TLP36USB
TLP36USB
    TRIPPLITE
    3-OUTLET SPHERICAL SURGE PROTECT
TLP36USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3-Outlet Spherical Surge Protector, 4 USB Ports (4.8A Shared) - 6 ft. (1.83 m) Cord, 5-15P Plug, 540 Joules, Black Highlights ● 3 NEMA 5-15R outlets for powering a laptop, smartphone or other electronic devices ● 540 joules protect your valuable electronics against dangerous surges and spikes ● 4 USB ports share 4.8A for fast charging of phones, tablets and other mobile devices ● Ball-shaped design takes up little room on your desk and easily packs away for travel MODEL NUMBER: TLP36USB Applications ● Protect a laptop, external hard drive or other valuable electronics against AC power surges and spikes ● Filter potentially damaging line noise to improve connected equipment’s performance and lifespan ● Safeguard valuable data against damage stemming from unexpected surges ● Charge a smartphone and tablet without taking up available AC outlets Portable ball-shaped surge protector with USB charging safeguards your electronics against dangerous surges, spikes and line noise. Features Sphere-Shaped 3-Outlet Surge Protector Safeguards Your Sensitive Electronics Ideal for your home or office workstation or travel use, this Protect It!® three-outlet power ball features a surge suppression rating of 540 joules to defend your sensitive electronic components against even the strongest power surges and spikes. Because residential power outlets have three wires—hot line (H), neutral (N) and ground (G)—the TLP36USB protects all three, covering the two protection modes: full normal mode (H-N) and common mode (N-G/H-G). 3 NEMA 5-15R Outlets Accept a Wide Range of Electronic Devices Plug your laptop, external hard drive, desk lamp or other home/office devices into the NEMA 5-15R outlets to protect them against dangerous surges, spikes and line noise. The outlets are located on different sides to allow easy connection of bulky transformers. 4 USB Ports Share 4.8 Amps of Charging Power USB-A ports are available for charging your smartphone, tablet and other USB mobile devices. They share 4.8A for charging multiple devices at the same time. Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform Better Various electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems. This surge protector filters out disruptive line noise that can disturb your electronics and inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Includes the Latest Safety Features to Maintain Your Equipment’s Well-Being Automatic shutoff permanently cuts power to outlets if the protection circuit is incapacitated, preventing equipment damage and indicating replacement is required. Safety shutters on unused outlets help prevent electrical shock. A green LED confirms your connected equipment is protected. Mounting slots allow installation on any flat surface. Ball-Shaped Design Gives You Plenty of Options for Installation and Use 1/4 Package Includes ● TLP36USB 3-Outlet Surge Protector Ball, Black ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Less than four inches in diameter, the spherical TLP36USB fits easily into your home or office workspace, providing power and USB charging at your fingertips. Its compact design also makes the surge protector ideal for travel, fitting easily into your backpack, laptop bag or suitcase for use in hotels, conference rooms and cruise ships. Specifications OVERVIEW UPC Code 037332260253 Device Compatibility Phone; Tablet INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 6 Right-Angle Plug No Input Cord Length (m) 1.83 OUTPUT Frequency Compatibility 60 Hz Output Receptacles (3) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation No Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Diagnostic LED Details 1 Green LED - Protection CHARGING Number of Charging Ports 4 Total Charging Watts 24 Charging Method USB 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Port Type USB A (FEMALE) Charging Ports / Amps (4) 4.8A Overcharge Protection No SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 540 AC Suppression Response Time < 1ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 500 EMI / RFI Filtering Yes Immunity Conforms to IEE 587/ANSI C62.41 Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Black Mounting Holes or Slots No Receptacle Color Black Unit Dimensions (hwd / in.) 3.590 x 3.560 x 3.320 Unit Dimensions (hwd / cm) 9.1 x 9.0 x 8.4 Unit Weight (lbs.) 1.18 Unit Weight (kg) 0.54 Input Cord Color Black FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No GaN Technology No STANDARDS & COMPLIANCE Product Certifications NOM (Mexico); UL 1449; UL 1363 Product Compliance RoHS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $10,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
TLP36USB 价格&库存
很抱歉,暂时无法提供与“TLP36USB”相匹配的价格&库存,您可以联系我们找货
