1000 Eaton Boulevard
Cleveland, OH 44122
United States
M.2 NGFF SSD (B-Key) to 2.5 in. SATA OpenFrame Housing Adapter
MODEL NUMBER: P960-001-M2-NE
Highlights
Connects 2242, 2260 and 2280
M.2 SATA SSD drives to your
2.5 in. SATA application
Shares data at rapid transfer
speeds up to 6 Gbps (SATA
I/II/III)
Open-frame housing provides
maximum airflow to keep
electronics cool
Works with all major operating
systems, including Windows,
Mac and Linux
Plug-and-play operation with no
software required for easy,
immediate installation
Applications
M.2 SSD to SATA adapter increases performance of your 2.5 in. SATA application when connected to an
M.2 NGFF SATA SSD drive.
System Requirements
SATA host device
B-Key or B+M Key M.2 NGFF
SATA drive
PCle drives not supported
Features
SSD to SATA Adapter Improves Performance of Your SATA ComputerThis adapter converts your
M.2 NGFF SSD drive into a 2.5-inch SATA SSD for use with a standard SATA-enabled computer. The
open-frame P960-001-M2-NE supports mount drive heights of 2242, 2260 and 2280, as well as data
transfer rates up to 6 Gbps. Adding an M.2 NGFF SSD to your application can reduce your computer’s
power consumption and boost performance.
Open-Frame Housing Helps Keep the Intricate Electronic Components CoolThe open frame is
designed for maximum heat dissipation, keeping the adapter cool to boost its performance potential. To
share data, simply connect the SATA drive to the M.2 NGFF connector and then the SATA connector to
your computer’s SATA port.
Just Plug and Play for Immediate Use Right Out of the PackageNo software, drivers or external power
supply is required. Mounting hardware is included. The P960-001-M2-NE is compatible with all major
operating systems, including Windows, Mac and Linux.
Specifications
OVERVIEW
UPC Code
037332242600
Drives Supported
2242, 2260, 2280 M.2 NGFF SSD
Technology
SATA/eSATA
INPUT
Bus Powered
Yes
1/2
Access old data or back up new
data on an M.2 NGFF SSD
using a SATA-enabled computer
Package Includes
P960-001-M2-NE M.2 NGFF
SSD to 2.5 in. SATA OpenFrame Housing Adapter
Mounting hardware
Screwdriver
Owner’s manual
Cleveland, OH 44122
United States
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Yellow (Data & Power)
PHYSICAL
Color
Green
Shipping Dimensions (hwd / in.)
1.10 x 4.80 x 6.10
Unit Dimensions (hwd / in.)
0.280 x 3.920 x 2.760
Unit Weight (lbs.)
0.11
Unit Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
50° to 122°F (10° to 50°C)
Storage Temperature Range
32° to 149°F (0° to 65°C)
Relative Humidity
10% to 80% RH, Non-Condensing
CONNECTIONS
Side A - Connector 1
M.2 NGFF SATA (B-Key)
Side B - Connector 1
22 PIN SATA + POWER (FEMALE)
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
Driver Required
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“P960-001-M2-NE”相匹配的价格&库存,您可以联系我们找货
