1000 Eaton Boulevard
Cleveland, OH 44122
United States
Highlights
Important Note
This extender kit operates in line-of-sight only. Make sure to install in an environment where few obstacles
are present.
Wireless HDMI Extender Kit,
Transmitter/Receiver, Zero Latency, 4K, 7.1
Audio, HDCP 2.2, Up to 98 ft. (30 m)
Display HDMI audio/video up to
98-ft. (29.87 m) away with no
costly cable installation
Delivers UHD picture quality at
resolutions up to 3840 x 2160
(4K x 2K) @ 30 Hz
Provides full, rich 7.1-channel
sound for realistic video gaming
and live televised events
Features 10.2 Gbps of
bandwidth to ensure almost zero
latency for premium viewing
Easy plug-and-play
operation—just connect the
transmitter and receiver and
play video
MODEL NUMBER: B127-1A1-WHD1
Applications
Connect a laptop for a video or
PowerPoint presentation in a
conference room or meeting
room, where the source device
changes frequently
Extend HDMI signals in an
indoor environment where
drilling through walls for cabling
is impossible or not practical
Gain flexibility in where the
source and display are placed,
with the freedom to move and
relocate them
Create a cleaner, streamlined
installation for a trade show
booth
Improve the line of sight for
digital signage in a restaurant,
store, school, airport or
entertainment venue
Extends a wireless HDMI 4K audio/video signal with zero latency to an HDMI display located up to 98 ft.
(30 m) from the source device.
Features
All-in-One Wireless Extender Kit Ideal for Transmitting 4K Video in Home Theaters and Offices
This complete wireless HDMI transmitter and receiver system is recommended for video presentations,
high-level gaming and live television events in your home, office, restaurant, bar, trade show and other
applications in which connecting long video cables could be a burden. This kit extends 4K video and 7.1channel audio from an HDMI source device to an HDMI display up to 98-ft. (30 m) away. No bulky or
costly cabling infrastructure is needed.
Wireless Transmission Saves You Money on Cable and Installation Costs
The B127-1A1-WHD1 eliminates more than just hassles. You’ll save on the costs of cabling infrastructure
and the labor to install it. Cable clutter is reduced, and you will enjoy more flexibility in placement of the
source and display with no cables to relocate when you want to reconfigure the room. The transmitter and
receiver units communicate over a 60 GHz wireless frequency that allows fast data transmission and
reduced interference from other wireless sources. Be sure the transmitter and receiver share a direct line
of sight for best results.
System Requirements
Source device with HDMI output
(Blu-ray player, cable box,
laptop)
Display device with HDMI input
(HDTV, projector, monitor)
Package Includes
Enjoy Live Video with No Lag or Delay in Transmission
Because this kit features the latest wireless technology with 10.2 Gbps of bandwidth, it transmits live
audio and video with virtually no latency. It is recommended for high-end video gaming, video
conferencing, digital signage or watching live television events.
Transmits Crystal-Clear 4K Video for Ultra High-Definition Presentations
The B127-1A1-WHD1 ensures Ultra HD performance in a one-to-one application, where there is less
obstruction to occur. It supports video resolutions up to 3840 x 2160 (4K x 2K) at 30 Hz with 7.1-channel
LPCM, DTS-HD and Dolby AC-3 digital audio. LEDs indicate when the transmitter and receiver units are
receiving power, building a wireless connection between the units and transmitting data.
1/4
Transmitter unit
Receiver unit
(2) External power supplies
w/NEMA 1-15P plugs (Input:
100–240V, 50/60 Hz, 0.2A;
Output: 5V 1A)
Owner’s manual
Cleveland, OH 44122
United States
Plug-and-Play Operation for Quick Setup and Immediate Use
The durable aluminum transmitter and receiver set works right out of the box with no software or drivers
required. Connect the receiver to the display and the transmitter to the source with user-supplied HDMI
cables (such as P568-Series). Then, plug the dual power supplies into an AC outlet. You can also use a
USB Micro-B cable (sold separately) to power the two units via laptop, power bank or other portable
power source.
Specifications
OVERVIEW
UPC Code
037332239150
Product Type
Extender Kit
Technology
HDMI; Wireless
VIDEO
Max Supported Video Resolution
3840 x 2160 (4K @ 30Hz)
Max 1280 x 720 (720p) Range (ft)
98
Max 1920 x 1080 (1080p) Range (ft)
98
Max 3840 x 2160 (4K@30Hz)
Range (ft)
98
Transmitter Video Input
HDMI
Transmitter - Number of Video
Outputs
1
Receiver/Transceiver Video Output
HDMI
Receiver - Number of Video Outputs
1
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
Maximum Signal Range (ft)
100
Maximum Signal Range (m)
30
AUDIO
Audio Input
HDMI
Audio Output
HDMI
Audio Specification
7.1 Channel Surround Sound LPCM, DTS-HD and Dolby-AC3 digital audio
INPUT
AC Power Adapter Plug(s)
NEMA 1-15P North America
AC Power Adapter Input Specs (V /
Hz / A)
100-240V / 50/60Hz / 2A
2/4
Cleveland, OH 44122
United States
AC Power Adapter Output Specs (V
/ A)
5V / 1A
AC Power Adapter Cord Length (ft.)
5
AC Power Adapter Cord Length (m)
1.5
Bus Powered
No
POWER
Power Source Type
AC Adapter
AC Plug Type
NEMA 1-15P
Power Source
Transmitter and Receiver (Included)
Power Over Cable (PoC) Support
No
DC Barrel Plug
OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
2.50
Power Consumption Detail
TX: 2.5W; RX: 2.5W
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
TX & RX: (x1) Blue (Power), (x1) Orange (Connection)
PHYSICAL
Color
Black
Material of Construction
Aluminum
Number of Displays
1
Form Factor/Mounting Options
Box
Receiver Unit Dimensions (hwd / in.)
3.11 x 2.13 x 2.29
Receiver Unit Weight (lbs.)
0.26
Transmitter Unit Dimensions (hwd /
in.)
3.11 x 2.13 x 2.29
Transmitter Unit Weight (lbs.)
0.26
Unit Packaging Type
Box
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
-4° to 158°F (-20° to 70°C)
Relative Humidity
0% to 90% RH, Non-Codensing
COMMUNICATIONS
Signal Range (ft.)
98
3/4
Cleveland, OH 44122
United States
Signal Range (m)
30
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
Latency
Near-Zero
USB Extension Support
No
CONNECTIONS
Side A - Connector 1
HDMI (FEMALE); MICRO-USB B (FEMALE)
Side B - Connector 1
Daisy-chainable / Cascadable
No
FEATURES & SPECIFICATIONS
Wireless Transmission Distance
98ft (30m)
10/100 Ethernet Extension Support
No
Transmission RF Frequency
60 GHz Wireless
Built-In Equalizer
No
HDCP Specification
2.2
Driver Required
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
UL; cUL
Product Compliance
RoHS; REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B127-1A1-WHD1”相匹配的价格&库存,您可以联系我们找货
