KTPS65-2427DT-3P-VI-HP-C-P1
    KAGA
    AC/DC DESKTOP ADAPTER 24V 65W
KTPS65-2427DT-3P-VI-HP-C-P1 数据手册
KTPS65 Series CEC/DoE Level VI 65 Watt Universal Input, Desktop Adapter INPUT SPECIFICATIONS All specifications are typical at nominal input, full load. INPUT SPECIFICATIONS Input Voltage AC 100 – 240VAC Input Frequency 50 – 60Hz Input Current 65W: 1.4A Max / 72W: 1.6A Max Protection Internal Primary Current Fuse, Inrush Limiting OUTPUT SPECIFICATIONS Output Voltage See Chart Efficiency DoE Level VI, Energy Star, ErP Stage 2, NRCan & GEMS Level VI Certified Protection Short Circuit Protection Over Current Protection Over Voltage Protection Ripple 1 - 2 % Vp-p (max) Hold-Up Time 10 mS (min) Transient Response 0.5mS for 50% Load Change(typ) Load Regulation ± 5% (typ) Leakage Current 0.25mA @ 2 pin / 3.5mA @ 3 pin GENERAL SPECIFICATIONS FEATURES       CEC/DoE LEVEL VI UNIVERSAL INPUT (AC100-240V) OVER VOLTAGE PROTECTION OVER CURRENT PROTECTION SHORT CIRCUIT PROTECTION ROHS COMPLIANT ENVIRONMENTAL SPECIFICATIONS Operating Temperature 0°C ~ +40°C Storage Temperature -20°C ~ +80°C Cooling Convection Operating Humidity 20 – 80% Rh Storage Humidity 10 – 90% Rh MTBF(Calculated) 300,000 Calculated Hours at 25°C, by Telcordia SR-332 MECHANICAL SPECIFICATIONS Dielectric Withstanding Voltage 3,000 VAC Primary – Secondary Case Dimension L115 x W53 x H38(mm) Input Configuration EMI Conduction & Radiation Compliance to EN55022 Class B IEC320-C14 (Optional C6) DC Cord Harmonic Current Compliance to EN61000-3-2,3 18AWG (Optional 16 AWG & 20AWG) EMS Immunity Compliance to EN61000-42,3,4,5,6,8,11 Output Connector See Chart Safety Approvals UL/cUL/CE/CB/GS/PSE/FCC Weight 310g (Ref) Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com KTPS65 Series CEC/DoE Level VI Model Number Output Voltage Output Current Max Output Power KTPS65-1250DT-3P-VI 12.0V 5.00A 60W KTPS65-13548DT-3P-VI 13.5V 4.82A 65W KTPS65-1543DT-3P-VI 15.0V 4.30A 65W KTPS65-1640DT-3P-VI 16.0V 4.00A 64W KTPS65-1836DT-3P-VI 18.0V 3.60A 65W KTPS65-1934DT-3P-VI 19.0V 3.40A 65W KTPS65-2032DT-3P-VI 20.0V 3.25A 65W KTPS65-2430DT-3P-VI 24.0V 3.00A 72W KTPS65-2427DT-3P-VI 24.0V 2.71A 65W KTPS65-2427DT-3P-VI* 24.0V 2.71A 65W KTPS65-3021DT-3P-VI 30.0V 2.17A 65W KTPS65-3220DT-3P-VI 32.0V 2.04A 65W KTPS65-3220DT-3P-VI** 32.0V 2.04A 65W KTS65-4813DT-3P-VI 48.0V 1.36A 65W KTPS65-5611DT-3P-VI 56.0V 1.17A * = 11A Peak Current ** = 3.9A Peak Currennt 65W Part Number Key: Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com KTPS65 Series CEC/DoE Level VI Mechanical Drawing: Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com
KTPS65-2427DT-3P-VI-HP-C-P1 价格&库存
很抱歉,暂时无法提供与“KTPS65-2427DT-3P-VI-HP-C-P1”相匹配的价格&库存,您可以联系我们找货
