1000 Eaton Boulevard
Cleveland, OH 44122
United States
200–240V 5000VA 5000W On-Line UPS, Unity
Power Factor with Bypass PDU, Hardwire
Input/Output, 3U
Highlights
Unity (1.0) power factor
equalizes VA and wattage to
safely support more equipment
Zero transfer time between online and battery modes for
uninterrupted operation
Detachable PDU with
maintenance bypass switch
allows convenient hot-swapping
Pre-installed WEBCARDLXMINI
network interface supports Auto
Probe feature
ENERGY STAR-certified to
save electricity, lower costs and
protect the environment
MODEL NUMBER: SU5KRT3UHWMB
Applications
Double-conversion UPS with detachable PDU and maintenance bypass switch provides fulltime sine wave
output for advanced network applications.
Delivering perfectly regulated
sine wave output to missioncritical equipment
Protecting connected
components from dangerous
surges, spikes and line noise
Keeping equipment operational
through short power failures
Allowing time to save data and
safely shut down components in
case of a prolonged blackout
Features
Protects Mission-Critical Rack-Mounted Equipment against Damage, Downtime and Data
LossTripp Lite's SmartOnline® SU5KRT3UHWMB Unity Power Factor UPS system protects connected
equipment against damage, downtime and data loss due to power outages, voltage fluctuations and
transient surges. Unity Power Factor design enables full 5000VA / 5000W output capacity. In doubleconversion mode, this UPS system maintains perfect output by continuously converting AC input to DC,
then reconverting UPS output to fully regulated sine wave AC with ±1% voltage regulation and zero
transfer time between online and battery modes. Featuring true on-line, double-conversion operation,
Tripp Lite's SU5KRT3UHWMB provides the highest level of UPS power protection for critical server,
network and telecom equipment.
High Availability Configuration Offers Reliable, Expandable Battery BackupIncluded Maintenance
Bypass Switch is mounted on a detachable Bypass PDU that securely mounts to the rear-rails of a 4 post
rack enclosure and remains safely in-place powering your equipment during UPS maintenance. The UPS
connects to the Bypass PDU using a sophisticated blind-mate connector set with self-aligning guide-pins
to ensure safe and reliable whole-UPS replacement with zero downtime for connected equipment. UPS
battery backup keeps connected equipment operational through short power failures, and provides time to
save data and perform an orderly system shutdown in case of a prolonged blackout. The internal battery
set provides 14 minutes of support at half load and 5 minutes at full load. During normal operation,
incoming utility power keeps the battery fully charged so backup power will be available when needed.
Advanced temperature-controlled battery charge management system provides efficient recharge and
enhanced battery lifespan. For mission critical applications demanding continuous uptime, the 6kVA UPS
can provide expandable runtime with optional BP192V12RT3US external battery pack (sold separately).
Battery-independent restart ensures automatic UPS power-up after lengthy power outages, even with
expired batteries.
Economy Mode Helps the Environment and Your Cash FlowOperates with >98% full-load efficiency in
optional economy mode significantly reducing BTU heat output and operating energy costs.
Intuitive Front-Panel Interface offers Convenient MonitoringFront-panel LEDs indicate line power, AC
output, On-battery mode, and Fault conditions. The LCD readout with scroll controls supports visual
monitoring of a variety of control options to support advanced UPS settings and configurations. The panel
1/6
Package Includes
On-line double-conversion UPS
network management card
Detachable bypass PDU
(2) Hardwire strain reliefs
USB cable
RS-232 cable
Rack-mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
rotates for comfortable viewing in rack-mount or tower configuration.
Pre-installed WEBCARDLXMINI Network Interface Offers 24/7 AccessPre-installed Java-free HTML5based WEBCARDLXMINI interface enables full remote access for site power and UPS status monitoring,
configuration, control and email notifications via secure web browser, SNMP, telnet or SSH. It supports
10/100 Mbps auto-sensing for optimum communication with an Ethernet network. Automated alerts help
prevent accidental overloads, power loss and downtime. Advanced Communications Ports USB and DB9
ports with included cabling enable data-saving unattended shutdown of connected systems when used
with Tripp Lite’s free downloadable PowerAlert® software. Capabilities include detailed monitoring of load
levels, self-test data and utility power conditions. DB9 ports also support basic contact-closure monitoring
to report On-battery and Low-battery status for legacy systems.
Versatile Installation OptionsHardware is included for mounting the complete 6kVA UPS system with
internal batteries in 3U of space in an EIA-standard 19-inch 4-post rack. Use the optional
2POSTRMKITHD for 2-post rack mounting or the optional 2-9USTAND for mounting in an upright tower
position.
2-Year Warranty, $250K Ultimate Lifetime Insurance and Environmentally Responsible DesignThe
SU5KRT3UHWMB comes with a 2-year warranty and $250,000 of Ultimate Lifetime Insurance for any
connected components damaged by a power surge (U.S., Canada and Puerto Rico only). It’s
manufactured in compliance with strict RoHS specifications, reflecting Tripp Lite’s commitment to
environmental responsibility.
Specifications
OVERVIEW
UPC Code
037332238009
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
Hardwire AC input: 27A (200V), 25.6A (208V), 24.2A (220V), 21.7A (230V), 22.2A (240V) maximum; Max inrush
current: 100A
Nominal Input Voltage(s) Supported
200V AC; 208V AC; 220V AC; 230V AC; 240V AC
Nominal Input Voltage Description
208V factory default
UPS Input Connection Type
Hardwire
UPS Input Connection Description
Hardwire input supports 3 wire L1, L2/N, PE(GND) input configurations
Input Frequency
50 / 60 Hz
Power Factor (Input)
0.98 minimum (full load, nominal input voltage)
THDi
很抱歉,暂时无法提供与“SU5KRT3UHWMB”相匹配的价格&库存,您可以联系我们找货
