1000 Eaton Boulevard
Cleveland, OH 44122
United States
2-Port IEEE-1284 Parallel Printer Auto Sharing
Switch
Highlights
Automatic, hands-free switching
No external power source
required
Reversible design allows
multiple computers to share 1
printer or 1 computer to use
multiple printers
MODEL NUMBER: B170-002-R
System Requirements
Share two PC's with one Parallel Printer, or one PC with two Parallel Printers
Computer with a parallel port
Parallel printer (either IEEE or
non-IEEE)
CD drive in the computer to load
the driver
One straight through IEEE
switch cable per computer
(model # P710-010)
One parallel IEEE printer cable
per printer (P606-006 or P606010)
Package Includes
B170-002-R Reversible 2
Position IEEE Autoswitch
This versatile 2-position autoswitch is compatible with any printer, including a high speed IEEE1284
CD with Drivers
printer. The automatic switch function can be used to share a printer between 2 PCs and will automatically
Manual
Description
manage print jobs in a transparent manner. The B170-002-R can also be used to connect a PC to 2
printers. The target printer is selected via included software or manually. This compact unit does not
require AC power, allowing it to be located virtually anywhere. You can connect the switch to your PC
using an IEEE Switchbox cable (P710-010).
Features
IEEE1284 Approved.
Designed for use with all printers including IEEE high speed printers.
Reversible: Connect 1 PC to 2 Printers or 2 PCs to 1 Printer.
No AC required.
Has both Automatic and Manual mode.
Status LEDs quickly identify the mode as well as the port in use.
Compact design enable switch to be located almost anywhere.
Specifications
OVERVIEW
UPC Code
037332014290
Host Connector
USB A (MALE)
1/2
Cleveland, OH 44122
United States
PHYSICAL
Color
Black
Shipping Dimensions (hwd / in.)
1.70 x 5.10 x 4.90
Shipping Dimensions (hwd / cm)
4.32 x 12.95 x 12.45
Shipping Weight (lbs.)
0.50
Shipping Weight (kg)
0.23
CONNECTIONS
Number of Ports
2
Side A - Connector 1
DB25 (FEMALE)
Side B - Connector 1
(2) DB25 (FEMALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“B170-002-R”相匹配的价格&库存,您可以联系我们找货
