N063-003
N063-003
    TRIPPLITE
    3 端口 面板 银
N063-003 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3-Port Metal DIN-Rail Mounting Module for SnapIn Keystone Jacks and Couplers, Silver, TAA MODEL NUMBER: N063-003 Highlights ● Heavy-duty metal construction ideal for industrial Ethernet network applications ● 3 blank cutouts compatible with all keystone jacks and couplers ● Built-in mounting clip attaches to standard 35 mm DIN rail with no tools needed ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes N063-003 Metal DIN-Rail Mounting Module, 3 Ports Accepts snap-in keystone jacks and couplers to help you manage your DIN-rail network cable application. Features Organizes a Wide Variety of Ethernet Network Patch Cables in Your DIN-Rail Installation This DIN-rail mounting module lets you manage network cable interconnectivity with three blank cutouts, which accommodate all snap-in keystone jacks and in-line couplers. Made from sheet metal with nickel plating, the N063-003 is quick and easy to install on a standard 35-millimeter DIN rail using the built-in mounting clip. TAA-Compliant for GSA Schedule Purchases The N063-003 is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332276889 Technology Cat5/5e; Cat6; Cat6a Firmware / Software Docs Offset Ports No PHYSICAL Primary Form Factor DIN-Rail Color Silver Material of Construction SUS304 & SPCC NI PLATE (STEEL) 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Total Number of Ports 3 Shipping Dimensions (hwd / in.) 2.10 x 4.50 x 8.00 Shipping Weight (lbs.) 0.15 Unit Dimensions (hwd / in.) 2.120 x 1.940 x 2.380 ENVIRONMENTAL Operating Temperature Range -13° to 122°F (-25° to 50°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 10% to 85% RH, (Non-Condensing) CONNECTIONS Number of Ports 3 Side A - Connector 1 (3) KEYSTONE JACK CUTOUT FEATURES & SPECIFICATIONS All-in-One Kit No Antibacterial No IP68 Rated No IP20 Rated No Numbered Ports No DIN Mountable Yes Keystone Jacks Yes Built-in Cables No Color-Coded Connections No EIA/TIA 2/32 Spacing No Labeled Ports No Down-Angled Ports No Panel Applications Ethernet STANDARDS & COMPLIANCE Product Compliance CE (Europe); REACH; RoHS; UKCA; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N063-003 价格&库存
很抱歉,暂时无法提供与“N063-003”相匹配的价格&库存,您可以联系我们找货
