1000 Eaton Boulevard
Cleveland, OH 44122
United States
220-240V 13A Single-Phase Hot-Swap PDU with
Manual Bypass - 4 BS1363 Outlets, C20 &
BS1363 Inputs, Rack/Wall
Highlights
Ideal for supporting critical IT
equipment that require 24/7/365
uptime
Transfers connected
components to utility power with
no downtime during UPS
maintenance
Dual C20 inlets support
connection to separate UPS and
utility input power sources
ECO mode saves power by
shutting down controlled outlet
bank in certain conditions
Mounts into 2U of rack space or
onto wall using included
mounting hardware
MODEL NUMBER: PDUBHV20B
Applications
Bypass PDU maintains continuous power to connected equipment during scheduled UPS maintenance or
replacement.
Set the bypass switch to UPS
during normal operation, so
connected equipment can
receive fulltime conditioned
power
Set the bypass switch to Utility
to bypass the UPS and provide
connected equipment with
unfiltered power during UPS
maintenance or replacement
Enable ECO Switching to save
power by shutting down one
load bank when the device
connected to the master outlet is
powered off or in lowconsumption mode
Features
Bypass PDU Recommended for Maintaining Continuous Power During UPS Maintenance
Keeping mission-critical data center equipment operating at its optimal level often means scheduled
maintenance. But what if you are unable to afford the costly downtime involved in powering down for
regular upkeep? This 220-240V 13A single-phase hot-swap PDU works in conjunction with your UPS
system to keep everything running 24/7/365. It allows you to manually transfer connected equipment to
utility power via the PDU’s bypass switch, permitting maintenance or equipment replacement with no
interruption of performance.
Package Includes
Features Dual Inputs and a Manual Transfer Switch for Uninterrupted Operation
The PDUBHV20B features two C20 inlets that connect to separate UPS and utility input power sources
with user-supplied power cables or the included cables. The manual transfer switch allows PDU output
power to flow from either input. Flip the switch to Bypass to replace the UPS and flip back to Normal once
the maintenance or UPS replacement is complete. Equipment connected to the four BS1363 outlets will
continue to operate without interruption.
Optional ECO Switching Feature Enables Cost-Cutting Power Savings
By enabling the ECO power saving feature, you can power off a single bank of three controlled BS1363
outlets all at once when the device connected to the master BS1363 outlet is powered off or goes into a
low-power consumption mode.
Mounts into 2U of Rack Space or on a Wall
Use the included mounting hardware to install the PDUBHV20B’s all-metal housing inside a 19-inch rack.
Because the PDU’s 56.1-millimeter height is larger than 1U in an EIA-standard rack, you will need to
mount the unit into 2U of space. You may also use the mounting brackets to secure the PDU to a wall.
Specifications
OVERVIEW
1/3
PDUBHV20B 220-240V 13A
(2) C19-to-C20 power cables
C19-to-BS1363 power cable
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
UPC Code
037332253118
PDU Type
Hot-Swap
INPUT
Input Phase
Single-Phase
PDU Input Voltage
220; 230; 240
Recommended Electrical Service
Works with 220-240V UPS systems with C20/BS1363 compatible input cabling
Maximum Input Amps
13
PDU Plug Type
(1) BS1363 13A British; (2) IEC-320 C20
Input Cord Details
Set of 3 power cables included (One 1.8m BS1363 British and Two 1.4m C19-to-C20); Supports user supplied
alternate input cabling
Input Cord Length (ft.)
6
Input Cord Length (m)
1.83
OUTPUT
Output Capacity Details
2.9kW (220V), 3kW (230V), 3.1kW (240V) / Total capacity 13A / 13A Max per outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacle Details
Set of 4 output receptacles are arranged in two groups to support the optional ECO Power-Saving feature; One
MASTER-outlet provides optional current-sense capability that when enabled, automatically powers off the bank of 3
CONTROLLABLE GROUP-outlets when the device connected to the MASTER-outlet is powered off or enters a low
power sleep mode consuming 20W or less (±5W)
Output Receptacles
(4) British BS 1363A
Output Nominal Voltage
220-240V
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Front panel LEDs report UTILITY Input Power ON (green), BYPASS-MODE Switch Setting (yellow), MASTER Outlet
Power ON (green), CONTROLLABLE GROUP Outlets Power ON (green)
Switches
2 position Manual Transfer switch offers Break-Before-Make transfer between UPS and Utility operating modes with
less than 8 milliseconds (typical) transfer time; Additional switch offers ENABLE/DISABLE control of the ECO
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
Form Factors Supported
Includes installation accessories for wall mount and 2U horizontal rackmount installation in 2 or 4 post equipment
racks
PDU Form Factor
Horizontal (2U)
Shipping Dimensions (hwd / in.)
5.50 x 8.00 x 21.40
Shipping Weight (kg)
3.27
2/3
Cleveland, OH 44122
United States
Unit Dimensions (hwd / in.)
2.210 x 17.240 x 3.940
Unit Dimensions (hwd / cm)
5.61 x 43.79 x 10.01
Unit Weight (lbs.)
5.2
Unit Weight (kg)
2.36
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
-22° to 122°F (-30° to 50°C)
Relative Humidity
5% to 95% non-condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
FEATURES & SPECIFICATIONS
High Availability PDU Features
Manual Hot-Swap Bypass
STANDARDS & COMPLIANCE
Product Certifications
IEC 62368-1
Product Compliance
RoHS; EAC (Belarus, Kazakhstan, Russia); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDUBHV20B”相匹配的价格&库存,您可以联系我们找货
