1000 Eaton Boulevard
Cleveland, OH 44122
United States
8K HDMI Cable (M/M) - 8K 60 Hz, Dynamic HDR,
4:4:4, HDCP 2.2, Black, 3 ft.
MODEL NUMBER: P568-003-8K6
Highlights
Supports UHD resolutions up to
8K @ 60 Hz (4:4:4) for
heightened video quality
Supports Dynamic HDR for
richer contrast and expanded
color accuracy per frame
Supports eARC for fullresolution object-based
surround sound with no
compression
Plug-and-play operation with no
software required for easy,
immediate installation
Applications
Watch 8K video from a
compatible Blu-ray player, game
console, laptop or tablet on a
compatible television, monitor or
projector
Connect a Windows laptop to a
conference table’s A/V box to
give a video presentation on a
large screen
Play online or PC video games
that display optimal graphics
Send 8K video content to digital
signs or point-of-sale displays
8K HDMI cable connects your HDMI compatible source and display devices to transmit enhanced 8K
video with Dynamic HDR.
Features
HDMI Cable Helps Your Gaming, Home Theater or Digital Signage Setup Get 8K-ReadyThis HDMI
cable (M/M) allows your compatible hardware to deliver up to 8K resolutions while securely connecting
source and display devices compatible with HDMI audio/video signals. Backward compatible with all your
existing HDMI devices, including Blu-ray players, game consoles and 4K televisions, the P568-003-8K6 is
ideal for future-proofing your high-definition or UHD A/V application in anticipation of an 8K upgrade.
Enjoy the Clarity of 4K/8K Video with Multi-Channel Audio, HDR and 4:4:4 ColorThe P568-003-8K6
supports 8K video resolutions and 7.1-channel surround sound, including Dolby Atmos. It’s compatible
with 8K/60Hz video resolutions with Dynamic HDR (High Dynamic Range), which maintains premium
contrast and color in each scene or even each frame. HDCP 2.2 compliance allows you to stream 4K
Amazon and Netflix content with no complications. This cable also supports 4:4:4 chroma subsampling for
top-level PC gaming or using your HDTV as a PC monitor.
Take Advantage of the Most Advanced HDMI Features for Premier Picture QualityThis 8K 60Hzready cable allows your compatible hardware to deliver up-to-date features, such as eARC (enhanced
Audio Return Channel), which passes full-resolution surround sound signals to your speakers without
compressing them. QMS (Quick Media Switching) switches from one frame rate to another without the
delay of a blank screen between them. ALLM (Auto Low Latency Mode), VRR (Variable Refresh Rate)
and QFT (Quick Frame Transport) reduce latency, refresh rate and lag for a more vivid gaming
experience.
Invest in Quality Construction for Reliable PerformanceYou’re expecting this 8K cable to last a long
time, which is why it has been constructed with high-quality materials, such as a rugged PVC jacket.
Contacts and connectors are gold-plated to resist corrosion. Double shielding reduces line noise
(EMI/RFI) that can disrupt signals traveling through the HDMI cord.
Specifications
OVERVIEW
1/4
System Requirements
Both source and display devices
must be compatible with 8K
standards to watch 8K video
Package Includes
P568-003-8K6 HDMI Cable, 8K @
60 Hz, M/M, Black, 3 ft. (0.9 m)
Cleveland, OH 44122
United States
UPC Code
037332254795
Product Type
Passive Cable
Technology
HDMI
Cable Type
Passive
VIDEO
Max Supported Video Resolution
7680 x 4320 (8K) @ 60Hz
Max Supported Color Depth
48-bit Deep Color
HDR Support
Yes
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Bidirectional
AUDIO
Audio Specification
eARC
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Black
Material of Construction
PVC
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
7.3 mm
Wire Gauge (AWG)
28
Cable Length (ft.)
3
Cable Length (m)
0.91
Cable Length (in.)
36
Ferrite Core
No
Minimum Bend Radius
36.5mm
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Weight (kg)
0.08
Unit Dimensions (hwd / in.)
9.000 x 7.000 x 0.500
2/4
Cleveland, OH 44122
United States
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
Integrated/Removable Cable
No
MST Support
No
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Fully Molded Connector Ends
No
Ohms
No
Integral Strain Relief
No
Impedance-Matched Twisted-Pair
Construction
No
Scaler Function
No
IP67 Rated
No
Armored Cable
No
Ethernet Support
Yes
HDCP Specification
1.4; 2.2
Driver Required
No
3/4
Cleveland, OH 44122
United States
DIN Mountable
No
STANDARDS & COMPLIANCE
Product Certifications
IEC/EN 62040
Product Compliance
CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“P568-003-8K6”相匹配的价格&库存,您可以联系我们找货
