SBH51-LPSE-D50-SM-BK 数据手册
8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2364
INITIAL RELEASE
06/08/2011
LH
F
F
C
E
E
2.70 .106
1.00 .039
4.30 .169
B
D
D
2.00 .079
3.40 .134
3.60 .142
0.10[.004]
0.95 .037
2X
0.64±0.10 .025±.004
OPTIONAL
SEE P/N CODING
6.16 .243
D
2X
0.80±0.05 .031±.002
A
C
A
0.56±0.05 .022±.002
C
1.00 .039
1.00 .039
0.30 .012
2.40 .094
7.00 .276
OPTIONAL
SEE P/N CODING
0.80 .031
D
B
A
NOTES:
1. INSULATOR MATERIAL: LCP, UL 94V-0, BLACK.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 1 AMP PER CONTACT.
5. INSULATOR RESISTANCE: 1000 MEGA OHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: 300V AC.
8. OPERATING TEMPERATURE: -40° C TO +125° C.
9. *PROCESSING TEMP.: 230° C FOR 60 SECS MAX.
(260° C FOR 10 SECS MAX.)
10. MATES WITH SFM210 SERIES.
RECOMMENDED PCB LAYOUT
DRAWN
7
6
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN MM[INCHES]
Pb
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT
INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED,
PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR
DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
8
B
TOLERANCES: ANGULAR:
.X= .3 [.01]
.XX= .20 [.008]
.XXX= .100 [.0040]
RoHS COMPLIANT
5
4
INTERPRET DIMENSIONS
AND TOLERANCING
PER: ASME Y14.5M-2009
DATE
NAME
06/08/2011
LH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
3
BOX HEADER, 1.00mm[.039"] CC/RS, SMT
SBH51-LP_E-D_ _-S_-BK
CAGE CODE
54453
DWG. NO.
11775
SCALE: 5:1
SHEET 1 OF 1
2
1
REV
A
FILE NAME: Z:\ECO PENDING\2364, SBH51 BOX HEADER\11775, SBH51-LP_E-D_ _-S_-BK PRINT: 6/10/2011
A
SBH51-LPSE-D50-SM-BK 价格&库存
很抱歉,暂时无法提供与“SBH51-LPSE-D50-SM-BK”相匹配的价格&库存,您可以联系我们找货
