U328-025-1
U328-025-1
    TRIPPLITE
    USB 3.0(USB 3.1 Gen 1,Superspeed) 缆线 A 公头(2)转 B 公头 25.00'(7.62m) 无屏蔽
U328-025-1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 3.0 SuperSpeed Active Repeater Cable (A to B M/M), 25 ft. (7.6 m) MODEL NUMBER: U328-025-1 Highlights ● Active repeater cable allows placement of devices beyond USB’s standard 5 m limit ● Signal booster centrally located to allow cable run through raceway ● Bus-powered cable provides up to 900mA of power to connected device ● Supports USB 3.2 Gen 1 data transfer rates up to 5 Gbps – 10x faster than USB 2.0 ● Plug-and-play operation with all major operating systems, including Windows and macOS System Requirements Connects a USB-B device, such as a printer or scanner, to a PC or laptop up to 25 ft. away with no latency issues or signal loss. ● USB 3.2 Gen 1 computer port and USB 3.2 Gen 1 connected device required to meet USB 3.2 Gen 1 speeds ● Not for use with Xbox devices Package Includes Features USB Repeater Cable Connects Computers, Printers, Scanners and Other Office Equipment This USB active cable (M/M) connects your computer or laptop's USB-A port to a USB-B device up to 25 feet (7.6 meters) away. Compatible USB-B equipment includes scanners, printers and external storage devices, such as optical drives and hard drive enclosures. The extra length gives you more flexibility in placing devices, even in different rooms, without the expense of extension cables. Built-In Signal Booster Ensures Top USB Performance The bus-powered signal booster supports USB 3.2 Gen 1 data transfer rates up to 5 Gbps with no latency or signal loss. The booster is constructed in the middle to allow the cable to be easily pulled through raceway. The cable is backward compatible with previous USB generations, so you can use it with legacy equipment. 900mA of Power Keeps Your Devices Functioning The U328-025-1 helps deliver up to 900mA to a connected device. Although not required, the additional USB-A connector is provided for applications where power is needed. If your application is not working correctly without power, connect the built-in connector to a USB-A port on your monitor or a USB wall outlet. The plug-and-play U328-025-1 supports all major operating systems, including Windows and macOS. Specifications OVERVIEW UPC Code 037332268662 Technology USB 3.x Cable Type Active 1/3 U328-025-1 USB Active Repeater Cable (M/M), 25 ft. (7.6 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Bus Powered Yes POWER USB Power Delivery (PD) Charging Support No PHYSICAL Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.0mm Cable Length (ft.) 25 Cable Length (m) 7.62 Unit Packaging Type Polybag ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Operating Humidity Range 10% TO 85% RH, Non-Condensing Storage Humidity Range 5% TO 90% RH, Non-Condensing Power Provided to Connected Device(s) 900mA via additional USB-A connector CONNECTIONS Side A - Connector 1 USB B (MALE) Side B - Connector 1 USB A (MALE) Side B - Connector 2 USB A (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight FEATURES & SPECIFICATIONS USB Specification USB 1.1 (up to 12 Mbps); USB 2.0 (up to 480 Mbps); USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U328-025-1 价格&库存
很抱歉,暂时无法提供与“U328-025-1”相匹配的价格&库存,您可以联系我们找货
