1000 Eaton Boulevard
Cleveland, OH 44122
United States
DisplayPort to HDMI over Cat6 Extender Kit, KVM
Support, 4K 60Hz, 4:4:4, USB, PoC, HDCP 2.2,
230 ft., TAA
Highlights
Supports UHD resolutions up to
4K @ 60 Hz (4:4:4) for crystalclear video
Power over Cable (PoC)
technology provides power to
either end via Cat6 cable
Transmitter’s local port shows
you the 4K image being
displayed at the other end
DIP switch selection allows bidirectional IR or USB function
for controlling the source
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B127A-1A1-BDBH
Applications
Connect a laptop for a video or
PowerPoint presentation in an
auditorium or lecture hall, where
the source device changes
frequently
Extend video signals from one
room to another using Cat6
cable, which can pass through
conduit to meet building codes
Gain flexibility in where the
receiver is placed, with the
freedom to move and relocate it
away from an AC outlet
Improve the line of sight for
digital signage in a hotel,
restaurant, theater, house of
worship, trade show or other
location
Stream Netflix, Amazon Prime,
Hulu and other home
entertainment channels to your
HDTV or projector
Transmitter/receiver kit extends a 4K signal via Cat6 cable from a DisplayPort source to an HDMI display
up to 230 ft. away.
Features
DisplayPort to HDMI Extender Kit Ideal for Digital Signage in Schools and Lecture Halls
This complete transmitter and receiver system is recommended for video presentations in conference
rooms, schools, trade shows, meeting facilities, houses of worship, retail settings, hotels and other digital
signage applications where the source and display are farther apart than conventional A/V cables allow.
Extends a 4K A/V Transmission up to 230 ft.
The B127A-1A1-BDBH extends 4K signals from a DisplayPort source device to an HDMI display up to
230 feet away via user-supplied Cat6 cabling. By adding a B127A-010-H HDMI repeater or B127A-110BH transceiver (sold separately) to the application, you can extend the signal up to 400 or 460 feet,
respectively.
Transmits Crystal-Clear 4K Video with Multi-Channel Audio and 4:4:4 Color
The B127A-1A1-BDBH supports Ultra HD resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz, as specified
by HDMI 2.0, with full, rich uncompressed DTS-HD, Dolby TrueHD and 7.1-channel digital audio. HDCP
2.2 compliance allows you to stream 4K Amazon and Netflix content with no complications. This extender
kit also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor.
Built-in equalization allows you to fine-tune the image quality at the remote display.
Local HDMI Port on Transmitter Supports 4K @ 60 Hz Resolution
To monitor the video signal being extended to the receiver, connect a 4K display to the transmitter’s local
HDMI port with a user-supplied HDMI cable. This port does not support multi-resolution capabilities, so the
connected monitor must also support 4K/60 Hz to function properly.
Built-In PoC Technology Provides Power to Avoid Bulky External Power Bricks
After you connect the included external power supply to either the transmitter or receiver, Power over
Cable (PoC) technology powers the opposite unit over Cat6 cable. LEDs on both the transmitter and
receiver will light up to indicate the system is receiving power and a signal is being transmitted. PoC lets
you avoid the hassle of a bulky power brick and gives you the freedom to place one unit where needed
without worrying about finding a nearby AC outlet.Dip Switch Extends Your Choice of Either USB or
IR.
The DIP switches on both the transmitter and receiver can be adjusted to let you choose from the USB 1.1
1/6
System Requirements
Source device with DisplayPort
output (Blu-ray player, PC,
laptop)
Display device with HDMI input
(HDTV, projector, monitor)
Package Includes
Transmitter
Receiver
External power supply (Input:
100–240V, 50/60 Hz, 0.6A;
Output: 24V 1A)
(4) International plug adapters
(North America, Europe, U.K.
Cleveland, OH 44122
United States
or bi-directional IR functions. Choose to either control the source device via keyboard and mouse or IR
remote control from the display end of the installation. Only one function can be extended at a time.
Plug-and-Play Operation for Quick Setup and Immediate Use
The included transmitter and receiver units work right out of the box with no software required. Mounting
hardware is included for installing both units on a wall, pole or 19-inch rack. Connect the transmitter to the
source with a user-supplied DisplayPort cable (such as P580-Series). Then connect the receiver to the
display with a user-supplied HDMI cable (such as P568- or P569-Series). Finally, connect the two units
with user-supplied Cat6 patch cable (such as N202-Series).
TAA-Compliant for GSA Schedule Purchases
The B127A-1A1-BDBH is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible
for GSA (General Services Administration) Schedule and other federal procurement contracts.
Specifications
OVERVIEW
UPC Code
037332258656
Product Type
Extender Kit
Technology
Cat5/5e; Cat6; HDMI; POC
VIDEO
Video Input
DISPLAYPORT (FEMALE)
Video Output
HDMI (FEMALE)
Number of Monitors Supported
2
Video Ports
DISPLAYPORT (FEMALE); HDMI (FEMALE)
Video Ports Details
HDMI 2.0; HDCP 1.4; HDCP 2.2; DisplayPort 1.4
Max Supported Video Resolution
3840 x 2160 (4K @ 60Hz)
Max. Distance (Between any 2
Units)
230 ft.; 400 ft. with B127A-010-H signal booster
Max Number of Ports (Entire Chain)
1
Max 1280 x 720 (720p) Range (ft)
230
Max 1920 x 1080 (1080p) Range (ft)
230
Max 1920 x 1200 Range (ft)
230
Max 2560 x 1600 Range (ft)
230
Max 3840 x 2160 (4K@30Hz)
Range (ft)
230
Max 3840 x 2160 (4K@60Hz)
Range (ft)
230
Transmitter Video Input
DisplayPort
Transmitter - Number of Video
Outputs
1
Transmitter - Local Display Output
HDMI
2/6
and Australia)
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Receiver/Transceiver Video Output
HDMI
Receiver - Number of Video Outputs
1
Range Extension using other Tripp
Lite product
170 ft. or 230 ft.
Recommended Cabling
Solid Wire Cat6 Cables (Tripp Lite's N202-Series)
Other Tripp Lite product used to
extend range
B127A-010-H or B127A-110-BH
Max Supported Color Depth
36-bit True Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
Maximum Signal Range (ft)
230
Maximum Signal Range (m)
70
AUDIO
Audio Ports
Audio Ports Details
Supports pass-through of audio formats including LPCM2.0/5.1/7.1
Audio Input
Displayport
Audio Output
Toslink; HDMI
Audio Specification
Pass-through audio (LPCM 2.0/5.1/7.1)
INPUT
AC Power Adapter Plug(s)
AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America
AC Power Adapter Input Specs (V /
Hz / A)
100-240V / 50/60Hz / 0.6A
AC Power Adapter Output Specs (V
/ A)
24V / 1A
AC Power Adapter Cord Length (ft.)
4.5
AC Power Adapter Cord Length (m)
1.38
Voltage Compatibility (VAC)
100; 110; 120; 125; 127; 200; 208; 220; 230; 240
Bus Powered
No
POWER
Power Source Type
AC Adapter
AC Plug Type
NEMA 1-15P; BS1363; CEE 7/16 Schuko; AS/NZS 3112
Power Source
Transmitter or Receiver (Included)
Power Over Cable (PoC) Support
Yes
Receiver Power Source
AC Adapter (Included); Power Over Cable
3/6
Cleveland, OH 44122
United States
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
TX: Green (Power); RJ45 Port: Green (Connection), Orange (Activity); RX: Green (Power), RJ45 Port: Green
PHYSICAL
Color
Black
Material of Construction
Metal
Included Mounting Accessories
Wallmount
Number of Displays
1
Form Factor/Mounting Options
Box; Wall-mount
Rackmountable
Yes
Receiver Unit Dimensions (hwd /
cm.)
2.7 x 11.5 x 6.24
Receiver Unit Dimensions (hwd / in.)
1.063 x 4.528 x 2.457
Receiver Unit Weight (kg)
0.4536
Receiver Unit Weight (lbs.)
1
Shipping Dimensions (hwd / in.)
2.17 x 10.24 x 6.46
Shipping Dimensions (hwd / cm)
5.51 x 26.01 x 16.41
Shipping Weight (lbs.)
1.45
Shipping Weight (kg)
0.66
Transmitter Unit Dimensions (hwd /
cm.)
2.7 x 11.5 x 6.24
in.)
Transmitter Unit Weight (kg)
0.4536
Transmitter Unit Weight (lbs.)
1
Unit Packaging Type
Box
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0% to 85% RH, Non-Condensing
COMMUNICATIONS
Signal Range (ft.)
230
Signal Range (m)
70
Transmission Distance
230 ft.
EDID Compatible
Yes
4/6
Cleveland, OH 44122
United States
IR Remote Extension Support
Yes
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
Latency
Zero-Latency
USB Extension Support
Yes
CONNECTIONS
Side A - Connector 1
Side A - Connector 2
HDMI (FEMALE)
Side A - Connector 3
RJ45 (FEMALE)
Side A - Connector 4
(2) 3.5MM (FEMALE); MICRO-USB B (FEMALE)
Side B - Connector 1
HDMI (FEMALE)
Side B - Connector 2
RJ45 (FEMALE)
Side B - Connector 3
(2) USB A (FEMALE)
Side B - Connector 4
TOSLINK (FEMALE); (2) 3.5MM (FEMALE)
Daisy-chainable / Cascadable
No
FEATURES & SPECIFICATIONS
USB Specification
USB 1.1 (up to 12 Mbps)
Integrated/Removable Cable
No
MST Support
No
Mounting Accessory Included
Yes
Multi-Resolution Support
No
Built-In Equalizer
No
Displayport Specification
1.2a
HDCP Specification
1.4; 2.2
Driver Required
No
Recommended Category Cable
Cat6
DIN Mountable
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
CE; FCC; CCC; GS; TUV; UL; cUL
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
5/6
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
