TLP38UAM
TLP38UAM
    TRIPPLITE
    SAFE-IT 3-OUTLET SPHERICAL SURGE
TLP38UAM 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Safe-IT 3-Outlet Spherical Surge Protector, 5-15R Outlets, 4 USB Charging Ports, 8 ft. (2.4 m) Cord, Antimicrobial Protection Highlights ● 3 NEMA 5-15R outlets are spaced apart to accommodate bulky transformers ● 540 joules protect your valuable electronics against dangerous surges and spikes ● 4 USB ports share 4.8A for fast charging of phones, tablets and other mobile devices ● Ball shape takes up little room on your conference table and easily packs away for travel ● Antimicrobial protection helps resist the growth of bacteria, viruses, fungi, mold and mildew MODEL NUMBER: TLP38UAM Package Includes Safely charges and powers up to 7 devices, including laptops and tablets, during important workplace meetings and conferences. Features Sphere-Shaped 3-Outlet Surge Protector Safeguards Your Sensitive Electronics Ideal for your home or office workstation or travel use, this Safe-IT™ power ball features a surge suppression rating of 540 joules to defend your sensitive electronic components against even the strongest power surges and spikes. Because residential power outlets have three wires—hot line (H), neutral (N) and ground (G)—the TLP38UAM protects all three, covering the two protection modes: full normal mode (H-N) and common mode (N-G/H-G). NEMA 5-15R Outlets Accept a Wide Range of Electronic Devices Plug your laptops, projector, printer and other conference-table electronics into three NEMA 5-15R outlets to protect them against dangerous surges, spikes and line noise. The outlets offer easy 360-degree access to power and are located on different sides to accept bulky transformers without blocking adjacent outlets. USB Ports Share 4.8 Amps of Charging Power Four USB-A ports are available for charging your smartphones, tablets and other USB mobile devices. They share 4.8A of charging power, which is plenty for delivering ample power to demanding devices. Filtering EMI/RFI Line Noise Helps Your Equipment Perform Better This surge protector filters out disruptive electromagnetic and radio frequency interference that can inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Antimicrobial Protection Helps Provide a Safer, Cleaner and Healthier Work Environment The Safe-IT TLP38UAM features antimicrobial protection that helps resist the growth of bacteria, viruses, fungi, mold and mildew. Premium Safety Features Protect Your Valuable Equipment Automatic shutoff permanently cuts power to outlets if the protection circuit is incapacitated, preventing equipment damage and indicating replacement is required. Safety shutters on unused outlets help prevent electrical shock. A green LED confirms your connected equipment is protected. Mounting slots allow 1/4 ● TLP38UAM 3-Outlet Surge Protector Ball ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States permanent installation on any flat surface. Compact Spherical Design Gives You Plenty of Options for Installation and Use Less than four inches in diameter, the spherical TLP38UAM fits easily into your home or office workspace, providing power and USB charging at your fingertips. Its compact design also makes the surge protector ideal for travel, fitting easily into your backpack, laptop bag or suitcase for use in hotels, conference rooms and cruise ships. Mounting slots allow permanent installation on any flat surface. Specifications OVERVIEW UPC Code 037332265784 Device Compatibility Phone; Tablet INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 8 Right-Angle Plug No Input Cord Length (m) 2.44 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output Receptacles (3) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation No Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Diagnostic LED Details 1 Green LED - Protection CHARGING Number of Charging Ports 4 Total Charging Amps 4.8A 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Total Charging Watts 24 Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports (2) 2.4A Quick Charge Charging Ports Details 2 x USB-A (2.4A) charging ports for iPhones and iPads2 x USB-A (2.4A) charging ports for Android and other devices Charging Ports / Amps (4) 4.8A Overcharge Protection No SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 540 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 500 EMI / RFI Filtering Yes Immunity Conforms to IEE 587/ANSI C62.41 Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Black Mounting Holes or Slots Yes Receptacle Color Black Unit Dimensions (hwd / in.) 3.590 x 3.560 x 3.320 Unit Dimensions (hwd / cm) 9.1 x 9.0 x 8.4 Unit Weight (lbs.) 1.18 Unit Weight (kg) 0.54 Input Cord Color Black Mounting Details Keyhole mounting slots in base FEATURES & SPECIFICATIONS Rotatable Outlets No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Antimicrobial No GaN Technology No STANDARDS & COMPLIANCE Product Certifications UL 1449; UL 1363 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $10,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
TLP38UAM 价格&库存
很抱歉,暂时无法提供与“TLP38UAM”相匹配的价格&库存,您可以联系我们找货
