1000 Eaton Boulevard
Cleveland, OH 44122
United States
Mini Bluetooth 5.0 (Class 2) USB Adapter
Highlights
Adds fast, reliable Bluetooth 5.0
LE+EDR Class 2 accessibility to
your PC or laptop
Supports data transfer speeds
up to 3 Mbps to a wireless range
up to 165 ft.
Connects up to 7 devices
simultaneously, including
printers, speakers and headsets
Backward compatible with
previous Bluetooth versions,
including 1.1, 1.2, 2.0, 3.0 and
4.0
Built-in security keeps your
pairing, encryption and
authentication info confidential
MODEL NUMBER: U261-001-BT5
System Requirements
Computer with USB-A port
Windows 8, 10 or 11 or Linux
operating system
Connects Bluetooth 5.0 wireless keyboards, mice, headsets, printers, smartphones and tablets to your
computer’s USB-A port.
Package Includes
Features
Add Bluetooth 5.0 Wireless Capability to Your Computer or Laptop
This low-profile Bluetooth 5.0 (Class 2) USB adapter connects to your PC or laptop’s USB-A port to
provide instant Bluetooth wireless capability. Compliant with Bluetooth 5.0 LE+EDR Class 2 standards,
the U261-001-BT5 is ideal for wireless communication between your computer and up to seven Bluetooth
5.0 devices at the same time, including smartphones, tablets, keyboards, mice, headsets and printers.
Broadcasts a Wireless Signal up to 165 ft.
The USB adapter has a wireless range up to 165 feet (50 meters) and supports data transfer speeds up to
3 Mbps. Built-in security measures ensure your pairing, encryption and authentication information remains
private.
Convenient Low-Profile Design Keeps You Connected as Long as You Like
This Bluetooth adapter protrudes less than 3/16 of an inch (about five millimeters) from the USB port, so it
can remain connected while your laptop is inside a sleeve, briefcase or backpack. It’s backward
compatible with previous Bluetooth versions, so you can use the adapter to connect older devices.
Specifications
OVERVIEW
UPC Code
037332272676
Technology
USB 2.0 (High Speed)
INPUT
Bus Powered
Yes
POWER
1/3
U261-001-BT5 Mini Bluetooth
5.0 USB Adapter
Quick Start Guide
Cleveland, OH 44122
United States
Power Consumption (Watts)
0.50
PHYSICAL
Color
Black
Material of Construction
Steel, PVC
Unit Dimensions (hwd / in.)
0.240 x 0.540 x 0.740
Unit Dimensions (hwd / cm)
0.63 x 1.38 x 1.89
Unit Packaging Type
Box
Unit Weight (lbs.)
0.004
Unit Weight (kg)
0.00
ENVIRONMENTAL
Operating Temperature Range
32° to 122°F (0° to 50°C)
Storage Temperature Range
-4° to 158°F (-20° to 70°C)
BTUs
1.2 BTU/Hr
Operating Humidity Range
20% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Signal Range (ft.)
164
Signal Range (m)
50
Bluetooth Class
Class 2
Bluetooth Version
5.0
Modulation Type
GFSK (1MBPS), /4-DQPSK (2MBPS) and 8-DPSK (3MBPS)
Spread Spectrum
Frequency Hopping Spread Spectrum (FHSS)
RF Power Output
3.06dBm, GFSK
CONNECTIONS
Side A - Connector 1
USB A (MALE)
FEATURES & SPECIFICATIONS
USB Specification
USB 2.0 (up to 480 Mbps)
Driver Required
Yes
STANDARDS & COMPLIANCE
Product Compliance
CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE
WARRANTY & SUPPORT
2/3
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“U261-001-BT5”相匹配的价格&库存,您可以联系我们找货
