712 specification. A sin(x)/x compensation is integrated with the low pass smoothing filter. The output of this filter is buffered to provide the receive output signal RO-. The output may be also be attenuated when the device is in the receive path adjust mode. If the device is operated half–channel with the FST pin clocking and FSR pin held LOW, the receive filter input will be connected to the VAG voltage. This minimizes transients at the RO– pin when full–channel operation is resumed by clocking the FSR pin. The RO- output can be externally connected to the PAI pin to provide a differential output with high driving capability at the PAO+ and PAO- pins. By using external resistors various gain settings of this output amplifier can be achieved. If the transmit power amplifier is not in use, it can be powered down by connecting PAI to VDD. The bias voltage and signal reference of the PAO+ & PAO– outputs is the VAG pin. The VAG pin cannot source or sink as much current as these pins, and therefore low impedance loads must be placed between PAO+ and PAO–. The PAO+ and PAO– differential drivers are also capable of driving a 100Ω resistive load or a 100nF piezoelectric transducer in series with a 20Ω resister with a small increase in distortion. These drivers may be used to drive resistive loads of 32Ω when the gain of PAO– is set to 1/4 or less. - 11 - Publication Release Date: January 2011 Revision A.5 W681360 7.2.1. Receive Gain Adjust Mode The W681360 can be put in the receive path adjust mode by applying a logic “1” to the BCLKR pin while all other clocks are clocked normally. The device is then in a position to read 16-bits of data, with three additional coefficient bits an addend to the 13-bit digital voice data. These three coefficients are used to program a receive path attenuation, thereby allowing the receive signal to be attenuated according to the values in the following table. If the feature is not used the default value is 0dB. Coefficient Attenuation (dB) 000 0 001 3 010 6 011 9 100 12 101 15 110 18 111 21 TABLE 7.2: ATTENUATION COEFFICIENT RELATIONSHIP IN RECEIVE GAIN ADJUST MODE 7.3. POWER MANAGEMENT 7.3.1. Analog and Digital Supply The power supply for the analog and digital parts of the W681360 must be 2.7V to 5.25V. This supply voltage is connected to the VDD pin. The VDD pin needs to be decoupled to ground through a 0.1 F ceramic capacitor. 7.3.2. Analog Ground Reference Bypass The system has an internal precision voltage reference which generates the V DD/2 mid-supply analog ground voltage. This voltage needs to be decoupled to V SS at the VREF pin through a 0.1 F ceramic capacitor. 7.3.3. Analog Ground Reference Voltage Output The analog ground reference voltage is available for external reference at the V AG pin. This voltage needs to be decoupled to VSS through a 0.01 F ceramic capacitor. The analog ground reference voltage is generated from the voltage on the V REF pin and is also used for the internal signal processing. - 12 - Publication Release Date: January 2011 Revision A.5 W681360 7.4. PCM INTERFACE The PCM interface is controlled by pins BCLKR, FSR, BCLKT & FST. The input data is received through the PCMR pin and the output data is transmitted through the PCMT pin. The Long Frame Sync or Short Frame Sync interface mode can be selected by connecting the BCLKR or BCLKT pin to a 256kHz to 4.800 MHz clock and connecting the FSR or FST pin to the 8kHz frame sync. The device synchronizes the data word for the PCM interface and the CODEC sample rate on the positive edge of the Frame Sync signal. Long Frame Sync is recognized when the FST pin is held HIGH for two consecutive falling edges of the bit-clock at the BCLKT pin. Short Frame Sync Mode is recognized when the Frame Sync signal at pin FST is HIGH for one and only one falling edge of the bit-clock at the BCLKT pin. 7.4.1. Long frame sync The device recognizes a Long Frame Sync when the FST pin is held HIGH for two consecutive falling edges of the bit-clock at the BCLKT pin. The length of the Frame Sync pulse can vary from frame to frame, as long as the positive frame sync edge occurs every 125 sec. During data transmission in the Long Frame Sync mode, the transmit data pin PCMT will become low impedance when the Frame Sync signal FST is HIGH or when the 13-bit data word is being transmitted. The transmit data pin PCMT will become high impedance when the Frame Sync signal FST becomes LOW while the data is transmitted or when half of the LSB is transmitted. The internal decision logic will determine whether the next frame sync is a long or a short frame sync, based on the previous frame sync pulse. To avoid bus collisions, the PCMT pin will be high impedance for two frame sync cycles after every power down state. Long Frame Sync mode is illustrated below. More detailed timing information can be found in the interface timing section. BCLKT (BCLKR) FST (FSR) PCMT 1 2 3 4 5 6 7 8 9 10 11 12 13 PCMR don't care 1 2 3 4 5 6 7 8 9 10 11 12 13 don't care Long Frame Sync (Transmit and Receive Have Individual Clocking) FIGURE 7.4: LONG FRAME SYNC PCM MODE 7.4.2. Short frame sync The W681360 operates in the Short Frame Sync Mode when the Frame Sync signal at pin FST is HIGH for one and only one falling edge of the bit-clock at the BCLKT pin. On the following rising edge of the bit-clock, the W681360 starts clocking out the data on the PCMT pin, which will also change from high to low impedance state. The data transmit pin PCMT will go back to the high impedance state halfway through the LSB. The Short Frame Sync operation of the W681360 is based on a 13-bit data word. When receiving data on the PCMR pin, the data is clocked in on the first falling edge after - 13 - Publication Release Date: January 2011 Revision A.5 W681360 the falling edge that coincides with the Frame Sync signal. The internal decision logic will determine whether the next frame sync is a long or a short frame sync, based on the previous frame sync pulse. To avoid bus collisions, the PCMT pin will be high impedance for two frame sync cycles after every power down state. Short Frame Sync mode is illustrated below. More detailed timing information can be found in the interface timing section. BCLKT (BCLKR) FST (FSR) PCMT 1 2 3 4 5 6 7 8 9 10 11 12 13 PCMR don't care 1 2 3 4 5 6 7 8 9 10 11 12 13 don't care Short Frame Sync (Transmit and Receive Have Individual Clocking) FIGURE 7.5: SHORT FRAME SYNC PCM MODE 7.4.3. Special 16-bit Receive Modes 7.4.3.1. Sign-Extended Mode Timing The Sign-bit extended mode is entered by applying a logic “0” to the BCLKR pin while all other clocks are clocked normally. In standard 13-bit mode the first bit is the sign bit. In this mode the device transmits and receives 16-bit data where the sign bit is extended to the first four data bits. The PCM timing for this mode is illustrated below. BCLKT (BCLKR) FST (FSR) SHORT OR LONG FRAME SYNC PCMT 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 PCMR don't care 1 2 3 4 5 6 7 8 9 10 11 12 14 15 13 16 don't care don't care Sign-Extended (BCLKR=0) Transmit and Receive both use BCLKT, and the first four data bits are the sign bit. FST may occur at a different time than FSR FIGURE 7.6: SIGN EXTENDED MODE - 14 - Publication Release Date: January 2011 Revision A.5 W681360 7.4.3.2. Receive Gain Adjust Mode Timing The Receive Path Adjust Mode is entered by applying a logic “1” to the BCLKR pin while all other clocks are clocked normally. In this mode the device receives 16-bit data where the last three bits are coefficients to program the Receive Gain Adjust Attenuation described above. The PCM timing for this mode is illustrated below. BCLKT (BCLKR) F S T (F S R ) SHORT OR L O N G F R AM E SYNC PCM T 1 2 3 4 5 6 7 8 9 10 11 12 13 PCM R don't care 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 don't care don't care Receive Gain Adjust (BCLKR=1) Transm it and Receive both use BCLKT. FST m ay occur at a different tim e than FSR. Bits 14, 15, and 16, clocked into PCM R, are used for attenuation control for the receive analog output. FIGURE 7.7: RECEIVE GAIN ADJUST TIMING MODE 7.4.4. System Timing The system can work at 256kHz, 512kHz, 1536kHz, 1544kHz, 2048kHz, 2560kHz, 4096kHz & 4800kHz master clock rates. The system clock is supplied through the master clock input MCLK and can be derived from the bit-clock if desired. An internal pre-scaler is used to generate a fixed 256kHz and 8kHz sample clock for the internal CODEC. The pre-scaler measures the master clock frequency versus the Frame Sync frequency and sets the division ratio accordingly. If both Frame Syncs are LOW for the entire frame sync period while the MCLK and BCLK pin clock signals are still present, the W681360 will enter the low power standby mode. Another way to power down is to set the PUI pin to LOW. When the system needs to be powered up again, the PUI pin needs to be set to HIGH and the transmit Frame Sync pulse needs to be present. It will take two transmit Frame Sync cycles before the pin PCMT becomes low impedance. 7.5. ON-CHIP POWER AMPLIFIER The on-chip power amplifier is typically used to drive an external loudspeaker. The inverting input to the power amplifier is available at pin PAI. The non-inverting input is tied internally to VAG. The inverting output PAO– is used to provide a feedback signal to the PAI pin to set the gain of the power amplifier outputs (PAO+ and PAO-). These push–pull outputs are capable of driving a 300Ω load to 1.772 VPEAK. Connecting PAI to VDD will power down the power driver amplifiers and the PAO+ and PAO– outputs will be high impedance. - 15 - Publication Release Date: January 2011 Revision A.5 W681360 8. TIMING DIAGRAMS TFTRHM TMCK TFTRSM TRISE TFALL MCLK TMCKH TMCKL TBCK BCLKT TFTRS TFTRH TBCKH TFTFH TBCKL TFS TFSL FST TFDTD TFDTD TBDTD THID THID PCMT MSB BCLKR (BCLKT) TFRRS TFRRH LSB TBCK TBCKH TFRFH TBCKL FSR TDRS PCMR MSB TDRH LSB FIGURE 8.1: LONG FRAME SYNC PCM TIMING NOTE: The Data is clocked out on the rising edge of BCLK. The Data is clocked in on the falling edge of BCLK. - 16 - Publication Release Date: January 2011 Revision A.5 W681360 TABLE 8.1: LONG FRAME SYNC PCM TIMING PARAMETERS SYMBOL 1/TFS FST, FSR Frequency TFSL FST / FSR Minimum LOW Width 1/TBCK BCLKT, BCLKR Frequency TBCKH 1 MIN TYP MAX UNIT --- 8 --- kHz TBCK 1 sec 256 --- 4800 kHz BCLKT, BCLKR HIGH Pulse Width 50 --- --- ns TBCKL BCLKT, BCLKR LOW Pulse Width 50 --- --- ns TFTRH BCLKT Falling Edge to FST Rising Edge Hold Time 20 --- --- ns TFTRS FST Rising Edge to BCLKT Falling edge Setup Time 80 --- --- ns TFTFH BCLKT Falling Edge to FST Falling Edge Hold Time 50 --- --- ns --- --- 60 ns --- --- 60 ns 10 --- 60 ns 20 --- --- ns TFRRH The later of BCLKT rising edge, or FST rising edge to first valid PCMT Bit Delay Time BCLKT Rising Edge to Valid PCMT Delay Time Delay Time from the Later of FST Falling Edge, or BCLKT Falling Edge of last PCMT Bit to PCMT Output High Impedance BCLKR Falling Edge to FSR Rising Edge Hold Time TFRRS FSR Rising Edge to BCLKR Falling edge Setup Time 80 --- --- ns TFRFH BCLKR Falling Edge to FSR Falling Edge Hold Time 50 --- --- ns TDRS Valid PCMR to BCLKR Falling Edge Setup Time 1 --- --- ns TDRH PCMR Hold Time from BCLKR Falling Edge 50 --- --- ns TFDTD TBDTD THID 1 DESCRIPTION TFSL must be at least  TBCK - 17 - Publication Release Date: January 2011 Revision A.5 W681360 TFTRHM TMCK TFTRSM TRISE TFALL MCLK TMCKH BCLKT TFTRS TFTRH TMCKL TBCK TBCKH TFTFS TBCKL TFS TFTFH FST TBDTD TBDTD THID PCMT MSB BCLKR (BCLKT) TFRRS TFRRH LSB TBCK TBCKH TFRFS TBCKL TFRFH FSR TDRS PCMR MSB TDRH LSB FIGURE 8.2: SHORT FRAME SYNC PCM TIMING - 18 - Publication Release Date: January 2011 Revision A.5 W681360 SYMBOL DESCRIPTION MIN TYP MAX UNIT --- 8 --- kHz 1/TFS FST, FSR Frequency 1/TBCK BCLKT, BCLKR Frequency 256 --- 4800 kHz TBCKH BCLKT, BCLKR HIGH Pulse Width 50 --- --- ns TBCKL BCLKT, BCLKR LOW Pulse Width 50 --- --- ns TFTRH BCLKT Falling Edge to FST Rising Edge Hold Time 20 --- --- ns TFTRS FST Rising Edge to BCLKT Falling edge Setup Time 80 --- --- ns TFTFH BCLKT Falling Edge to FST Falling Edge Hold Time 50 --- --- ns TFTFS FST Falling Edge to BCLKT Falling Edge Setup Time 50 --- --- ns TBDTD BCLKT Rising Edge to Valid PCMT Delay Time 10 --- 60 ns THID Delay Time from BCLKT Falling Edge at last PCMT bit (LSB) to PCMT Output High Impedance 10 --- 60 ns TFRRH BCLKR Falling Edge to FSR Rising Edge Hold Time 20 --- --- ns TFRRS FSR Rising Edge to BCLKR Falling edge Setup Time 80 --- --- ns TFRFH BCLKR Falling Edge to FSR Falling Edge Hold Time 50 --- --- ns TFRFS FSR Falling Edge to BCLKR Falling Edge Setup Time 50 --- --- ns TDRS Valid PCMR to BCLKR Falling Edge Setup Time 1 --- --- ns TDRH PCMR Hold Time from BCLKR Falling Edge 50 --- --- ns TABLE 8.2: SHORT FRAME SYNC PCM TIMING PARAMETERS - 19 - Publication Release Date: January 2011 Revision A.5 W681360 SYMBOL DESCRIPTION MIN TYP MAX UNIT --- 256 512 1536 1544 2048 2560 4096 4800 --- kHz 1/TMCK Master Clock Frequency TMCKH / TMCK MCLK Duty Cycle for 256kHz Operation TMCKH Minimum Pulse Width HIGH for MCLK(512kHz or Higher) 50 --- --- ns TMCKL Minimum Pulse Width LOW for MCLK (512kHz or Higher) 50 --- --- ns TFTRHM MCLK falling Edge to FST Rising Edge Hold Time 50 --- --- ns TFTRSM FST Rising Edge to MCLK Falling edge Setup Time 50 --- --- ns TRISE Rise Time for All Digital Signals --- --- 50 ns TFALL Fall Time for All Digital Signals --- --- 50 ns 45% 55% Table 8.3: General PCM Timing Parameters - 20 - Publication Release Date: January 2011 Revision A.5 W681360 9. ABSOLUTE MAXIMUM RATINGS 9.1. ABSOLUTE MAXIMUM RATINGS Condition Value 0 Junction temperature 150 C Storage temperature range -65 C to +150 C Voltage applied to any pin (VSS - 0.3V) to (VDD + 0.3V) Voltage applied to any pin (Input current limited to +/-20 mA) (VSS – 1.0V) to (VDD + 1.0V) VDD - VSS -0.5V to +6V 0 0 1. Stresses above those listed may cause permanent damage to the device. Exposure to the absolute maximum ratings may affect device reliability. Functional operation is not implied at these conditions. 9.2. OPERATING CONDITIONS Condition Value 0 0 Industrial operating temperature -40 C to +85 C Supply voltage (VDD) +2.7V to +5.25V Ground voltage (VSS) 0V Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. - 21 - Publication Release Date: January 2011 Revision A.5 W681360 10. ELECTRICAL CHARACTERISTICS 10.1. GENERAL PARAMETERS VDD=2.7V – 3.6V; VSS=0V; TA=-40C to +85C; Symbol Parameters Conditions Min VIL Input LOW Voltage VIH Input HIGH Voltage VOL PCMT Output LOW Voltage IOL = 1.6 mA VOH PCMT Output HIGH Voltage IOL = -1.6 mA IDD VDD Current (Operating) - ADC + DAC No Load ISB VDD Current (Standby) FST&FSR =Vss ; PUI=VDD IPD VDD Current (Power Down) PUI= Vss IIL Input Leakage Current VSS
W681360RG TR 价格&库存
很抱歉,暂时无法提供与“W681360RG TR”相匹配的价格&库存,您可以联系我们找货
