1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6a 10G Snagless Molded UTP Ethernet Cable
(RJ45 M/M), PoE, White, 25 ft. (7.6 m)
MODEL NUMBER: N261-025-WH
Highlights
Cat6a UTP Ethernet cable rated
for high-speed 10 Gbps
communications
Supports PoE to save you
expense and effort of powering
PoE devices individually
Allows installation of PoE
devices in hard-to-reach areas
or away from AC outlets
Snagless RJ45 connectors
prevent tabs from being
damaged during installation
White jacket permits fast, easy
identification in a crowded
switch or patch panel
Package Includes
N261-025-WH Cat6a 10G
Cable (RJ45 M/M), PoE, White, 25
ft. (7.6 m)
Ethernet cable with Power over Ethernet (PoE) connects critical components, such as servers, switches,
routers and hubs, in high-density 10G networks.
Features
Cat6a Cable Ideal for Your High-Density 10 Gigabit Ethernet Network
This Cat6a 10G Ethernet cable with RJ45 connectors is recommended for connecting network
components like printers, computers, copiers, routers, servers, modems, hubs and switches in highdensity data centers and network closets. Designed for fast transmission and excellent signal quality, the
N261-025-WH ensures peak performance throughout your LAN.
Supports Power over Ethernet to Save You Money and Give You More Installation Choices
Because this Cat6a cable supports PoE, it can supply the power to operate compatible PoE devices, such
as security cameras, VoIP telephones, point-of-sale kiosks and access control devices. This saves you
the expense and effort of purchasing, connecting and installing individual power supplies for each device.
It also helps you install PoE devices in areas far away from AC outlets, such as poles or ceilings.
Snagless RJ45 Male Connectors Add Extra Protection
The RJ45 connectors’ snagless design protects the locking tabs from being damaged or broken off during
installation. The contacts feature 50-micron gold plating to help ensure the most accurate signal transfer
possible, improving near-end crosstalk (NEXT) performance to 500 MHz.
White Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The cable has a white PVC jacket, which is easy to identify quickly in a crowded patch panel or switch and
helps prevent the cable from becoming accidentally disconnected.
Premium Construction for Superior Performance
Manufactured from 24 AWG copper wire, the four-pair stranded cable is rated for speeds up to 10 Gbps.
Integral strain relief gives the unshielded cable extra flexibility, reduces stress and helps the cable move
freely without cracking or breaking loose from the connector.
Specifications
OVERVIEW
1/3
Cleveland, OH 44122
United States
UPC Code
037332277503
Technology
Cat6a; PoE
PHYSICAL
Cable Jacket Color
White
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
UTP
Cable Outer Diameter (OD)
6.0 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
25
Cable Length (m)
7.62
Cable Length (in.)
300
ENVIRONMENTAL
Operating Temperature Range
-4° to 140°F (-20° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
500 MHz
Maximum Bandwidth as Tested
500 MHz
Network Compatibility
10 Gbps
IEEE Standards Supported
802.3ab; 802.3an; 802.3af; 802.3at
CONNECTIONS
PoE Capability
15.4W (802.3af); 30W (802.3at)
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Connector Plating
Nickel
Contact Plating
Gold
PoE Type
Type 1 PoE (15.4W, IEEE 802.3af); Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Molded; Snagless
2/3
Cleveland, OH 44122
United States
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
No
Snagless Connector
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3af PoE; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+;
REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N261-025-WH”相匹配的价格&库存,您可以联系我们找货
