U330-10M-AL
U330-10M-AL
    TRIPPLITE
    USB 3.2 第 1(USB 3.1 第 1,Superspeed(USB 3.0)) 缆线 A 公型至 A 母型 32.81'(10.0m) 无屏蔽
U330-10M-AL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 3.2 Gen 1 Active Extension Repeater Cable (A M/F), Aluminum Housing, 10 m (32.8 ft.) MODEL NUMBER: U330-10M-AL Highlights ● Adds 10 meters to your existing connection to provide flexibility in placing devices ● Increase the extension to 20 meters by daisy-chaining 2 cables together ● Provides up to 120mA of power to connected device without need for external power ● Supports USB 3.2 Gen 1 data transfer rates up to 5 Gbps – 10x faster than USB 2.0 ● Robust aluminum housing provides extra durability for heavy-use applications Applications USB 3.2 Gen 1 active extension cable increases the distance between 2 connected USB-A devices with no latency issues or loss of signal. Features Extension Cable Connects Computers, Printers, Modems and Other USB Equipment This USB-A active extension repeater cable (M/F) attaches to your current USB cable to extend it by 10 meters (32.8 feet). It connects your computer, laptop or other compatible USB device to a USB-A keyboard, printer, portable hard drive, game console or other peripheral. By adding 10 more meters to your connection, you have more flexibility in placing your devices. And by daisy-chaining two U330-10MAL cables, you can extend the USB connection even further – up to 20 meters (65.6 feet). Built-In Signal Booster Ensures Top Performance Just connect the active cable’s male end to your computer’s USB port and the female end to a USB device cable to extend your total connection beyond USB’s natural five-meter (16.4-foot) limit. The buspowered signal booster ensures USB 3.2 Gen 1 data transfer speeds up to 5 Gbps with no signal loss. The cable is backward compatible with previous USB generations, so you can use it with legacy equipment. 120mA of Power Keeps Your Devices Functioning The U330-10M-AL works with standard USB 3.0 cables and supports up to 120mA of power to a connected device. A white LED indicates a successful power connection. For power applications stronger than 120mA, you must connect a compatible DC 5V external power supply (sold separately) with a barrel connector of 3.5 x 1.35 x 10 mm (positive pin, negative sleeve). Premium Construction for Superior Performance A rugged aluminum housing maintains the cable’s integrity in heavy-use applications. Gold-plated connectors and contacts provide maximum conductivity and minimum data loss to guarantee a clear transmission free of interference. The plug-and-play U330-10M-AL supports all major operating systems, including Windows, macOS and Linux. Specifications OVERVIEW 1/3 ● Connect devices like computers, servers and external hard drives in your data center, workspace or home theater ● Extend an existing USB connection up to 10 meters to more easily place a device ● Daisy-chain 2 cables for an extra-long USB connection up to 20 meters System Requirements ● USB 3.0 computer port and USB 3.0 connected devices required to meet USB 3.0 speeds ● External power supply required if connected device needs more than 120mA of power Package Includes U330-10M-AL USB 3.2 Gen 1 Active Extension Repeater Cable (M/F), 10 m (32.8 ft.) 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332262653 Technology USB 3.x Cable Type Active INPUT Voltage Compatibility (VDC) 5V Bus Powered Yes Product Length (in.) 393.7 Product Length (cm.) 1000 Product Length (ft.) 32.8 Product Length (m.) 10 POWER DC Barrel Plug OD: 3.5 x 1.35 x 10mm, Positive Pin, Negative Sleeve USB Power Delivery (PD) Charging Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators White (Connection to PC) PHYSICAL Material of Construction Aluminum, PVC Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.0mm Cable Length (ft.) 32.8 Cable Length (m) 10.00 Cable Length (in.) 393.7 Shipping Dimensions (hwd / in.) 1.00 x 9.00 x 10.75 Shipping Weight (lbs.) 1.30 Unit Packaging Type Polybag Unit Weight (lbs.) 0.51 Unit Weight (kg) 0.23 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Humidity Range 20% TO 80% RH, NON-CONDENSING Storage Humidity Range 20% TO 80% RH, NON-CONDENSING Power Provided to Connected Device(s) Up to 0.12A CONNECTIONS Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 USB 3.0 A (FEMALE) Connector Plating Gold Contact Plating Gold Connector Style Straight PORT EXPANSION Daisy-chainable or Cascadable Y FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U330-10M-AL 价格&库存
很抱歉,暂时无法提供与“U330-10M-AL”相匹配的价格&库存,您可以联系我们找货
