1000 Eaton Boulevard
Cleveland, OH 44122
United States
DisplayPort over Cat6 Receiver with Repeater,
4K, 4:4:4, Transceiver, PoC, HDCP 2.2, 230 ft.
(70.1 m), TAA
Highlights
Combines with B127A-111BDTD to extend 4K signals up
to 230 ft.
Supports UHD resolutions up to
4K @ 30 Hz (4:4:4) for crystalclear video
Can be daisy-chained up to 4
times (920 ft. total) via additional
B127A-110-BD transceivers
Power over Cable (PoC)
technology provides power to
the transceiver via Cat6 cable
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B127A-110-BD
Applications
Extend video signals from one
room to another using Cat6
cable, which can pass through
conduit to meet building codes
Gain flexibility in where the
receiver is placed, with the
freedom to move and relocate it
away from an AC outlet
Improve the line of sight for
digital signage in a hotel,
restaurant, theater, house of
worship, trade show or other
location
Works with Tripp Lite’s DisplayPort extender kit to extend 4K video an extra 230 ft. between source and
display via Cat6 cable.
Features
DisplayPort 1.2a Extender Transceiver Ideal for Digital Signage in Schools and Restaurants
This 4K transceiver is recommended for video presentations in conference rooms, schools, trade shows,
meeting facilities, houses of worship, retail settings, hotels and other digital signage applications where
the source and display are farther apart than conventional A/V cables allow.
Combines with DisplayPort Extender Kit to Add More Distance
The B127A-110-BD works with B127A-111-BDTD extender kit (sold separately) to further extend a 4K
audio/video signal up to 230 feet (70.1 meters) with no latency. It connects between the transmitter and
receiver from the extender kit with user-supplied Cat6 cabling.
Transmits Crystal-Clear 4K Video with Multi-Channel Audio and 4:4:4 Color
The B127A-110-BD supports Ultra HD resolutions up to 3840 x 2160 (4K x 2K) at 30 Hz with 7.1-channel
surround sound audio through its TOSLINK port. HDCP 2.2 compliance allows you to stream 4K Amazon
and Netflix content with no complications. This receiver also supports 4:4:4 chroma subsampling for toplevel PC gaming or using your HDTV as a PC monitor. Built-in equalization allows you to fine-tune the
image quality at the remote display.
Create a Daisy Chain to Achieve More Distance
This transceiver combines with the B127A-111-BDTD extender kit (sold separately) and additional B127A110-BD transceivers to form daisy-chain installations up to 920 feet (280.4 meters) from the transmitter.
Up to four total transceivers can be chained together, each capable of extending a 4K signal up to 230
feet per unit. In addition to the extender kit, this transceiver is also compatible with B127A-1A1-BDBD and
can be used to replace any receivers in the installation as well.
Add a Signal Booster to Achieve, Yes, Even More Distance
The receiver is also compatible with B127A-010-H signal booster (sold separately), which allows the
signal to be boosted up to 400 feet (121.9 meters) total between the transmitter and transceiver. When
used in a daisy-chain installation, this brings the total extension distance up to 1,090 ft. (332.2 meters).
Note: B127A-010-H will only work when used in the first link of the daisy-chain installation.
1/5
System Requirements
Source device with DisplayPort
output (computer, laptop, media
server)
Display device with DisplayPort
input (HDTV, projector, monitor)
B127A-111-BDTD DisplayPort
over Cat6 Extender Kit
Package Includes
B127A-110-BD DisplayPort over
Cat6 Receiver
External power supply (Input:
100–240V, 50/60 Hz, 0.6A;
Output: 24V 1A)
(4) International plug adapters
(North America, Europe, U.K.
and Australia)
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Built-In PoC Technology Provides Receiver Power to Avoid Bulky External Power Bricks
Power over Cable (PoC) technology powers the B127A-110-BD over Cat6 cable. LEDs indicate when the
system is receiving power and a signal is being transmitted. PoC lets you avoid the hassle of a bulky
power brick and gives you the freedom to place the transceiver where needed without worrying about
finding a nearby AC outlet. Power is also equally distributed to any additional receivers within a daisychain installation.
Plug-and-Play Operation for Quick Setup and Immediate Use
The transceiver works right out of the box with no software required. Mounting hardware is included for
installing it on a wall, pole or 19-inch rack. Connect the transceiver to a transmitter and any additional
transceivers with user-supplied Cat6 cable (such as N202-Series). Connect to a 4K display with a usersupplied DisplayPort cable (such as P580-Series).
TAA-Compliant for GSA Schedule Purchases
The B127A-110-BD is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for
GSA (General Services Administration) Schedule and other federal procurement contracts.
Specifications
OVERVIEW
UPC Code
037332263124
Product Type
Receiver
Technology
Cat5/5e; Cat6; DisplayPort; POC
Host Connector
RJ45 (FEMALE)
VIDEO
Video Input
DISPLAYPORT (FEMALE)
Video Output
Video Ports
Video Ports Details
DisplayPort 1.2a; HDCP 2.2
Supported Resolutions
1280x720 (720p); 1920x1080 (1080p); 3840x2160 (4K)
Max Supported Video Resolution
3840 x 2160 (4K x 2K) @ 30 Hz
Max. Distance (Between any 2
Units)
230 ft.
Max 1280 x 720 (720p) Range (ft)
230
Max 1920 x 1080 (1080p) Range (ft)
2300
Max 1920 x 1200 Range (ft)
230
Max 2560 x 1600 Range (ft)
230
Max 3840 x 2160 (4K@30Hz)
Range (ft)
230
Max 4096 x 2160 (4K) Range (ft)
230
Receiver/Transceiver Video Output
DisplayPort
Receiver - Number of Video Outputs
2
2/5
Cleveland, OH 44122
United States
Signal Range (ft)
230
Signal Range (m)
70
Range Extension using other Tripp
Lite product
170 ft. or 230 ft.
Recommended Cabling
Solid Wire 24AWG Cat6 Cables (Tripp Lite's N202-Series)
Other Tripp Lite product used to
extend range
B127A-010-H Signal Booster or additional B127A-110-BD Transceivers (up to 3)
Max Supported Color Depth
36-bit Deep Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
Maximum Signal Range (ft)
230
Maximum Signal Range (m)
70
Maximum Signal Range Details
A single B127A-110-BD unit can be connected to a transmitter unit to reach 230 ft. When daisy-chaining multiple
B127A-110-BD's (up to 4 total) each link in the chain reaches 230 ft., for a maximum distance of 920 ft. When using
a B127A-010-H signal booster between the first transmitter and first B127A-110-BD in the chain in a four-link daisychain installation the total distance can be 1070 ft.
AUDIO
Audio Input
Displayport
Audio Output
Displayport; Toslink
Audio Specification
Pass-through audio formats including LPCM2.0/5.1/7.1; TOSLINK audio
INPUT
AC Power Adapter Plug(s)
AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America
AC Power Adapter Input Specs (V /
Hz / A)
100-240V / 50/60Hz / 0.6A
AC Power Adapter Output Specs (V
/ A)
24V / 1A
AC Power Adapter Cord Length (ft.)
4.53
AC Power Adapter Cord Length (m)
1.381
Voltage Compatibility (VAC)
100; 110; 120; 125; 127; 200; 208; 220; 230; 240
Bus Powered
No
POWER
Power Source Type
AC Adapter
AC Plug Type
AS/NZS 3112; BS1363; CEE 7/16 Schuko; NEMA 1-15P
Power Source
Transmitter end only (Optional)
Power Over Cable (PoC) Support
Yes
3/5
Cleveland, OH 44122
United States
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
(x1) Power = Green; RJ45 (x2) Green = Unit is receiving power, (x2) Orange = signal is being sent
PHYSICAL
Color
Black
Material of Construction
Metal
Included Mounting Accessories
(2) Mounting Brackets
Number of Displays
1
Form Factor/Mounting Options
Box
Rackmountable
Yes
Shipping Dimensions (hwd / in.)
2.17 x 10.24 x 6.46
Shipping Dimensions (hwd / cm)
5.51 x 26.01 x 16.41
Shipping Weight (lbs.)
1.23
Shipping Weight (kg)
0.56
Unit Dimensions (hwd / in.)
1.063 x 4.528 x 2.457
Unit Dimensions (hwd / cm)
2.7 x 11.5 x 6.24
Unit Dimensions (hwd / mm)
27 x 115 x 62.4
Unit Packaging Type
Box
Unit Weight (lbs.)
0.55
Unit Weight (kg)
0.25
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 85%, Non Condensing
COMMUNICATIONS
Signal Range (ft.)
230
Signal Range (m)
70
Transmission Distance
230 ft. (70m) ; 400 ft. (121 m) with signal booster
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
No
Latency
Cleveland, OH 44122
United States
USB Extension Support
No
CONNECTIONS
Side A - Connector 1
(2) RJ45 (FEMALE)
Side A - Connector 2
Side B - Connector 1
TOSLINK (FEMALE)
Daisy-chainable / Cascadable
Yes
Details
Up to 4 Units
PORT EXPANSION
Daisy-chainable or Cascadable
Daisychainable up to 4 layers, 230 ft. per layer
FEATURES & SPECIFICATIONS
Integrated/Removable Cable
No
MST Support
No
Mounting Accessory Included
Yes
Multi-Resolution Support
No
Built-In Equalizer
Yes
Displayport Specification
1.2a
HDCP Specification
1.4; 2.2
Driver Required
No
Recommended Category Cable
Cat6
DIN Mountable
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
CCC; CE; GS; TUV; UL; cUL
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
