1000 Eaton Boulevard
Cleveland, OH 44122
United States
Highlights
Important Note
UL1363a, Paragraph 14.1(d) States "The SPRPT shall be permanently attached to the medical equipment
by a means such that it is only removable with the use of a tool." To achieve compliance, one must use
the PSCLAMP.
Antimicrobial protection helps
prevent the growth of bacteria,
viruses, fungi, mold and mildew
Approved for use in patient-care
areas when properly mounted
Complies with UL 1363A &
NFPA 99 specifications
Features six NEMA 5-20R-HG
hospital-grade outlets
Features 15 ft. (4.6 m) cord with
NEMA 5-20P-HG hospital-grade
plug
Safe-IT UL 1363A Medical-Grade Power Strip for
Patient-Care Vicinity, 6x 20A Hospital-Grade
Outlets, 15 ft. (4.57 m) Cord
MODEL NUMBER: PS615HG20AOEM
Package Includes
Supplies power to movable plug-connected components mounted to IV poles, mobile carts, crash carts
and mobile medical workstations in operating rooms and patient-care areas.
Description
The PS615HG20AOEM Medical-Grade Power Strip supplies power to movable plug-connected
components mounted to a rack, table or pedestal in operating rooms, patient-care areas, therapy rooms,
imaging environments and administrative areas. Compliant with UL 1363A specifications, this 120V, 50/60
Hz power strip features a NEMA 5-20P-HG hospital-grade plug and six NEMA 5-20R-HG hospital-grade
outlets.
The power strip is protected by a antimicrobial powder coating. Antimicrobial protection helps prevent the
growth of bacteria, viruses, fungi, mold and mildew. The coating meets the requirements of JIS Z
2801:2000, an international standard for evaluating efficacy in antimicrobial products.
Two resettable built-in 20A circuit breakers control power to all outlets and protect the power strip against
overloads. Switchless design prevents the unit from being accidentally shut off. Locking safety covers are
integrated to protect unused outlets from debris and damage.
Long 15-foot (4.6-meter) 20A AC power cord gives you flexibility to roll the equipment where it’s most
needed. Mounting tabs and flanges let you install the PS615HG20AOEM on a wide variety of surfaces,
such as IV poles, mobile carts, crash carts and mobile medical workstations. All-metal housing ensures
safety and is guaranteed to last a long time in demanding environments.
Features
Power Distribution in Any Medical FacilityIdeal for operating rooms, administrative areas, patient-care
areas, therapy rooms and imaging environmentsAttaches easily to IV poles, mobile carts, crash carts and
mobile workstations120V, 50/60 Hz power strip complies with UL 1363A specifications
Exclusive Antimicrobial ProtectionAntimicrobial coating helps resist the growth of bacteria, viruses,
fungi, mold and mildewCoating meets the requirements of JIS Z 2801:2000, an international standard for
1/4
PS615HG20AOEM UL 1363A
Medical-Grade Power Strip with
6 20A Hospital-Grade Outlets
Owner’s Manual with
maintenance requirements
Cleveland, OH 44122
United States
Versatile Medical-Grade SolutionSix NEMA 5-20R-HG hospital-grade outlets provide consistent
powerLong 15 ft. (4.6 m) 20A AC power cord with NEMA 5-20P-HG hospital-grade plug lets you move the
components where power is most neededRugged all-metal housing for long life in demanding
environments
Premium Safety FeaturesDual resettable built-in 20A circuit breakers protect against dangerous
overloadsSwitchless design prevents accidental shutoffIntegrated locking safety covers keep debris away
from unused outlets
Ready to Use Right from the BoxMounting tabs and flanges let you install the unit on a wide variety of
surfaces
Specifications
OVERVIEW
UPC Code
037332190680
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
20A 120V
Input Plug Features
Hospital Grade Plug
Input Cord Gauge Type
12 gauge; SJT
Voltage Compatibility (VAC)
120
Input Plug Type
NEMA 5-20P-HG
Input Cord Length (ft.)
15
Right-Angle Plug
No
Input Cord Length (m)
4.57
Integrated Cord Clip
No
OUTPUT
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(6) 5-20R-HG
Circuit Breaker (amps)
Overload Protection
2 x 20amp breakers (1 line, 1 neutral)
Transformer Accommodation
(2) Yes
Outlet Orientation
Single row of 6
Right-Angle Outlets
No
USER INTERFACE, ALERTS & CONTROLS
Switches
No power switch
2/4
Cleveland, OH 44122
United States
PHYSICAL
Color
White
Material of Construction
Metal
Power Cord Color
White
Form Factors Supported
Housing Color
White
Included Mounting Accessories
Mounting Holes or Slots
Yes
Slot or Hole Mount Measurement
(Center to Center)
Distance between end tabs = 330.20mm
Outlets Measurement (Center to
Center)
1.52 in.
Receptacle Color
White
Shipping Dimensions (hwd / in.)
7.01 x 4.02 x 14.72
Shipping Dimensions (hwd / cm)
17.81 x 10.21 x 37.39
Shipping Weight (lbs.)
4.32
Shipping Weight (kg)
1.96
Unit Dimensions (hwd / in.)
1.500 x 13.750 x 2.500
Unit Dimensions (hwd / cm)
34.93 x 6.35 x 3.81
Unit Weight (lbs.)
2.25
Unit Weight (kg)
1.02
Mounting Details
Includes flanges
FEATURES & SPECIFICATIONS
Rotatable Outlets
No
Antimicrobial
Yes
Built-In Circuit Breaker
Yes
Antibacterial
No
Built-in Cable Management
No
STANDARDS & COMPLIANCE
Product Certifications
UL 1363A
Product Compliance
NFPA 99: 10.2.3.6; RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“PS615HG20AOEM”相匹配的价格&库存,您可以联系我们找货
