GWLGX-S1888-GR/GR
GWLGX-S1888-GR/GR
    KYCON
    GANGJACK RT
GWLGX-S1888-GR/GR 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GWLGX-S1288-G/G Part Number Builder LR78160 MODULAR JACKS AND PLUGS: GWLGX Series GWLGX S1 2 88 G/G Series Shield Option No. of Ports No. of Positions & Contacts LED Color Option Right Angle Ganged Jack with LED Product Features Easy Viewing LEDs to Act as Power/Transmit Indicators Snap-In Retention Tabs Available Fully Shielded for EMI/RFI Protection CSA/NRTL Certified File No. LR78160 Performance Specifications Materials and Finish Housing Material Thermoplastic, UL 94V-0 Rated, Black Color Shield Material Copper Alloy, Nickel Plated Contact Material Phosphor Bronze Electrical Characteristics Insulation Resistance 500 Megohms Min. Contact Resistance 20 milliohms Max. Current Rating 1.5A Voltage Rating 125V DC Operating Temperature -40°C to +85°C Durability Rating 500 Mating Cycles Min. Series GWLGX - Ganged Modular Jack with LED, Tab Up Shield Option S1 - Fully Shielded with Top and Side Grounding Tabs Number of Ports 2 - 2 Port 4 - 4 Port 8 - 8 Port Number of Positions/Contacts 88 - 8 Positions / 8 Contacts LED Color G/G - Left: Green, Right: Green Y/G - Left: Yellow, Right: Green G/Y - Left: Green, Right: Yellow G/R - Left: Green, Right: Red R/G - Left: Red, Right: Green Contact Kycon for Other Options GWLGX Series Dimensions in mm GWLGX-S1288x-x Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
GWLGX-S1888-GR/GR 价格&库存
很抱歉,暂时无法提供与“GWLGX-S1888-GR/GR”相匹配的价格&库存,您可以联系我们找货
