1000 Eaton Boulevard
Cleveland, OH 44122
United States
3-Phase 208V UPS + Input Isolation Transformer
Kit - 480V Delta to 208V Wye, 30kVA/kW, External
Batteries Required
Highlights
Recommended for government,
manufacturing, healthcare and
corporate settings
ENERGY STAR 2.0-certified
UPS efficiency up to 98% helps
reduce utility/cooling costs
Unity output power factor (1.0)
allows support of more
equipment without overloading
Optional WEBCARDLXMINI
network card allows costeffective remote management
24/7
Rugged steel housings with
compact footprint come ready
for installation
MODEL NUMBER: S3M30K-30K4T
Applications
Fit transformer, UPS and
batteries in best-in-class
footprint to save space for
revenue-generating equipment
Protect healthcare,
manufacturing, corporate and
other IT equipment where the
upstream power source is 480V
and the load requires a 208V 3phase UPS
Maintain server-room operations
during all power conditions,
including short blackouts
Combines an input transformer with a UPS to provide 480V to 208V step-down and isolation protection
and clean, reliable backup power to support connected loads.
Features
30kVA/kW 3-Phase UPS System and Input Isolation Transformer Combined into One Kit
This SmartOnline® kit for 208V IT loads combines S3M30K 208/220/120/127V Double-Conversion UPS
system and S3MT-30K480V Input Isolation Transformer into one convenient package. The input
transformer connects to the UPS system’s input to provide 3-phase voltage step-down and isolation from
480V (Delta) to 208V (Wye). That clean, reliable 208V backup power passes through the UPS system to
support your critical loads. The S3M30K-30K4T combo kit is ideally suited for vital applications in banking,
education, healthcare, government and manufacturing sectors.
Battery Backup and VFI Operation Protect Critical Loads
The IGBT UPS supports the continuous availability of your most important operational and IT equipment
loads through all power conditions, providing a compact backup power platform that’s easy to manage
and inexpensive to operate. Sophisticated voltage- and frequency-independent (VFI) operation and
advanced IGBT rectifier technology with DSP control deliver reliable output power quality.
Complete Step-Down and Isolation Protection That Prevents Power Disruption
The input transformer offers line isolation and protection to the UPS system and its load. It isolates the
UPS and connected components from line surges and spikes caused by utility power disruptions that can
damage equipment or corrupt data.
Best-in-Class Footprint for Easy Integration into Your Network Application
The compact design lets you install the steel housings in spaces that would otherwise have required
expensive retrofitting. By achieving their condensed size without compromising runtime, reliability or
functionality, this combination UPS/transformer kit is recommended for data centers, colocation facilities
and edge computing environments that require high efficiency, high performance and clean, reliable
power protection, while preserving as much space as possible for revenue-generating server racks.
Efficient UPS Operation and Design Reduces Cost of Ownership
The UPS features ENERGY STAR 2.0-certified technology that provides high operational efficiency to
save on utility and cooling costs, as well as protect the environment. It achieves 94% efficiency in doubleconversion mode and up to 98% in ECO mode, reducing your power and cooling costs. Unity output
power factor (1.0) lets you support more equipment. A low THDi (
很抱歉,暂时无法提供与“S3M30K-30K4T”相匹配的价格&库存,您可以联系我们找货
