A
Datasheet
BT85x Series Development Kits
Applicable to the following Laird part numbers:
DVK-BT850-SA
DVK-BT850-ST
Version 1.0
BT85x Series
Datasheet
REVISION HISTORY
Version
Date
1.0
12 Jan 2018
Notes
Contributor
Jacky Kuo
Raj Khatri
Initial Release
Embedded Wireless Solutions Support
Center: http://ews-support.lairdtech.com
www.lairdtech.com/bluetooth
2
© Copyright 2018 Laird. All Rights Reserved
Approver
Jonathan Kaye
Americas: +1-800-492-2320
Europe: +44-1628-858-940
Hong Kong: +852 2923 0610
BT85x Series
Datasheet
CONTENTS
1
Overview.............................................................................................................................................................4
2
Introduction ........................................................................................................................................................4
2.1.
Package Contents .......................................................................................................................................4
2.2.
DVK-BT850 – Main Development Board ....................................................................................................4
3
Getting to Know the Development Board ..........................................................................................................4
4
Power Supply ......................................................................................................................................................4
5
Interface Specification ........................................................................................................................................5
6
5.1.
GPIOs (PIN HEADER – J2) ............................................................................................................................5
5.2.
PCM/I2S Interface (Pin Header – J1) ...........................................................................................................6
5.3.
DC Power Supply ........................................................................................................................................6
5.4.
Push Button ................................................................................................................................................7
Other Features....................................................................................................................................................7
6.1.
Current Consumption Measurement .........................................................................................................7
7
Additional Documentation .................................................................................................................................8
8
Additional Assistance....................................................................................................................................... 10
3
BT85x Series
Datasheet
1 OVERVIEW
Laird’s BT850 development kit (DVK-BT850-Sx) provides a platform for rapid prototyping of BT850-Sx series modules.
The development board provides simple, easy-to-use access to the various hardware interfaces and configuration
options for the module. The DVK is the perfect platform to provide for early development testing of the BT850-Sx
series features and functionality, prior to designing the module onto a host PCB.
This datasheet is for the development board PCB which is DVK-BT850 1.0 on PCB.
2 INTRODUCTION
The Laird DVK-BT850-Sx is designed to support the rapid development of applications and evaluation for the
specific Laird Bluetooth module part number BT850-SA or -ST. In-depth documentation for this product is
available from the BT850 series product pages: http://www.lairdtech.com/Products/BT850
Package Contents
Each DVK-BT850-Sx includes the following items:
Development motherboard
USB cable – USB A type male
to Micro-USB type
Stand-off
Insert card
External antenna
The motherboard has the BT850-Sx module already soldered onto it and all
available hardware interfaces are exposed.
The USB cable can be used to power, control, and configure the BT850-Sx.
Screw nuts x 4 pcs; Stand-off x 4 pcs
Provides links to additional information including BT850-Sx datasheet, utilities,
schematics, and application notes.
Only supplied with DVK-BT850-ST.
Antenna supplied is Laird part # 0600-00040.
DVK-BT850-Sx – Main Development Board
The development board allows the Laird Bluetooth module to be connected to a PC. The development board
provides USB interface linking to PCB and the BT850-Sx host interface. Any Windows PC (Windows 7. or later)
auto-installs the generic Microsoft Bluetooth driver. Getting
Figure 1: Main DVK-BT850-Sx Board
3 POWER SUPPLY
Table 1: Input voltage
Minimum
Typical
Maximum
4.5V
5V
5.5V
Input Voltage
Power supply options for powering development board:
USB
External DC supply
The DVK-BT850-Sx includes a USB cable to provide power to the development board. This should be plugged
into a PC USB port, a USB hub, or a main adaptor with a USB output. If a hub is used, it should be a powered USB
hub to ensure sufficient current is available at the port. The BT850-Sx module can be driven by the available
current at a USB port.
4
BT85x Series
Datasheet
The low noise LDO (U4) on the DVK-BT850-Sx provides the 3.3V to support the entire board’s operating voltage.
4 INTERFACE SPECIFICATION
There are three GPIO signals (GPIO [5;6;7]) presented on pin header J2. These can be used for an LED indicator
or Cypress GCI (Global Coexistence Interface). The following (Table 2) shows the default settings by firmware.
Table 2: Default setting by firmware
GPIO
GPIO_5
GPIO_6
GPIO_7
Note:
Function
LED indications
Cypress GCI; BT_SECI_IN (same as WLAN_Activity)
Cypress GCI; BT_SECI_OUT (same as BT_Activity)
All GPIOs functions are configured by firmware and any changes from the defaults would require a
new firmware load.
The pin descriptions of J2 are shown in Table 3.
Table 3: J2 pin descriptions
J2
Description
Direction
Pin-2
Pin-3
GPIO[5]
GPIO[7]
O
O
Pin-4
GPIO[6]
I
There are four LED indicators on the DVK-BT850-Sx as shown in Table 4.
Table 4: LED indicators
LED
LED1
LED2
LED3
Description
Connected to the BT_SECI_I
Connected to the BT_SECI_OUT
Connected to the output of the U4 (LDO)
LED4
Connected to GPIO_5
Function
Cypress GCI indication
3.3V power supply rail indication
For BT850-Sx of status indications including inquiry, connected,
and data traffic.
▪ When ininquiry mode, the LED is flashing with
one-second periods.
BR/EDR ▪ When the BT connection is created, the LED is
Modes
solid light state .
▪ When the BT has data traffic, the LED is flashing
with 250 ms periods
▪ When in inquiry mode, the LED is flashing with
one-second periods.
LE
Mode
solid light state.
with 250 ms periods
5
BT85x Series
Datasheet
Figure 2: Pin headers - J2
Figure 4: LED1, LED2, LED4
Figure 3: LED3
. PLEASE NOTE – The LED4 status configuration is controlled by firmware, any changes from the above default,
please contact Laird.
The DVK-BT850-Sx has a 4-wire digital audio port capable of operating in PCM or I2S mode; it isa dedicated audio
interface and cannot be used as general purpose GPIOs.
The pin descriptions of J1 in PCM/I2S are shown in Table 5.
Table 5: J1 Descriptions for PCM/I2S Interface
J11
Description (PCM/I2S/SPI)
Pin-1
GND
Pin-2
PCM_SYNC/I2S_WS
Pin-3
Pin-4
Direction
I/O
2
I/O
2
Input
2
Output
PCM_CLK/I S_CLK
PCM_IN/I S_DI
Pin-5
PCM_OUT/I S_OUT
Pin-6
GND
Figure 5: Pin Headers - J11 for PCM/I2S Interface
DC Power Supply
USB Connector – The development kit provides a USB Type micro-USB connector (USB1) which allows
connection to any USB host device. The connector optionally supplies power to the DVK-BT850-Sx when
SW2 is set to the USB position.
DC JACK – The development kit provided a DC JACK (CN1) for DC power supply input with an LDO (U4) to
converting input voltage to 3.3V. The operation voltage range of the LDO is from 2.5V to 5.5V (1) and the
current consumption is 1A maximum. When using the DC JACK for supply voltage to the DVK-BT850, the
SW2 need to set to the DC JACK position.
(1) The DVK-BT850-Sx that it just supported +5V input only.
6
BT85x Series
Datasheet
Figure 6: Micro-USB Connector (USB1), SW2, and DC JACK (CN1)
Push Button
SW4 (push button TACT switch) provides a reset signal to reset the BT850-Sx module (Error! Reference source
not found.).
Push Button
Label on DVK-BT850 PCB
Description
SW4
Reset
Reset the BT850-Sx module
Figure 7: SW4
5 OTHER FEATURES
A removable jumper (J3) is provided to break the power supply line directly to the module (if SB1 is cut),
allowing you to measure current consumption. For normal operation, J3 must be fitted. Error! Reference source
not found. shows the locations of SB1 and J3.
Note:
This measures the current consumption of the BT850-Sx series module ONLY.
7
BT85x Series
Datasheet
Figure 8: Current measurement circuit
To prepare the board for current measurement, cut the shorting of the solder bridge SB1. After this
modification, there are two primary ways to measure the current consumption:
Using Ammeter – Connect an ampere meter between the two pins of connector J3. This directly monitors
the current.
Using Oscilloscope (Note below) – Mount a resistor on the footprint R3. The resistor should not be larger
than 10 Ohm. Connect an oscilloscope or similar with two probes on the pin on the J3 connector and
measure the voltage drop. The voltage drop is proportional with current consumption. If a one-Ohm
resistor is chosen,
1 mV equals 1 mA.
There is also a third way to measure current:
Using Current Shunt Monitor – The current drawn by the BT850-Sx module can be monitored using the
Current Shunt Monitor (CSM), INA216 (U3). The gain of INA216 is 200 V/V for lowest possible drop voltage.
Note:
The Current Shunt Monitor method allows the dynamic current consumption waveforms on
oscilloscope as the BT850-Sx radio operates. This can provide insight into power optimization.
Current consumed by the BT850-Sx series module is measured as a voltage (that is proportional to the current)
using the CSM by connecting measuring voltmeter or oscilloscope to TP3 Connect measuring voltmeter or
oscilloscope GND to TP2.
I(mA) = Vmeas_TP3(mV) /51
CAUTION:
To avoid permanent damage to the IC U3 (the current shunt monitor), do not short the TP3 output
to GND.
6 ADDITIONAL DOCUMENTATION
Laird offers a variety of documentation and ancillary information to support our customers through the initial
evaluation process and ultimately into mass production. Additional documentation can be found at the BT850
product page under the documentation tab. It includes:
BT850 – Class 1 BT4.2 Dual Mode HCI module – Product brief
BT850 Datasheet - Hardware Integration Guide
8
BT85x Series
Datasheet
BT850 UART HCI Bluetooth Module for Linux – User’s Manual – Using the BT850 with the BlueZ Linux
BCCMD tool
For any additional questions or queries or to receive local technical support for the DVK-BT850-Sx or BT850Sxmodule, please visit our support site at https://laird-ews-support.desk.com/.
9
BT85x Series
Datasheet
7 ADDITIONAL ASSISTANCE
Please contact your local sales representative or our support team for further assistance:
Laird Technologies Connectivity Products Business Unit
Support Centre: http://ews-support.lairdtech.com
Email: wireless.support@lairdtech.com
Phone:
Europe:
Hong Kong:
Web:
+44-1628-858-940
+852 2923 0610
http://www.lairdtech.com/bluetooth
© Copyright 2018 Laird. All Rights Reserved. Patent pending. Any information furnished by Laird and its agents is believed to be accurate and reliable.
All specifications are subject to change without notice. Responsibility for the use and application of Laird materials or products rests with the end user
since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to non-infringement nor as to the fitness, merchantability,
or sustainability of any Laird materials or products for any specific or general uses. Laird, Laird Technologies, Inc., or any of its affiliates or agents shall
not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of Sale in effect
from time to time, a copy of which will be furnished upon request. When used as a tradename herein, Laird means Laird PLC or one or more subsidiaries
of Laird PLC. Laird™, Laird Technologies™, corresponding logos, and other marks are trademarks or registered trademarks of Laird. Other marks may be
the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property right.
10
很抱歉,暂时无法提供与“DVK-BT850-SA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+581.8681410+70.58725
- 20+579.1490820+70.25740
- 30+579.1362730+70.25584
- 40+579.1234740+70.25429
- 50+579.1106750+70.25274
- 国内价格 香港价格
- 1+581.868141+70.58725
- 4+579.149084+70.25740
- 10+579.1362710+70.25584
- 25+579.1234725+70.25429
- 40+579.1106740+70.25274
