PRO TOOLKIT - ULTIMATE DATAREADY
Ultimate DataReady® Pro Kit
Cat No:
PA4934
UPC No:
769328113174
Description
If you're an installer or technician needing a data cable tool kit solution, this is it. It includes all the tools
you need for Cat5, Cat5e and Cat6 installation or maintenance in our rugged Ultimate Tool Bag
Specifications
Includes : PA1116 Data SureStrip UTP/STPAnd Flat Satin Cutter/Stripper, PA1923 Untwist Tool,
PA8000 CrimpALL Crimp Frame With EZI-CHANGE Thumb Screws, PA3589 SurePunch Pro
Punchdown Tool, DetachableLED Light, PA4571 110/ 66 Blade, PA4591 Doubl
Replacement Part : PA1116 Data SureStrip UTP/STPAnd Flat Satin Cutter/Stripper, PA1923
Untwist Tool, PA8000CrimpALL Crimp Frame With EZI-CHANGE Thumb Screws, PA3589
SurePunch Pro Punchdown Tool, PA4599 SurePunch Pro DetachableLED Light, PA4571 110/ 66
Blade, PA4591 Doubl
Size : 11.000 IN (279.000 MM) Width X 8.500 IN (216.000 MM) LengthX 6.000 IN (152.000 MM)
Depth
Sub Brand : DataReady
Type : Ultimate, Pro
Weight : 5.150 LB (2.300 KG)
很抱歉,暂时无法提供与“PA4934”相匹配的价格&库存,您可以联系我们找货
