1000 Eaton Boulevard
Cleveland, OH 44122
United States
Hardened Gigabit Fiber to Ethernet Media
Converter, 10/100/1000 Mbps, RJ45/SC
Singlemode, -10° to 60°C, 10 km (6.2 mi.)
Highlights
Extends up to 1000 Mbps (1
Gbps) of data to a network
device up to 10 km away
Automatic MDI/MDI-X
configuration connects devices
without crossover cabling
Hardened aluminum housing
withstands operating
temperature range of -10° to
60°C
LEDs indicate Ethernet
connection and various
statuses, including data transfer
speed
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: N785-H01-SCSM
Package Includes
Extends a 10/100/1000 Mbps Gigabit Ethernet network connection over SC duplex singlemode fiber optic
cable up to 10 kilometers.
N785-H01-SCSM Media
Converter
L-shaped bracket
Rubber foot
SC connector cap
External power supply with
NEMA 1-15P plug (Input:
100–240VAC, 50/60 Hz, 0.5A;
Output: 12VDC 1.5A)
DIN rail kit
Wall-mounting hardware
Quick Start Guide
Features
Extends a Network Connection up to 10 km over SC Singlemode Fiber Optic Cable
This network media converter converts a copper Gigabit Ethernet signal to a singlemode fiber optic signal
and extends it to a second network device up to 10 kilometers (6.2 miles) away. Because copper Cat5e/6
cables are limited to only 100 meters, it is more effective to couple the N785-H01-SCSM with singlemode
fiber cable to reach hubs, switches and other network devices located farther away. Auto-negotiation and
automatic MDI/MDI-X configuration seamlessly connect devices without crossover cabling.
Monitor Your Installation with Link Fault Signaling and Loop Back Functions
Determine the health of your network connection via the Link Fault Signaling (LFS) and Loop Back
functions. The LFS LED indicates when a copper or fiber cable has been severed or another cause of
disruption in service has occurred. The Local Loop Back (LLB) and Remote Loop Back (RLB) functions
ensure copper and fiber cables have been correctly installed. Use the DIP switches to control each
function or turn them on or off.
LEDs Indicate Installation Performance and Diagnostic Functions
Easy-to-read LEDs on the side of the unit indicate essential status information, including network speed
and connection, LFS diagnostics and unit power.
Protective Metal Housing Built to Withstand a Variety of Hazards
The hardened aluminum case is designed to operate in extreme temperatures ranging from -10 to 60
degrees Celsius (14 to 140 degrees Fahrenheit). It is protected from electrostatic discharge (ESD), radio
frequency interference (RFI) and power surges. Hardware is included for wall or DIN mounting.
Works in Tandem with N785-CH12 Chassis
House and power up to 12 media converters, including the N785-H01-SCSM, using the N785-CH12 12port chassis (sold separately) to create an organized installation.
TAA-Compliant for GSA Schedule Purchases
The N785-H01-SCSM is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible
for GSA (General Services Administration) Schedule and other federal procurement contracts.
1/4
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332267054
Product Type
Fiber to Ethernet
Technology
Cat5/5e; Cat6; Cat6a; PoE; Singlemode
Mode Type
Singlemode
DISPLAY
Accessories (Included)
External Power Supply (Input: 100-240V, 50/60Hz, 0.5A; Output: 12V/1.5A), Mounting Bracket, Mounting Hardware,
DIN Rail, SC Connector Cap, L-Shape Holder, Rubber Foot
NETWORK
Network Ports
RJ45 (FEMALE); SC (FEMALE)
INPUT
AC Power Adapter Plug(s)
NEMA 1-15P North America
AC Power Adapter Input Specs (V /
Hz / A)
100-240V / 50/60Hz / 0.5A
AC Power Adapter Output Specs (V
/ A)
12V / 1.5A
AC Power Adapter Cord Length (ft.)
3.94
AC Power Adapter Cord Length (m)
1.2
POWER
Power Source Type
AC Adapter
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 12V, 1.5A
DC Barrel Plug
OD: 5.5 x 2.5 x 11mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
1.80
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PWR (Power), ALM (LFS function indicator), Fiber - 1000 (For Ethernet speed 1000Mbps), LNK/ACT (For Fiber port
data transmitting/receiving), RJ45 - 1000 (For RJ45 speed 1000Mbps), LNK/ACT (For Copper port data
transmitting/rec)
PHYSICAL
Color
Black
Power Cord Color
Black
Unit Dimensions (hwd / in.)
0.920 x 2.910 x 4.300
2/4
Cleveland, OH 44122
United States
Unit Dimensions (hwd / cm)
2.34 x 7.38 x 10.92
Unit Packaging Type
Box
Unit Weight (lbs.)
0.5267
Unit Weight (kg)
0.24
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
-40° to 185°F (-40° to 85°C)
Relative Humidity
5% to 95% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
10 Mbps; 100 Mbps (Fast Ethernet); 1 Gbps (Gigabit)
Network Speed Details
10 Mbps; 100 Mbps; 1000 Mbps
Wavelength
1310nm
Transmission Distance
10 km
IEEE Standards Supported
802.3; 802.3ab; 802.3u; 802.3z
Wavelength Division Multiplexing
(WDM)
Yes
CONNECTIONS
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
SC (FEMALE)
FEATURES & SPECIFICATIONS
Data Transfer Rate
1 Gbps; 10 Mbps; 100 Mbps
Mounting Accessory Included
Yes
Auto MDIX Support
Yes
DIN Mountable
Yes
Optical Port
SC
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; LPS; RoHS; UL; WEEE; cUL
Product Compliance
RoHS; CE (Europe); FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“N785-H01-SCSM”相匹配的价格&库存,您可以联系我们找货
