1000 Eaton Boulevard
Cleveland, OH 44122
United States
USB-C Cable (M/M) - USB 3.2 Gen 1 (5 Gbps),
Thunderbolt 3 Compatible, Right-Angle Plug, 1 m
(3.3 ft.)
Highlights
Power Delivery cable supports
20V 3A (60W) power output for
charging host device
Supports USB 3.2 Gen 1
speeds up to 5 Gbps to ensure
fast data transfers
Reversible USB-C plugs
connect in either direction for
immediate no-fuss use
Space-saving right-angle USB-C
plug allows easy connection in
confined spaces
USB-C to USB-C cable is
compatible with all USB-C and
Thunderbolt 3 devices
MODEL NUMBER: U420-01M-RA
Applications
Charge and power your
MacBook Pro, Windows laptop
or other USB-C or Thunderbolt 3
device from a USB-C wall
charger
Transfer data between an
external hard drive and your
laptop or PC
Connect your laptop to a
docking station or hub with a
USB-C or Thunderbolt 3 port
USB cable with right-angle plug connects a smartphone or other USB-C device to the USB-C port on your
computer, charger or power bank.
Features
USB-C Cable Connects Devices for Charging or Transferring Data at 5 Gbps Speeds
This USB cable (M/M) is compatible with any device with a USB-C or Thunderbolt 3 port, including
MacBook Pros, Chromebooks and Windows laptops. It allows you to connect your notebook computer to
a docking station, your Apple or Android device to a wall charger or power bank, or an external hard drive
to a PC or tablet, to name just a few valuable uses for the cable. It supports USB 3.2 Gen 1 data transfer
speeds up to 5 Gbps, which is 10 times faster than USB 2.0.
PD Charging Cable Supports up to 60W for Syncing and Charging Mobile Devices
The Power Delivery cable provides power output up to 20V 3A (60W), which is sufficient for fast charging,
syncing and powering most smartphones and other mobile devices.
Right-Angle Plug Makes Connecting in Tight Spaces Easier
A space-saving right-angle USB-C connector is easy to install in confined spaces, such as behind your
computer or workstation. The right-angle construction also helps relieve strain on the cable and connector
and prevents the cable from bending awkwardly.
Reversible USB-C Connectors Attach in Either Direction
Unlike traditional USB cables that connect in only one direction, the reversible USB-C male connectors
plug into a USB-C or Thunderbolt 3 port in either direction for an instant connection every time.
Specifications
OVERVIEW
UPC Code
037332263643
Technology
Thunderbolt; USB 3.x
1/3
System Requirements
Devices with USB-C or
Thunderbolt 3 ports (USB 3.2 Gen
1 compatibility required to achieve
USB 3.2 Gen 1 speeds)
Package Includes
U420-01M-RA USB-C to USB-C
Cable, M/M, Black, 1 m (3.3 ft.)
Cleveland, OH 44122
United States
Cable Type
Passive
INPUT
Maximum Input Amps
3
Maximum Input Watts
60
POWER
USB Power Delivery (PD) Charging
Support
Yes
PHYSICAL
Material of Construction
PVC
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
4.5MM
Cable Length (ft.)
3.3
Cable Length (m)
1.01
Cable Length (in.)
39.4
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Weight (kg)
0.03
Unit Packaging Type
Polybag
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
-4° to 158°F (-20° to 70°C)
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
Power Provided to Connected
Device(s)
60W (20V/3A)
CONNECTIONS
Side A - Connector 1
USB C (MALE) - RIGHT ANGLE
Side B - Connector 1
USB C (MALE)
Connector Plating
Nickel
Contact Plating
Gold
Connector Style
Angled
FEATURES & SPECIFICATIONS
2/3
Cleveland, OH 44122
United States
USB Specification
USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps)
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“U420-01M-RA”相匹配的价格&库存,您可以联系我们找货
