U223-007-IND-1
U223-007-IND-1
    TRIPPLITE
    7-PORT INDUSTRIAL-GRADE USB 2.0
U223-007-IND-1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 7-Port Industrial-Grade USB 2.0 Hub - 15 kV ESD Immunity, Metal Housing, Wall/DIN Mountable MODEL NUMBER: U223-007-IND-1 Highlights ● Adds barcode scanner, serial device, sensor—up to 7 devices—to your host computer ● Supports USB 2.0 speeds up to 480 Mbps to ensure reliable data transfers ● Industrial-grade metal housing withstands harsh warehouse and factory environments ● ESD protection to ±15 kV cuts potential static damage to your connected peripherals ● USB ports support screw-locked cables to help prevent accidental disconnections Applications ● Connect up to 7 USB devices and peripherals to your computer or laptop ● Add easy-to-access USB ports to computers stored in a cabinet, behind furniture or other hard-to-reach location ● Mount to a wall or DIN rail in a harsh environment, such as a factory, construction site, supply room or warehouse Rugged industrial-grade hub adds 7 USB 2.0 ports to your computer for connecting industrial printers, sensors and other USB devices. Features Industrial-Grade USB 2.0 Hub Adds up to 7 USB Devices to Your ComputerThis USB 2.0 hub with a heavy-duty all-metal housing connects seven USB devices, such as external hard drives, industrial printers, barcode scanners, serial devices and sensors, to your host PC, server or thin client. The durable metal housing withstands harsh physical conditions in industrial and commercial applications, such as factories, construction sites, supply rooms and warehouses. The hub supports USB 2.0 data transfer rates up to 480 Mbps and is backward compatible with USB 1.1 devices. All ports support screw-locked USB 2.0 cable to prevent accidental disconnections. System Requirements ● Compatible with Windows, Mac OS and Linux operating systems ● If using an optional power supply, requires 5V 3A DC unit with 5.5 x 2.1 x 9.5 mm output plug with a positive pin and negative sleeve Protects Your Devices against Electrostatic Discharge (ESD) and OvercurrentMachines on the shop floor can generate electrostatic discharges, wiping out data and damaging sensitive electronics. This seven-port hub includes ESD protection to ±15 kV, reducing potential static damage to your connected peripherals. This feature works in tandem with overcurrent protection to safeguard your connected devices against damage and data loss from power surges. Package Includes Plug-and-Play Hub Offers Flexible Power and Mounting OptionsThe U223-007-IND-1 requires no software to download and install. It can draw power from the connected computer through a USB-A to USB-B cable. However, for best performance, connecting a compatible 5V 3A DC external power supply (not included) is recommended. You can also plug the included 3-wire terminal block into the hub to draw power from a power terminal. A green LED indicates the unit is receiving power. The metal chassis mounts easily to a wall or DIN rail using the included hardware. Specifications OVERVIEW 1/3 ● U223-007-IND-1 7-Port Industrial-Grade USB 2.0 Hub ● 3-pin power terminal block ● USB-A to USB-B cable ● DIN rail-mounting hardware ● Wall-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332253033 Product Type Hub Technology USB 2.0 (High Speed) Host Connector USB A (MALE) VIDEO Extended Mode No Mirror Mode No DATA Data Ports (7) USB A (FEMALE) Data Ports Details (7) USB-A - USB 2.0 INPUT Bus Powered Yes Product Length (in.) 6.22 Product Length (cm.) 15.8 Product Length (ft.) 0.518 Product Length (m) 0.158 POWER DC Barrel Plug OD: 5.5 x 2.1 x 9.5mm, Positive Pin, Negative Sleeve USB Power Delivery (PD) Charging Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (POWER, 1-7) PHYSICAL Color Black Material of Construction Steel (Galvanized Cold Rolled) Included Mounting Accessories Yes Unit Dimensions (hwd / in.) 1.260 x 3.150 x 6.220 Unit Dimensions (hwd / cm) 3.2 x 8.0 x 15.8 Unit Packaging Type Box Unit Weight (lbs.) 0.73 Unit Weight (kg) 0.33 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 32° to 140°F (0° to 60°C) Storage Temperature Range 14° to 176°F (-10° to 80°C) Relative Humidity 5 - 90 % RH, NON-CONDENSING CONNECTIONS Number of Ports 7 Side A - Connector 1 USB B (FEMALE) Side B - Connector 1 (7) USB A (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Over Current Protection Yes USB Hub Ports Yes Number of USB Hub Ports 7 USB Specification USB 2.0 (up to 480 Mbps) STANDARDS & COMPLIANCE TAA Compliant Option N Product Certifications NOM (Mexico) Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U223-007-IND-1 价格&库存
很抱歉,暂时无法提供与“U223-007-IND-1”相匹配的价格&库存,您可以联系我们找货
