U360-007-INT
U360-007-INT
    TRIPPLITE
    7-PORT USB-A MINI HUB - USB 3.2
U360-007-INT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 7-Port USB-A Mini Hub - USB 3.x (5Gbps), International Plug Adapters MODEL NUMBER: U360-007-INT Highlights ● Accepts up to 7 USB peripherals, turning your computer into a mini workstation ● Supports USB 3.2 Gen 1 speeds up to 5 Gbps to ensure fast data transfer ● 5V/1.5A charging ports quickly charge smartphones and other mobile devices ● Slim housing fits easily into backpack or bag for convenient work-from-anywhere use ● Plug-and-play operation with no software required for immediate connection System Requirements Compatible with USB-enabled operating systems (USB 3.2 Gen 1 port needed to achieve USB 3.2 Gen 1 speeds) USB 3.2 Gen 1 portable hub adds 7 USB-A ports to your PC, laptop, Chromebook, tablet or other USBenabled device. Package Includes ● U360-007-INT 7-Port USB-A Mini Hub ● USB-B to USB-A cable, 3 ft. (0.9 m) ● External power supply (Input: 100–240V, 50/60 Hz, 1.5A; Output: 12V 3A) ● (3) International plug adapters (U.K., Europe, Australia) Features USB-A Hub Connects 7 USB Peripherals to Your Computer, Laptop or Tablet This USB mini hub connects up to seven USB peripherals to your computer, laptop, Ultrabook, Chromebook, tablet or other device with a USB-A port. It expands the potential of your device by connecting peripherals that can help you do your job faster, easier and better, such as flash drives, printers, barcode scanners, webcams, keyboards/mice, power meters and external hard drives for uploading and downloading important files. Transfers Data at Fast USB 3.2 Gen 1 Speeds All seven USB ports transfer images, video and other data at speeds up to 5 Gbps, which is 10 times faster than USB 2.0. The USB ports are backward compatible with previous USB generations, so you can continue using older peripherals while getting high-speed performance from new devices. Ideal for Charging Multiple Mobile Devices The included external power supply provides 12V 3A to be shared among all seven USB ports. Each port is capable of providing up to 1.5A for fast charging of your phone, tablet, music player and other mobile devices (2.4A for Apple devices). A white LED lets you know the hub is connected and ready. Ready to Use Right Out of the Package The plug-and-play USB hub connects to your computer via the included USB cable, saving you the expense and effort of buying extra cables. It requires no drivers or other software. The included power supply comes with international plug adapters that allow you to connect to almost any AC outlet. The slim housing fits easily into a pocket, briefcase or laptop bag, so you can set up your workstation anywhere. Specifications OVERVIEW UPC Code 037332272058 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Type Hub Technology USB 3.x Host Connector USB A (MALE) VIDEO Extended Mode No Mirror Mode No DATA Data Ports (7) USB A (FEMALE) Data Ports Details (7) USB-A - USB 3.2 Gen 1 (5 Gbps) INPUT AC Power Adapter Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.5A AC Power Adapter Output Specs (V / A) 12V / 3A AC Power Adapter Cord Length (ft.) 5 AC Power Adapter Cord Length (m) 1.5 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered No Product Length (in.) 6.102 Product Length (cm.) 15.5 Product Length (ft.) 0.508 Product Length (m) 0.155 BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Source Type AC Adapter AC Adapter Input: 100-240V, 50/60Hz, 1.5A; Output: 12V, 3A, 5 ft. DC Barrel Plug OD: 5.5 x 2.5 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 1.40 USB Power Delivery (PD) Charging Support No USER INTERFACE, ALERTS & CONTROLS 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States LED Indicators Blue (Power) White (Connection) CHARGING Charging Ports USB-A: 5V 1.5A (7.5W); 2.4A Quick Charge Charging Ports Details BC 1.2 Specification provides 1.5A to connected devices and 2.4A for Apple devices Charging Ports / Amps 1.5A; 2.4A PHYSICAL Color Black Material of Construction ABS Unit Dimensions (hwd / in.) 0.870 x 6.100 x 2.000 Unit Dimensions (hwd / cm) 2.2 x 15.5 x 5.1 Unit Packaging Type Box Unit Weight (lbs.) 0.22 Unit Weight (kg) 0.10 ENVIRONMENTAL Operating Temperature Range 28.4° to 125.6°F (-2° to 52°C) Storage Temperature Range -4° to 132.8°F (-20° to 56°C) Relative Humidity 5 to 95% RH, Non-Condensing BTUs 4.8 BTU/Hr Power Provided to Connected Device(s) 5V 0.9A (4.5W) Output (USB-A 3.0), 5V 2A (10W) Output (USB 2A Charger) CONNECTIONS Number of Ports 7 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 (7) USB 3.0 A (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Over Current Protection Yes USB Hub Ports Yes Number of USB Hub Ports 7 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Driver Required No STANDARDS & COMPLIANCE 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States TAA Compliant Option N External Power Supply Certifications C-Tick; CCC; CE; DOE; GS; TUV; UL; WEEE; cUL Product Compliance RoHS; CE (Europe); REACH; WEEE; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U360-007-INT 价格&库存
很抱歉,暂时无法提供与“U360-007-INT”相匹配的价格&库存,您可以联系我们找货
