1000 Eaton Boulevard
Cleveland, OH 44122
United States
Safe-IT 4-Port Single-Gang Keystone Wall Plate,
Antibacterial, Ivory Gloss, TAA
MODEL NUMBER: N042AB-004-IVG
Highlights
Ideal for home theater, VoIP or
Ethernet in-wall wiring
installations
Made with antibacterial material
proven effective in inhibiting E.
coli and staph
Compatible with all keystone
jack types, including HDMI,
Cat5/6, USB and DisplayPort
High-impact plastic construction
designed to blend in with your
home/office décor
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
Package Includes
Clean, simple faceplate with keystone jack ports mounts to a wall for terminating premise audio/video,
voice or data cable applications.
Features
4-Port Wall Plate Connects Your In-Wall Audio/Video, Voice or Data Cable Lines
This single-gang wall plate provides a clean, simple method for terminating your premise wiring
applications, including home theater (audio/video), VoIP phones (voice) and Ethernet (data). Any type of
keystone jack, including those used in HDMI, Cat5/6, USB and DisplayPort installations, snaps easily into
the cutouts for quick cable connection.
Provides Extra Protection Against Certain Bacteria
The wall plate is constructed using an antibacterial material that is effective in inhibiting Escherichia coli
(E. coli) and Staphylococcus aureus (staph) and tested to ISO 22196:2011 standards. This added
protection makes this cover plate an ideal solution for medical facilities, schools, businesses,
restaurants/kitchens and anywhere else that needs extra protection against bacteria.
High-Impact Construction Designed to Blend In Seamlessly with Your Room
This durable faceplate with an ivory gloss finish blends elegantly into any home or office décor for a sleek,
professional installation. Mounting screws are included. The ABS plastic construction meets UL 94V-0
flame-retardant standards for protection against fire and high heat.
TAA-Compliant for GSA Schedule Purchases
The N042AB-004-IVG is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible
for GSA (General Services Administration) Schedule and other federal procurement contracts.
Specifications
OVERVIEW
UPC Code
037332269157
Accessory Type
Wall Plate
Technology
Cat5/5e; Cat6; Cat6a; DisplayPort; HDBaseT; HDMI; USB 2.0 (High Speed)
1/2
N042AB-004-IVG 4-Port SingleGang Antibacterial Keystone
Wall Plate, Ivory Gloss
(2) Mounting screws
Cleveland, OH 44122
United States
Country/Region
Global
PHYSICAL
Color
Ivory
Material of Construction
ABS (ABS-764)
Total Number of Ports
4
Unit Dimensions (hwd / in.)
4.840 x 3.110 x 0.440
Finish
Gloss
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
-40° to 154°F (-40° to 68°C)
Operating Humidity Range
10% to 90% RH, (Non-Condensing)
Storage Humidity Range
CONNECTIONS
Number of Ports
4
Side A - Connector 1
(4) KEYSTONE JACK CUTOUT
FEATURES & SPECIFICATIONS
Antibacterial
Yes
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); UL 94; UL Listed; cUL Listed
Product Compliance
RoHS; REACH; Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N042AB-004-IVG”相匹配的价格&库存,您可以联系我们找货
