1000 Eaton Boulevard
Cleveland, OH 44122
United States
Double-Gang Surface-Mount Back Box, White,
TAA
MODEL NUMBER: N080-SMB2-WH
Highlights
Mid-sized back box
accommodates any mid-sized or
standard double-gang wall plate
High-impact ABS thermoplastic
construction designed to last a
long time
Classic white color blends
elegantly into your home or
office décor
Raceway cutouts in 3 different
sizes at each panel allow bulk
cabling
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
Applications
Deep double-gang junction box mounts a wall plate to complete multiple audio/video, voice and/or
Ethernet in-wall connections.
Package Includes
N080-SMB2-WH Double-Gang
Surface-Mount Junction Box
(4) #6-20 wood screws
(4) 2-sided adhesive strips
Features
Double-Gang Surface-Mount Junction Box for Premise ApplicationsThe N080-SMB2-WH is ideal for
mounting a double-gang wall plate to complete multiple audio/video, voice and Ethernet in-wall
connections using any type of keystone jack, including Cat5e/6/6a, USB, HDMI, DisplayPort and RCA.
Designed to work with mid-sized and standard double-gang wall plates, this back box is two inches deep.
Raceway Cutouts on Each Side for Easy AccessThe N080-SMB2-WH features raceway cutouts in
three different sizes (1 inch, 1.25 inches and 1.75 inches in diameter) on each side, as well as a
rectangular knockout on the back. The cover snaps securely to the base with no screws required.
Highly Adaptable to Match Your Specific RequirementsMade from robust ABS thermoplastic, the
N080-SMB2-WH is colored white to blend elegantly into any home or office decor for a sleek, professional
installation. Four mounting screws are included.
TAA-Compliant for GSA Schedule PurchasesThe N080-SMB2-WH is compliant with the Federal Trade
Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and
other federal procurement contracts.
Specifications
OVERVIEW
UPC Code
037332236272
Accessory Type
Wall Plate
Technology
Cat5/5e; Cat6; Cat6a; USB 2.0 (High Speed); HDBaseT; HDMI; DisplayPort
Country/Region
Global
1/2
Complete multiple in-wall
Ethernet cable lines
simultaneously
Cleveland, OH 44122
United States
PHYSICAL
Color
White
Total Number of Ports
Shipping Dimensions (hwd / in.)
12.00 x 10.00 x 0.50
Shipping Dimensions (hwd / cm)
30.48 x 25.40 x 1.27
Shipping Weight (lbs.)
0.39
Shipping Weight (kg)
0.18
Unit Dimensions (hwd / in.)
5.060 x 5.080 x 2.130
Unit Dimensions (hwd / cm)
128 x 8 x 5
Unit Weight (lbs.)
0.27
Unit Weight (kg)
0.12
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
-40° to 154°F (-40° to 68°C)
Relative Humidity
10% to 90% RH
CONNECTIONS
Side A - Connector 1
KEYSTONE JACK CUTOUT
Side B - Connector 1
FEATURES & SPECIFICATIONS
Antibacterial
No
STANDARDS & COMPLIANCE
Product Compliance
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N080-SMB2-WH”相匹配的价格&库存,您可以联系我们找货
