MTB3-DOCK-04
MTB3-DOCK-04
    TRIPPLITE
    THUNDERBOLT 3 DUAL MONITOR DOCKI
MTB3-DOCK-04 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Highlights Important Note This Thunderbolt 3 docking station must be connected to a Thunderbolt 3-enabled laptop or computer to achieve maximum data transfer and video transmission specifications. Thunderbolt 3 Dual Monitor Docking Station 8K/30Hz DisplayPort, 4K/60Hz HDMI, USB 3.2 Gen 2, GbE, 60W PD Charging - Black ● Connects 2 displays at the same time for multitasking and increasing productivity ● DisplayPort output transmits up to 8K @ 30 Hz to a single display for professional users ● HDMI output supports UHD resolutions up to 4K @ 60 Hz for crystal-clear video ● Carries High Dynamic Range (HDR) signals for rich contrast and expanded color accuracy ● Supports Thunderbolt 3 speeds up to 40 Gbps between compatible source/host devices MODEL NUMBER: MTB3-DOCK-04 Applications Multiport docking station transmits 8K DisplayPort and 4K HDMI video to separate displays, and up to 4K/60Hz video simultaneously. Features Thunderbolt 3 Dock Turns Your Laptop or Notebook into a 7-Port 8K Workstation This Thunderbolt 3 docking station dramatically expands the potential of your MacBook Pro or Windows laptop by adding seven ports to its Thunderbolt 3 port. The MTB3-DOCK-04 allows you to transmit 8K video to a DisplayPort monitor or 4K video to an HDMI monitor, and both ports can be used simultaneously for dual 4K/60Hz video output. You can also add USB peripherals, record a podcast, connect to a Gigabit Ethernet network, and charge your host device. Video resolutions are dependent on the host computer's specifcations. Supports DisplayPort Alternate Mode for Transmitting Audio/Video Signals By connecting the built-in Thunderbolt 3 cable to a source device that supports DisplayPort Alt Mode, you can output 8K/4K video and digital audio to a compatible monitor, television or projector without installing special software drivers. Thunderbolt 3 Supports Blisteringly Fast 40 Gbps Data Transfer Speeds The Thunderbolt 3 cable supports bidirectional speeds up to 40 Gbps, which is eight times faster than USB 3.0, four times faster than Thunderbolt 1 and twice as fast as Thunderbolt 2. With dual 20 Gbps channels moving data both directions at the same time, the MTB3-DOCK-04 is perfectly suited for video streaming and editing on two monitors, as well as transferring large RAW video or CAD files. Transmits Crystal-Clear 8K and 4K Video for Professional Editing and Digital Signage By connecting to a source that supports DisplayPort MST Mode, you may connect one DisplayPort monitor or one HDMI monitor at resolutions up to 8K (7680 x 4320 at 30 Hz) and 4K (3840 x 2160 at 60 Hz as specified in HDMI 2.0), respectively. Both ports can be used simultaneously to support dual video resolutions up to 4K @ 60 Hz. This allows you to display the same image on both monitors, extend your host desktop across both with different windows open on each, or combine both into one large display as 1/5 ● Extend or mirror your MacBook Pro or Windows laptop on multiple displays to aid in multitasking and increase productivity ● Edit HDR production video or digital photos using an 8K monitor ● Connect USB peripherals, including flash drives and hard drives, to transfer data at USB 3.1 Gen 2 speeds ● Access a wired Gigabit Ethernet network in a location with no or spotty Wi-Fi ● Connect a microphone/headset to record a podcast or speakers to listen to music System Requirements ● Source computer with Windows 10 or macOS 10.15.3 and Thunderbolt 3 output ● Source computer with at least DisplayPort 1.3 required to achieve 8K video resolutions ● Display device with HDMI and/or DisplayPort input ● Wired 10/100/1000 Mbps Ethernet network Package Includes ● MTB3-DOCK-04 Thunderbolt 3 Dock, Dual Display, Black ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States a video wall. Note: Host device must support DisplayPort 1.3 in order to achieve 8K resolution. PD 3.0 Charging Port Charges High-Powered Devices via AC Wall Charger The USB-C Power Delivery port provides power output up to 20V 3A (60W), which is sufficient for charging and powering the connected source device, such as a MacBook or Chromebook. Connect the port to the device’s AC wall charger to provide power to the host device as well as the dock. The dock works at optimal specifications while using the PD Charging port to power it. USB Ports Connect Keyboards, Thumb Drives and Other USB Peripherals Two USB-A hub ports accept USB peripherals, such as flash drives, mice, keyboards, external hard drives and printers. When the USB-C PD port (see above) is powering the dock, both USB-A ports support lightning-fast USB 3.2 Gen 2 data transfer rates up to 10 Gbps. When using bus-powered mode, one port supports 10 Gbps, and the other supports USB 2.0 speeds on a first-come, first-serve basis. Both are backward compatible with previous USB generations. Accesses a Wired Gigabit Ethernet Network The RJ45 port offers access to a Gigabit Ethernet network when no Wi-Fi is available or when a wired connection offers faster speeds. Connect using a UTP cable (sold separately), and enjoy true 10/100/1000 Mbps Ethernet speeds for fast data transfers. Connects Stereo Audio Equipment for Recording and Playback This Thunderbolt 3 docking station contains one 3.5 mm mini stereo jack, convenient for connecting speakers, headphones or a microphone to your workstation. You can listen to music or record the latest episode of your podcast. Ready to Use Right from the Package, So You Can Plug and Play Immediately The plug-and-play Thunderbolt 3 dock is specifically designed for use with the MacBook Pro or Windows laptop equipped with a Thunderbolt 3 port. It requires no extra software to be downloaded and installed. Simply connect the Thunderbolt 3 plug to your computer’s Thunderbolt 3 port. Specifications OVERVIEW UPC Code 037332258502 Product Type Docking Station Technology DisplayPort; HDMI; Thunderbolt Host Connector THUNDERBOLT 3 (Type-C MALE) VIDEO Number of Monitors Supported 2 Video Ports DISPLAYPORT (FEMALE); HDMI (FEMALE) Video Ports Details HDMI 2.0; HDCP 2.2; DisplayPort 1.4 Resolutions Supported DisplayPort 8K @ 30 Hz (7680 x 4320)HDMI 4K @ 60 Hz (3840 x 2160)DisplayPort + HDMI 4K @ 60 Hz (3840 x 2160) Max Supported Video Resolution DisplayPort: 7680 x 4320 @ 30Hz (8K); HDMI: 3840 x 2160 @ 60Hz (4K) Extended Mode Yes Extended Mode Details 1x DP (8K/30 Hz)1x HDMI (4K/60 Hz)1x DP (4K/60 Hz) x 1x HDMI (4K/60 Hz) Mirror Mode Yes 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Mirror Mode Details DisplayPort 8K @ 30 Hz (7680 x 4320)HDMI 4K @ 60 Hz (3840 x 2160)DisplayPort + HDMI 4K @ 60 Hz (3840 x 2160) Max Supported Color Depth 48-bit Deep Color HDR Support Yes Chroma Sub Sampling 4:4:4 AUDIO Audio Ports 3.5MM (FEMALE) Audio Ports Details 3.5mm Combo Stereo Audio / Microphone Jack DATA Data Ports (2) USB A (FEMALE) Data Ports Details (2) USB-A - USB 3.2 Gen 2 (10 Gbps) NETWORK Network Ports RJ45 (FEMALE) INPUT Built-In Cable Length (ft.) 0.66 Built-In Cable Length (in.) 7.87 Built-In Cable Length (cm) 20 Bus Powered Yes BATTERY Battery Charging (5V/1.5A Port) No POWER USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 3.0 USER INTERFACE, ALERTS & CONTROLS LED Indicators PD Charging Port in Use = Green, Device Plugged into Thunderbolt Port = Blue CHARGING Total Charging Watts 60 Charging Method USB Charging Ports Supports 60W (20V 3A) Power to Host Computer Charging Ports / Amps 3A 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Material of Construction PC, ABS Unit Dimensions (hwd / in.) 0.980 x 4.170 x 4.170 Unit Dimensions (hwd / mm) 25 x 106 x 106 Unit Packaging Type Box Unit Weight (lbs.) 0.481 Unit Weight (kg) 0.22 ENVIRONMENTAL Operating Temperature Range 32° to 95°F (0° to 35°C) Storage Temperature Range -4° to 158°F (-20° to 70°C) Relative Humidity 0 to 90% RH, Non-Condensing Operating Humidity Range 0 to 90% RH, Non-Condensing Storage Humidity Range 0 to 90% RH, Non-Condensing Power Provided to Connected Device(s) USB-C PD: 60W (20V/3A) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) CONNECTIONS Number of Ports 7 Dock Connectors DisplayPort, HDMI, (2) USB-A 3.2 Gen2, USB-C PD Charging, RJ45, 3.5mm Side A - Connector 1 THUNDERBOLT 3 (Type-C MALE) Side B - Connector 1 DISPLAYPORT (FEMALE) Side B - Connector 2 HDMI (FEMALE) Side B - Connector 3 RJ45 (FEMALE) Side B - Connector 4 3.5MM (FEMALE) Side B - Connector 5 (2) USB A (FEMALE) Side B - Connector 6 USB C (FEMALE) FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 2 USB Specification USB 3.2 Gen 2 (Up to 10 Gbps) MST Support Yes 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Ethernet Support Yes UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No Thunderbolt Specification Thunderbolt 3 (up to 40Gbps short or active cables) Displayport Specification 1.4 HDCP Specification 2.2 Driver Required No Recommended Category Cable Cat5/Cat5e/Cat6 Cables STANDARDS & COMPLIANCE TAA Compliant Option N Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
MTB3-DOCK-04 价格&库存
很抱歉,暂时无法提供与“MTB3-DOCK-04”相匹配的价格&库存,您可以联系我们找货
