U420F-15M-V
U420F-15M-V
    TRIPPLITE
    缆线 C 公型至 C 公型 49.21'(15.00m) 无屏蔽
U420F-15M-V 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C to USB-C Plenum-Rated Fiber Active Optical Cable (AOC) - 4K 60 Hz, HDR, 4:4:4, M/M, Black, 15 m (49 ft.) Highlights ● Supports UHD resolutions up to 4K @ 60 Hz (4:4:4) for crystalclear video ● 15 m (49 ft.) length allows flexibility in placing source and display devices where needed ● Supports High Dynamic Range (HDR) for richer contrast and expanded color accuracy ● Plenum rated for horizontal premise applications in air ducts and drop ceilings ● Fiber optic construction ideal for long-distance connections not supported by copper MODEL NUMBER: U420F-15M-V Package Includes U420F-15M-V USB-C to USB-C Fiber Active Optical Cable, M/M, Black, 15 m (49 ft.) In-wall fiber cable connects A/V components to a 4K display in your digital signage application, auditorium, home theater or security system. Features 4K USB-C Cable Connects Home Theater, Office and Digital Signage Components This USB Type-C to USB Type-C fiber optic cable (M/M) securely connects the USB-C or Thunderbolt 3 port on your MacBook, Windows laptop or other compatible device to an HDTV, monitor or projector with a USB-C input. Because the cable uses optical fiber, it can transmit audio/video signals longer distances with no latency or loss. Supports USB-C DisplayPort Alternate Mode for Converting Audio/Video Signals By connecting the USB-C end to a source device that supports USB DisplayPort Alt Mode, you can output 4K video and digital audio to a USB-C monitor, television or projector without installing special software drivers. Transmits Crystal-Clear 4K Video with HDR and 4:4:4 Color The U420F-15M-V supports Ultra HD resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz, as well as HDR video, providing a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks that pop on your 4K display. HDCP 2.2 compliance allows you to stream 4K Amazon and Netflix content with no complications. This cable also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Note: To enhance the video experience, the connected displays must have the latest drivers/firmware. See your display's manual or visit the display's official website for the latest drivers/firmware. Advanced Fiber Cable Is Easier to Install than Copper Because the fiber cable is slimmer and more flexible than standard copper cables, the U420F-15M-V is easier to install around corners and in hard-to-reach spaces behind equipment. It draws power from the connected device, so no external power supply is needed to transmit the audio/video signal across the longer distances unique to fiber optic cabling. Note: The cable must be installed in the correct direction to function properly, so please check the Source and Display labels on the connectors before installation. CMP Jacket Designed for In-Wall Installations The plenum-rated jacket has low smoke and flame characteristics, making it suitable for premise applications in ceilings, walls and ducts. 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States 15 m Cable Lets You Design an Audio/Video Application to Your Specifications This long cable allows you greater flexibility in placing your home theater or digital signage components. For instance, your laptop or media server may be concealed some distance from the connected display for security purposes. Specifications OVERVIEW UPC Code 037332275097 Technology USB 3.x Cable Type Active VIDEO Resolutions Supported 3840 x 2160 @ 60Hz Max Supported Video Resolution 3840 x 2160 @ 60Hz Max Supported Color Depth 24-bit True Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes DisplayPort Alt Mode Yes AUDIO Audio Specification DOLBY MAT AND DOLBY DTS HD INPUT Bus Powered Yes POWER USB Power Delivery (PD) Charging Support No PHYSICAL Material of Construction PVC (Plenum-Rated Cable) + Zinc Alloy (Connector Ends) Cable Jacket Color Black Connector Color Light Gray Cable Jacket Material PVC Cable Jacket Rating CMP Cable Outer Diameter (OD) 4.5 mm 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (ft.) 49.2 Cable Length (m) 15.00 Cable Length (in.) 590.5 Unit Dimensions (hwd / in.) 1.540 x 9.250 x 8.860 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range 32° to 122°F (0° to 50°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Relative Humidity 10% TO 80% RH, Non-Condensing Operating Humidity Range 10% TO 80% RH, Non-Condensing Storage Humidity Range 10% TO 80% RH, Non-Condensing COMMUNICATIONS Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 USB C (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No Displayport Specification 1.2 HDCP Specification 1.4; 2.2 Driver Required No STANDARDS & COMPLIANCE Product Certifications CAN/CSA C22.2; EN 55032; ICES (Canada); UL Listed Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U420F-15M-V 价格&库存
很抱歉,暂时无法提供与“U420F-15M-V”相匹配的价格&库存,您可以联系我们找货
