1000 Eaton Boulevard
Cleveland, OH 44122
United States
DisplayPort Active Optical Cable (AOC), 8K 60 Hz
(M/M), CL3 Rated, Latching Connectors, Black,
20 m (65 ft.)
Highlights
Supports UHD resolutions up to
8K @ 60 Hz (4:2:2) for
heightened video quality
Carries High Dynamic Range
(HDR) signals for rich contrast
and expanded color accuracy
Complies with HDCP 2.2 and
1.4 standards to display up-todate 8K video content
CL3-rated PVC cable jacket
meets required standards for
commercial in-wall installation
Draws power from connected
device to transmit 8K signal over
long distances
MODEL NUMBER: P580F3-20M-8K6
Applications
Watch 8K video from a
compatible Blu-ray player, game
console, laptop or tablet on a
compatible television, monitor or
projector
Connect a Windows laptop to a
conference table’s A/V box to
give a video presentation on a
large screen
Send 8K video content via inwall cable setups to digital signs
or point-of-sale displays
Connect a security camera or
other A/V surveillance
equipment to a central monitor
High-speed in-wall fiber cable connects A/V components to an 8K display in your digital signage
application, auditorium or security system.
Features
8K DisplayPort Cable Gets Your Gaming, Home Theater or Digital Signage Setup 8K-Ready
This DisplayPort fiber optic cable (M/M) securely connects DisplayPort-enabled source and display
devices compatible with 8K audio/video signals. Backward compatible with all your existing DisplayPort
devices, including Blu-ray players, game consoles and 4K televisions, the P580F3-20M-8K6 is ideal for
future-proofing your high-definition or UHD A/V application in anticipation of an 8K upgrade.
Fiber Optic Cabling Allows 8K Transmissions Over Longer Distances
The P580F3-20M-8K6 supports DisplayPort 1.4 bandwidths of 32.4 Gbps, allowing for 8K @ 60 Hz
resolutions. Because the cable uses optical fiber instead of copper, it can transmit longer distances with
no latency or loss. It also is largely immune to EMI/RFI line noise that can interfere with your audio/video
signal and disrupt the performance of your connected equipment.
System Requirements
Both source and display devices
must be compatible with 8K
standards to watch 8K video
Package Includes
Enjoy the Clarity of 4K/8K Video with HDR and 4:2:2 Color
The DisplayPort cable supports 8K UHD resolutions up to 7680 x 4320 at 60 Hz, as well as HDR video,
providing a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks. HDCP 2.2
and 1.4 compliance and 4:2:2 chroma subsampling allow you to stream 4K Amazon and Netflix content
with no complications. The cable is backward compatible with 4K and 1080p equipment.
Advanced Fiber Cable Is Easier to Install than Copper
Because the fiber cable is slimmer and more flexible than standard copper cables, the P580F3-20M-8K6
is easier to install around corners and in hard-to-reach spaces behind equipment. It draws power from the
connected device, so no external power supply is needed to transmit the audio/video signal across the
longer distances unique to fiber optic cabling. Note: the cable must be installed in the correct direction to
function properly, so please check the Source and Display labels on the connectors before installation.
Invest in Quality Construction for Reliable Performance
You’re expecting this 8K cable to last a long time, which is why it has been constructed with high-quality
materials. The PVC jacket carries a CL3 rating, making it suitable for in-wall cable installation in residential
or commercial settings. Contacts are gold-plated to provide maximum conductivity and minimum data loss
to guarantee a clear transmission free of interference.
1/4
P580F3-20M-8K6 DisplayPort
Fiber Active Optical Cable, M/M,
Black, 20 m (65 ft.)
Cleveland, OH 44122
United States
20 m (65 ft.) Cable Lets You Design an Audio/Video Application to Your Specifications
This long cable allows you greater flexibility in placing your home theater or digital signage components.
For instance, your laptop or media server may be concealed some distance from the connected display
for security purposes.
Specifications
OVERVIEW
UPC Code
037332259929
Product Type
Technology
DisplayPort
VIDEO
Video Input
DISPLAYPORT (MALE)
Video Output
DISPLAYPORT (MALE)
Max Supported Video Resolution
7680 x 4320 (8K) @ 60Hz
Max 1280 x 720 (720p) Range (ft)
65
Max 1920 x 1080 (1080p) Range (ft)
65
Max 1920 x 1200 Range (ft)
65
Max 2560 x 1600 Range (ft)
65
Max 3840 x 2160 (4K@30Hz)
Range (ft)
65
Max 3840 x 2160 (4K@60Hz)
Range (ft)
65
Max 4096 x 2160 (4K) Range (ft)
65
Max 5120 x 2880 (5K) Range (ft)
65
Max 7680 x 4320 (8K@30Hz)
Range (ft)
65
Max 7680 x 4320 (8K@60Hz)
Range (ft)
65
Signal Range (ft)
65
Signal Range (m)
Max Supported Color Depth
36-bit True Color
HDR Support
Yes
3D Video Supported
Yes
Chroma Sub Sampling
4:2:0; 4:2:2
Maximum Signal Range (ft)
65
Maximum Signal Range (m)
Signal Transmission
Unidirectional
2/4
Cleveland, OH 44122
United States
INPUT
Bus Powered
No
POWER
Power Over Cable (PoC) Support
No
PHYSICAL
Color
Black
Material of Construction
PVC + ZINC ALLOY
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
CL3
Cable Outer Diameter (OD)
4.8 mm
Wire Gauge (AWG)
30
Cable Length (ft.)
65.6
Cable Length (m)
20.00
Cable Length (in.)
780
Ferrite Core
No
Minimum Bend Radius
48mm
Number of Displays
1
Form Factor/Mounting Options
Cable
Shipping Dimensions (hwd / in.)
2.56 x 7.87 x 7.48
Shipping Weight (kg)
0.65
Unit Dimensions (hwd / in.)
2.560 x 7.870 x 7.480
ENVIRONMENTAL
Operating Temperature Range
32° to 113°F (0° to 45°C)
Storage Temperature Range
-40° to 158°F (-40° to 70°C)
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
COMMUNICATIONS
EDID Compatible
No
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
No
3/4
Cleveland, OH 44122
United States
CONNECTIONS
Side A - Connector 1
DISPLAYPORT (MALE)
Side B - Connector 1
DISPLAYPORT (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
Yes
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
Yes
10/100 Ethernet Extension Support
No
MST Support
Yes
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Armored Cable
No
Ethernet Support
No
Displayport Specification
1.4
HDCP Specification
1.4; 2.2
Driver Required
No
STANDARDS & COMPLIANCE
Product Compliance
CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“P580F3-20M-8K6”相匹配的价格&库存,您可以联系我们找货
