1000 Eaton Boulevard
Cleveland, OH 44122
United States
USB 3.2 Gen 2 Active Extension Cable - USB-C to
USB-A (M/F), 10 Gbps, Data Only, 5 m (16.4 ft.)
MODEL NUMBER: U330-05M-C2A-G2
Highlights
Adds 5 meters to your existing
USB connection to provide
flexibility in placing devices
Connects existing USB-A
peripherals to newer laptops or
tablets with USB-C ports
Supports USB 3.2 Gen 2
speeds up to 10 Gbps to ensure
fast data transfers
Provides up to 900mA of power
to connected device without
need for external power
Plug-and-play operation with no
software required for easy,
immediate installation
System Requirements
USB 3.2 Gen 2 computer port and
USB 3.2 Gen 2 connected device
required to meet USB 3.2 Gen 2
speeds
Active 16 ft. extension cord increases the distance between two USB devices, including MacBooks and
Windows laptops, without signal loss.
Package Includes
Features
U330-05M-C2A-G2 USB-C Active
Extension Cable, USB-C to USB-A
(M/F), 5 m (16.4 ft.)
USB Extension Cable Connects Computers, Printers, Modems and Other USB Equipment
This USB-C to USB-A Active Extension Cable (M/F) attaches to your current USB 3.2 Gen 2 cable to
extend it by five meters (16.4 feet). It connects your MacBook Pro, Windows laptop, Chromebook or other
compatible USB-C device to a USB-A webcam, keyboard, printer, portable hard drive, patch panel or
other peripheral. The extra length allows you greater flexibility in placing equipment where most needed.
Built-In Signal Booster for Peak Performance
Just connect the active cable’s USB-C plug to your computer’s USB-C port and the USB-A female
connector to a USB device cable to extend your total connection beyond USB’s natural five-meter limit.
The bus-powered signal booster ensures USB 3.2 Gen 2 data transfer speeds up to 10 Gbps, twice as
fast as USB 3.2 Gen 1, with no signal loss. The cable is backward compatible with previous USB
generations, so you can use it with legacy equipment.
900mA of Proper Power to Keep Devices Functioning
The U330-05M-C2A-G2 works with standard USB 3.2 Gen 2 cables and provides up to 900mA of power
to a connected device.
Specifications
OVERVIEW
UPC Code
037332268686
Technology
USB 3.x
Cable Type
Active
INPUT
1/3
Cleveland, OH 44122
United States
Bus Powered
Yes
POWER
USB Power Delivery (PD) Charging
Support
No
PHYSICAL
Material of Construction
TPE + ABS
Cable Jacket Color
Black
Cable Jacket Material
TPE
Cable Outer Diameter (OD)
4.8MM
Cable Length (ft.)
16.4
Cable Length (m)
5.00
Unit Packaging Type
Polybag
Unit Weight (lbs.)
0.51
Unit Weight (kg)
0.23
ENVIRONMENTAL
Operating Temperature Range
32° to 113°F (0° to 45°C)
Storage Temperature Range
14° to 158°F (-10° to 70°C)
Operating Humidity Range
10% TO 85% RH, Non-Condensing
Storage Humidity Range
5% TO 90% RH, Non-Condensing
Power Provided to Connected
Device(s)
900mA
CONNECTIONS
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
USB A (FEMALE)
Connector Plating
Nickel
Contact Plating
Gold; Nickel
Connector Style
Straight
FEATURES & SPECIFICATIONS
USB Specification
USB 3.2 Gen 2 (Up to 10 Gbps)
Driver Required
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“U330-05M-C2A-G2”相匹配的价格&库存,您可以联系我们找货
