1000 Eaton Boulevard
Cleveland, OH 44122
United States
In-Row Cooler for Server Racks - 33,000 BTU (9.7
kW), 208/240V, 42U
MODEL NUMBER: SRCOOL33K
Highlights
33,000 BTU (9.7kW) of cooling
power in self-contained, rowbased, zero-maintenance unit
Needs no costly electrician or
HVAC contractor—can be fully
installed by IT staff
Expels condensation through
exhaust air system—no floor
drain or water collection tank
required
10-ft. (3.05 m) cord with NEMA
L6-30P plug connects to
208/240V outlet
Supports remote management
24/7 via pre-installed
WEBCARDLX network interface
Applications
Self-contained rack cooling system provides up to 33,000 BTU of close-coupled cooling to high-density IT
equipment.
Features
Get Highly Efficient, Reliable Cooling in a 42U Rack Form FactorThe harder your data center, network
closet or server room works, the more it heats up, leading to inefficient operation, weakened performance
and raised cooling costs. To help prevent equipment shutdowns, malfunctions and failures caused by
overheating and temperature fluctuations, the SmartRack® SRCOOL33K provides a close-coupled
cooling solution in a 42U rack form factor that reduces energy use, lowers operating costs and simplifies
installation.
Completely Self-Contained for Simplified and Less Expensive Installation and MaintenanceThe
zero-maintenance SRCOOL33K with its intuitive LCD interface is easy to install and operate. You and
your IT staff can install it yourself. No costly startup service, electrician or HVAC contractor is needed. A
built-in evaporator eliminates condensation through the exhaust air stream, so no costly floor drain, water
collection tank, external condenser, refrigerant piping, ductwork or plumbing is required.
Advanced Network Monitoring Keeps You in Touch 24/7The pre-installed Java-free HTML5-based
WEBCARDLX interface enables full remote monitoring, configuration, control and email notifications via
secure web browser, SNMP, telnet or SSH. It supports 10/100 Mbps auto-sensing for optimum
communication with an Ethernet network.
Energy-Saving Features Meant to Save You MoneyA row-based airflow path maximizes hot-aisle/coldaisle efficiency and cooling predictability by delivering cold air high in the cold aisle and removing hot air in
the hot aisle. The SRCOOL33K promotes temperature uniformity from 1U to 42U, allowing your
equipment to perform at its peak and reduce power consumption and operating costs, and features an
AC-driven rotary compressor.
One-Year Warranty and Environmentally Responsible DesignThe SRCOOL33K comes with a oneyear warranty. It’s manufactured in compliance with strict RoHS specifications and uses eco-friendly
R410a refrigerant.
Specifications
1/3
Primary cooling of high-density
equipment in a small server
room, wiring closet or data
center
Package Includes
SRCOOL33K SmartRack
Energy-Saving, Row-Based
Server Rack Cooling Unit 33,000 BTU, 208/240V
Flexible air ducts
Hot-exhaust removal tube
Unloading ramps
Unpacking guide
Installation manual
Owner’s manual
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332172280
INPUT
Nominal Input Voltage(s) Supported
208V AC; 240V AC
Nominal Input Voltage Description
208-240V AC 60 Hz
Maximum Input Amps
17.9
Input Connection Type
L6-30P Input Cordset
Input Plug Features
Voltage Compatibility (VAC)
208; 240
Input Frequency
60 Hz
Maximum Surge Amps
23
Input Cord Length (ft.)
10
Input Cord Length (m)
3.05
COOLING
Cooling Type
Active
Airflow
1200 CFM
Cooling Capacity (BTUs)
33000
Cooling Capacity (kW)
9.7
Equivalent Room Size
115 sq. m (1,250 sq. ft.)
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Multi-line LCD control panel
PHYSICAL
Color
Black
Material of Construction
Aluminium, Steel
Shipping Dimensions (hwd / in.)
84.40 x 25.60 x 44.90
Shipping Dimensions (hwd / cm)
214.38 x 65.02 x 114.05
Shipping Weight (lbs.)
630.00
Shipping Weight (kg)
285.76
Unit Dimensions (hwd / in.)
78.400 x 23.600 x 42.700
Unit Dimensions (hwd / cm)
199.14 x 59.94 x 108.46
Unit Weight (lbs.)
558.00
Unit Weight (kg)
253.10
2/3
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Refrigerant
R410a (Environmentally friendly, Non ozone depleting)
Refrigerant Amount
2.25 KG
Air Exhaust Tube Length
98 inches
Air Exhaust Tube Diameter
9.84 inches
Compressor Type
Rotary
Dehumidifier
3.35 liters / hour
Sound Level (Noise)
60 dB
Amp Draw Nominal
Variable
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); UL 484
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SRCOOL33K”相匹配的价格&库存,您可以联系我们找货
