1000 Eaton Boulevard
Cleveland, OH 44122
United States
10kW 200-240V 3PH Switched PDU - LX Interface,
Gigabit, 30 Outlets, L15-30P Input, LCD, 3 m
Cord, 0U 1.8 m Height, TAA
MODEL NUMBER: PDU3EVSR10L1530
Highlights
10kW 200-240V 3-phase
switched 1.8-meter 0U PDU
30 individually controllable
outlets—24 C13, 6 C19
Pre-installed GbE-capable
WEBCARDLX with latest
version of PADM20 for IP-based
Auto Probe feature
NEMA L15-30P PDU input with
3 m power cord
Touchscreen LCD with mobile
access option via QR code
Package Includes
10kW L15-30 PDU with multi-function touchscreen LCD distributes, monitors and manages AC power.
Built-in Java-free network interface helps you remotely monitor load levels to prevent overloads that cause
downtime.
Description
The PDU3EVSR10L1530 10kW 3-Phase Switched Power Distribution Unit provides advanced network
control and remote power monitoring with the ability to turn on, turn off, reboot or lock out power to each
outlet. By reducing the frequency of on-site visits, these advanced remote capabilities can save you
money and reduce downtime.
The 0U PDU features 30 switched outlets (24 C13 and 6 C19) with included plug-lock insert sleeves to
prevent cables from becoming accidentally disconnected. A 10-ft. (3.05 m) cord with NEMA L15-30P plug
connects the PDU to a compatible AC power source, generator or protected UPS.
The built-in Java-free HTML5-based LX Platform network interface enables full remote access for PDU
status monitoring and email notifications via secure web browser, SNMP, telnet or SSH. It supports
10/100 Mbps auto-sensing for optimum communication with an Ethernet network. Optional EnviroSense2
modules (sold separately) provide a variety of environmental monitoring capabilities. Protocols supported
include IPv4, IPv6, HTTP, HTTPS, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP and
NTP.
A color touchscreen LCD lets you toggle between menus to monitor input current level per phase, output
current per load bank and per outlet with ±1% billing-grade accuracy, environmental sensor data and
network information. It also generates a unique QR code to allow access to the switchable PDU through a
mobile device.
Features
Distributes, Monitors and Manages Network-Grade AC Power10kW 200-240V switched PDU with 3phase inputRecommended for network applications requiring individual outlet control, load shedding and
remote monitoring of critical network componentsNEMA L15-30P plug with 10-ft. (3.05 m) cord connects
to compatible AC power sourceFirmware upgrades support future product enhancements
30 Switched Outlets Distribute AC Power24 C13 and 6 C19 outlets split into 3 separately breakered
load banksIndividual outlets can be remotely controlled to power up, power down, reboot or lock out
devicesPlug-lock insert sleeves prevent cables from becoming accidentally disconnected
Color Touchscreen LCDReports network data, including IP address, input current level per phase, and
output current per load bank and per outlet with ±1% billing-grade accuracyGenerates unique QR code for
read-only access to PowerAlert® Device Manager via mobile deviceFull access available by logging into
1/4
PDU3EVSR10L1530 10kW 3Phase Switched PDU
Built-in LX Platform interface
Configuration cable
(30) Plug-lock insert sleeves
Rack-mounting hardware
PDUMVROTATEBRKT
mounting bracket accessory
Owner’s manual
Cleveland, OH 44122
United States
PowerAlert Device Manager via browser as user with read/write credentials
Built-In GbE-Capable LX InterfacePre-installed WEBCARDLX with the latest version of PowerAlert
Device Manager firmware (PADM20) provides enhanced remote management capabilitiesPADM20 and
PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large
installations, including firmware update checks and backup and restoration of device configurationsIPbased Auto Probe detects lost connectivity and restores service autonomouslySupports 10/100 Mbps
auto-sensing for communication with an Ethernet networkOptional EnviroSense2 modules (sold
separately) provide a variety of environmental monitoring capabilitiesNo Java required
Broad Communications CompatibilitySupports IPv4, IPv6, HTTP, HTTPS, SMTP, SNMPv1, SNMPv2,
SNMPv3, telnet, SSH, FTP, DHCP and NTPSupports automatic and manual assignment of IP address
Easy 0U Installation in EIA-Standard 19 in. RacksMounts vertically using included toolless buttons or
rack-mounting bracketsIncluded PDUMVROTATEBRKT allows mounting with rear-facing outlets
TAA-CompliantCompliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332209467
PDU Type
Switched
INPUT
Input Phase
3-Phase
PDU Input Voltage
200; 208; 220; 230; 240
Recommended Electrical Service
Three-phase 30A 200-240V service
Maximum Input Amps
24
Maximum Input Amps Details
Agency de-rated to 24A continuous
PDU Plug Type
NEMA L15-30P
Input Cord Length (ft.)
10
Input Cord Length (m)
3.05
OUTPUT
Output Capacity Details
10kW (240V), 9.6kW (230V), 9.1kW (220V), 8.6kW (208V), 8.3kW (200V) total capacity; 13.9A max per breakered
outlet bank; 12A max per C13 outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(24) C13; (6) C19
Output Nominal Voltage
200-240V
Overload Protection
Three 20A circuit breakers, one per output load bank
Customized Load Management
Receptacles
Each outlet is individually controllable via remote interface
2/4
Cleveland, OH 44122
United States
USER INTERFACE, ALERTS & CONTROLS
Reported Load Segments
Reports input current per phase (L1, L2, L3), plus output current for each output load bank (20A balanced max per
banks B1-B3) and individual output receptacle (1-30); Outlets are color-coded and labeled for phase and load bank
identification; L1-L2 feeds light-gray outlets (B1); L2-L3 feeds black outlets (B2); L3-L1 feeds dark-gray outlets (B3)
Front Panel LCD Display
Touchscreen LCD reports NETWORK DATA (IP address, Subnet Mask, Gateway, MAC Address, Device Name,
Model, Serial Number), INPUT PHASE DATA (Amperage, Wattage, Voltage per phase, plus Unbalance
percentage), LOAD BANK DATA (Amperage, Wattage, Voltage per load bank, plus total PDU output in watts),
OUTLET DATA (Amperage, Wattage per outlet), CONFIGURATION DATA (Listing of current configuration settings),
ENVIRONMENTAL DATA (Reports data and status of E2 sensor modules; Sensor options are available for
temperature and humidity, plus input and output dry contacts), MOBILE ACCESS (Generates a unique QR code to
view reported PDU details on a mobile device)
Front Panel LEDs
One LED for each output receptacle offers power availability information: GREEN (Power ON, load bank capacity
80%), RED (Power OFF/undervoltage), RED FLASHING (Power
OFF/breaker trip), LED OFF (Power OFF). Network Activity (Green): Flashes for network activity. Link/Network
Speed (Yellow): On steady for any speed.
Switches
LX Platform Interface: Recessed reset switch for interface reboot and factory reset
Current Measurement Accuracy
(Amps)
+/-1%
Voltage Measurement Accuracy
(Volts)
+/-1%
Power Measurement Accuracy
(Watts)
+/-1%
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
Form Factors Supported
Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
6.89 x 9.65 x 75.87
Shipping Dimensions (hwd / cm)
17.50 x 24.51 x 192.71
Shipping Weight (lbs.)
27.08
Shipping Weight (kg)
12.28
Unit Dimensions (hwd / in.)
70.000 x 2.170 x 2.860
Unit Dimensions (hwd / cm)
177.8 x 5.5 x 7.3
Unit Weight (lbs.)
Unit Weight (kg)
9.07
ENVIRONMENTAL
Operating Temperature Range
32° to 122°F (0° to 50°C)
Storage Temperature Range
-22° to 140°F (-30° to 60°C)
Relative Humidity
5% to 95% non-condensing
3/4
Cleveland, OH 44122
United States
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
COMMUNICATIONS
PowerAlert Software
LX Platform Interface: PowerAlert Device Manager
Communications Cable
USB B-to-USB A Configuration/Console Access cable
Network Monitoring Port
RJ45 Network port, RJ45 Config/Console Access port; 2x USB A ports supports a variety of Envirosense2
environmental and control modules. See Accessories>Management Hardware section for more information about
these modules. USB B port (Configuration & Console Access)
SNMP Compatibility
SNMP V1, V2c, V3
Network Compatibility
10 Mbps; 100 Mbps (Fast Ethernet); 1 Gbps (Gigabit)
Communications Interface
Pre-installed network card; RS-232; USB
FEATURES & SPECIFICATIONS
High Availability PDU Features
Auto Probe Monitoring and Reboot (included); Auto Load Shedding
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1
Product Compliance
RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
