1000 Eaton Boulevard
Cleveland, OH 44122
United States
Highlights
Important Note
This is refreshed model, updated with WEBCARDLXE (enables remote configuration and management);
and 48v external battery. Extra runtime is available by connecting up to four optional extended battery
modules BP48VRM2U (sold separately).
Protects equipment against
blackouts, brownouts, transient
surges and line noise
Keeps equipment running during
outages to allow time for file
saves and safe shutdown
Unity power factor ensures
maximum power possible at
each power rating
ENERGY STAR 2.0-certified to
save electricity, lower costs and
protect the environment
2-line front-panel LCD with 10
selectable screens reports
detailed UPS and site power
info
Included WEBCARDLXE
network interface allows 24/7
remote monitor and control
SmartPro 1000VA 1000W 120V Line-Interactive
Sine Wave UPS - 8 Outlets, Extended Run, NIC,
LCD, USB, DB9, 2U Rack/Tower
MODEL NUMBER: SMART1000RMX2UN
Package Includes
Provides complete battery backup and pure sine wave power output for servers, switches and other highend distributed IT equipment.
Features
1kVA/1kW/120V Battery Backup for Distributed IT, Telecom or Enterprise Deployments
This rack-mount line-interactive UPS system provides reliable battery backup and AC power protection
against blackouts, brownouts, surges and line noise that can damage your valuable IT equipment or
destroy data. The SMART1000RMX2UN is ideal power management for high-end in-rack networking
equipment, including servers, VoIP phones, data storage and PoE switches. Unity power factor ensures
the most watts possible at each power rating, so you can connect more equipment.
Reliable, Expandable Battery Backup Keeps You Operational Through Power Outages
The field-replaceable, hot-swappable VRLA battery modules allow you to work through short power
failures and give you enough time to safely save files and shut down your system in case of a prolonged
blackout. Switchover from line to battery power happens within milliseconds to maintain continuous
operation of connected equipment without interruption or rebooting. Extra runtime is available by
connecting up to four optional extended battery modules (BP48VRM2U, sold separately).
Pre-Installed LX Platform Network Management Card Allows Remote Access 24/7
The WEBCARDLXE network interface enables full remote configuration and management, including load
shedding, reboots of connected equipment and safe shutdowns. The IP-based Auto Probe feature
ensures continuous network uptime by communicating with other network devices, detecting lost
connectivity and automatically rebooting IT equipment. Optional EnviroSense2 modules (E2MT, E2MTDO
and E2MTHDI, all sold separately) provide a variety of environmental monitoring and control options.
NEMA 5-15R Outlets Protect Your Connected Components
Eight managed 5-15R outlets provide connected equipment with pure sine wave AC output and allow you
to monitor power consumption down to the outlet group level. Power provided by these outlets is filtered to
1/7
1000VA 1000W 120V LineInteractive UPS
WEBCARDLXE network
management card
USB cable
DB9 cable
Rack-mounting hardware
Tower support stands
Safety instructions
Advanced User Guide
Cleveland, OH 44122
United States
protect connected equipment against damaging surges and line noise. Four outlets are grouped into two
programmable load banks that let you shed non-critical loads to extend runtime for critical loads. Front
and rear cooling fans help protect equipment from overheating.
Automatic Voltage Regulation (AVR) Corrects Low- and High-Voltage Conditions
AVR protects your equipment from incremental hardware damage, data loss and performance problems
caused by brownouts. The SMART1000RMX2UN maintains regulated 120V nominal output during
brownouts and overvoltages from 80V to 151V while keeping the battery fully charged and ready to take
over in case of power failure.
Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform Better
This UPS system filters out disruptive electromagnetic and radio frequency interference that can inflict
hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform
better and last longer.
ENERGY STAR-Certified to Help You Save Money and Protect the Environment
By meeting strict U.S. Department of Energy and U.S. Environmental Protection Agency requirements,
this ENERGY STAR 2.0 UPS system provides high operational efficiency to signal a reduction in BTU
emissions, save on utility and cooling costs and help protect the environment.
Intuitive Front-Panel Interface for Convenient UPS Operation and Monitoring
The two-line front-panel LCD monitoring screen features 10 selectable screens that allow quick access to
a wide range of detailed UPS and site power information. LEDs show UPS status: a green light means
utility power is on, an orange light means the UPS is in battery mode and a red light indicates an active
alarm or fault. The control panel rotates to accommodate both rack-mount and tower configurations.
Advanced Communications Ports Allow for Automatic Saves and Shutdowns
RS-232 and USB ports connect to a device for a variety of communication options (cables are included). A
dry-contact relay port can be programmed through the LCD to provide reliable communications to
automation and industrial components. The RPO/ROO port permits emergency shutdown or remote
restart of all connected equipment.
Versatile Installation Options
You can mount the SMART1000RMX2UN in just 2U of space in an EIA-standard 19-inch rack using the
included hardware. You can also adapt it for tower installation using the included support stands. The 10foot power cord with NEMA 5-15P plug connects to a compatible AC outlet.
Specifications
OVERVIEW
UPC Code
037332256447
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
12A
Nominal Input Voltage(s) Supported
120V AC
Nominal Input Voltage Description
80V-151V; adjustable to 70-153V
UPS Input Connection Type
5-15P
Input Circuit Breakers
15A
2/7
Cleveland, OH 44122
United States
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
Output Capacity (Watts)
1000
Output Capacity (kW)
1
Power Factor
1
Nominal Voltage Details
120v nominal output in battery mode
Frequency Compatibility
50 / 60 Hz
Output Voltage Regulation (Line
Mode)
120V (-13%, +15%)
Output Voltage Regulation (Battery
Mode)
-10%, +6%
Load Management Receptacles
Two switchable two-outlet 5-15R load banks
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(8) 5-15R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
6 min. (1000W)
Runtime Half Load (min.)
17 min. (500W)
Expandable Runtime
Yes
Expandable Battery Runtime
Extended runtime supported via optional BP48VRM2U external battery packs
External Battery Pack Compatibility
BP48VRM2U (limit 4)
DC System Voltage (VDC)
48
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10 to 90% (typical, full load discharge)
Battery Access
Front panel battery access door
3/7
Cleveland, OH 44122
United States
Internal UPS Replacement Battery
Cartridge
Pre-February 2023: RBC93-2U
Post-February 2023: 744-A3296
Battery Replacement Description
Hot-swappable, replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 81 to 150V
(Normal mode) adjustable to 70-153V (Extended mode)
Overvoltage Correction
Reduces incoming voltage between 132-151V by 13% (Normal Mode); 138-152V (Extended mode)
Undervoltage Correction
Boost incoming voltages between 81-102V by 15% (Normal Mode); 71-92V by 15% (Extended Mode)
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Front panel rotatable LCD information and configuration screen offers detailed UPS and site power status and
operating data, plus configuration of voltage, frequency, operating mode, alarm function and a variety of additional
options (see manual for detailed LCD configuration and monitoring options)
Switches
5 pushbutton switches control OFF / ON power status, ENTER, UP, and DOWN selection and ESC control functions
Alarm Cancel Operation
Press the ESC (Escape) button on the front panel display to silence the alarm. Check the alarm condition and
perform the applicable action to resolve the condition. If the alarm status changes, the alarm beeps again, overriding
the previous alarm silencing
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
UPS: 3 status-indicating LEDs (normal, battery mode, alarm/fault); LED colors (green = ON, orange = On battery,
flashing orange = below warning level, red = alarm/fault). LX Platform Interface Status: Network Link/Activity
(Green): Flashes for network activity. Network Speed (Yellow): 10 Mbps (Flashing), 100 Mbps (On steady). Normal
Operation (Solid Green); Software Update (Alternating Green/Orange ~1/sec); Factory Reset (Alternating
Green/Orange ~2/sec).
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
380
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Rackmount; Tower
Rack Height
2U
Cooling Method
Fan
Included Mounting Accessory
Description
Included mounting bracket enables installation in 4 post racks. Two ABS mounting stands enables the UPS to be
configured in an upright tower orientation.
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount; Tower
with Optional Accessories
4 post rackmount short-depth ( 4POSTRAILKITWM );
Wallmount ( 2POSTRMKITWM )
4/7
Cleveland, OH 44122
United States
Minimum Required Rack Depth (cm)
53.34
(inches)
21
Minimum Required Rack Depth with
External Battery Pack (cm)
51
External Battery Pack (in.)
without External Battery Pack (cm)
53
without External Battery Pack (in.)
21
Optional Mounting Accessory Notes
Optional 2POSTRMKITWM enables wall-mount
installation; 4POSTRAILKITWM enables installation in 4-post
short-depth racks from 14.5 to 23.5 inches (368 to 597mm)
Primary UPS Depth (mm)
447
Primary UPS Height (mm)
88
Primary UPS Width (mm)
439
Shipping Dimensions (hwd / in.)
9.40 x 19.60 x 23.00
Shipping Weight (kg)
25.22
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, in.)
3.45 x 17.3 x 17.6
UPS Power Module Weight (kg)
20.20
UPS Power Module Weight (lbs.)
44.53
Unit Dimensions (hwd / in.)
3.400 x 17.200 x 17.600
Unit Weight (lbs.)
44.5
Unit Weight (kg)
20.18
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
20 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
70
AC Mode Efficiency Rating (100%
Load)
96%
Battery Mode Heat Dissipation
(BTU/Hr) @ Full Load
465
Audible Noise
45 dBA maximum, front side 1m
Operating Elevation (m)
0-3,000
5/7
Cleveland, OH 44122
United States
COMMUNICATIONS
Network Management Cards
WEBCARDLXE
Network Monitoring Port Description
Pre-installed WEBCARDLXE supports detailed monitoring and management of UPS and site power conditions. Not
compatible with WEBCARDLX.
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert Office software at
https://tripplite.eaton.com/poweralert
Communications Cable
Micro-USB, USB and DB9 cabling included
RJ45 Network port, Micro-USB Configuration/Console port, USB A port supports a variety of Envirosense2
environmental and control modules. See Accessories>Management Hardware section for more information about
these modules.
SNMP Compatibility
SNMP V1, V2c, V3
Network UPS Tools (NUT)
Compatibility
NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite
Network Compatibility
10 Mbps; 100 Mbps (Fast Ethernet)
Description
Network management card included
Communications Interface
Contact closure; DB9 Serial; EPO (emergency power off); Pre-installed network card; Slot for SNMP/Web interface;
USB (HID enabled)
Emergency Power Off
(EPO)/Remote On-Off (ROO)
Yes
LINE / BATTERY TRANSFER
Transfer Time
1-4ms for normal mode, >5ms for sensitive mode
Low Voltage Transfer to Battery
Power (Setpoint)
80 (adjustable to 70V)
High Voltage Transfer to Battery
Power (Setpoint)
151
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring and Reboot (included); Automatic Voltage Regulation (AVR); Expandable battery backup; Hot
swappable batteries; Remote management; Sine wave output; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS; Individually controllable load banks; Schedulable daily hours of
economy mode operation
Grounding Details
Rear panel grounding lug
APPLICATIONS
UPS Applications
Large Network; High-End Desktop/Small Network
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); EN 62040-2; ICES (Canada); IEC 62040-2; NOM (Mexico); UL 1778
Product Compliance
FCC Part 15 Class A (USA); RoHS
6/7
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
7/7
