1000 Eaton Boulevard
Cleveland, OH 44122
United States
Left-Angle Cat6 Gigabit Molded Slim UTP
Ethernet Cable (RJ45 Left-Angle M to RJ45 M),
Blue, 3 ft. (0.91 m)
MODEL NUMBER: N204-S03-BL-LA
Highlights
Cat6 Ethernet patch cable
delivers fast transmission
speeds up to 1 Gbps in your
LAN
Left-angle RJ45 connector is
easy to plug into switch or panel
pressed against a wall
Over 38% slimmer than
standard Cat6 cables to
increase airflow in full racks
Easy to route around corners
and through crowded cable
management panels
Cable is blue for fast, easy
identification in a crowded rack
or workstation
Applications
Cat6 cable connects Gigabit Ethernet network components like routers, servers and switches in highdensity data centers.
Features
Left-Angle Cat6 Ethernet Cable Connects Equipment in Data Centers and VoIP NetworksThis Cat6
cable is ideal for connecting network components, such as printers, computers, copiers, routers, servers,
modems and switches, in hard-to-reach areas of space-constrained high-density data centers. Designed
for fast transmission and excellent signal quality, this RJ45 patch cable ensures data transfer speeds up
to 1 Gbps throughout your Gigabit Ethernet or VoIP network.
Special Slim Design for Better Airflow and Easier Installation in Crowded RacksThis Cat6 UTP
patch cord is more than 38% smaller in diameter than standard Cat6a cable. This increases airflow in tight
spaces, which helps keep your equipment cool and properly functioning. It also cuts down on clutter in
crowded racks and patch panels, and makes the cable easier to install around corners and through cable
management panels.
Left-Angle RJ45 Patch Cable Makes Connecting and Disconnecting EasierOne RJ45 male connector
is designed at a 90-degree left angle, which prevents excessive bending and reduces stress on the cable.
This makes the space-saving cable easy to plug into patch panels, switches and other devices located in
a confined area or behind a desk.
Blue Jacket to Avoid Misidentification That Can Cause Costly DowntimeThis left-angle Cat6 Ethernet
cable features a blue PVC jacket and molded blue ends. The blue color allows easy, fast identification in a
crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected.
Specifications
OVERVIEW
UPC Code
037332252302
Technology
Cat6
1/3
Build a Gigabit Ethernet or VoIP
network through the connection
of routers, modems, switches
and servers in a high-density
data center
Connect a workstation computer
to the company server to gain
access to printers, scanners and
copiers
Combine with other Tripp Lite
patch cables to set up a colorcoded system in a crowded rack
Create a connection in a tight
space, such as a repurposed
server room or behind furniture
Package Includes
N204-S03-BL-LA Left-Angle
Patch Cable (M/M), Blue, 3 ft.
Cleveland, OH 44122
United States
PHYSICAL
Cable Jacket Color
Blue
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
UTP
Cable Outer Diameter (OD)
4.0 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
28 AWG
Cable Length (ft.)
3
Cable Length (m)
0.91
Cable Length (in.)
36
Cable Length (cm)
91.4
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (kg)
0.03
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Relative Humidity
0% to 90% RH, Non-Condensing
Operating Humidity Range
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
250 MHz
Maximum Bandwidth as Tested
500 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3an
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE) - LEFT ANGLE
Crossover Wiring
No
Contact Plating
Gold
Connector Type
Molded
2/3
Cleveland, OH 44122
United States
Wiring Configuration
EIA/TIA 568B
Angled Connector
Yes
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
No
Snagless Connector
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3an 10GBase-T; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N204-S03-BL-LA”相匹配的价格&库存,您可以联系我们找货
