U460-002-2AM-C1
U460-002-2AM-C1
    TRIPPLITE
    USB-C MULTIPORT ADAPTER, 2X USB-
U460-002-2AM-C1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Multiport Adapter, USB 3.x (5Gbps), USBA/C Hub Ports, Card Reader, Silver MODEL NUMBER: U460-002-2AM-C1 Highlights ● USB-C 3.1 hub is compatible with all USB-C and Thunderbolt 3 devices ● Connects external hard drives, keyboard, printer and other USB peripherals ● Supports USB 3.1 Gen 1 speeds up to 5 Gbps to ensure fast data transfers ● Reversible USB-C plug connects in either direction for immediate no-fuss use ● Plug-and-play operation with no software required for easy, immediate installation Applications Adds USB-A and USB-C ports and memory card slots to the USB-C or Thunderbolt 3 port on your MacBook, Chromebook, tablet or notebook. ● Connect up to 3 USB peripherals, such as an external hard drive, flash drive and keyboard/mouse ● Transfer photos, videos and other important files between your MacBook or Chromebook and a memory card Features USB-C/Thunderbolt 3 Hub Connects USB Peripherals to Your Laptop or TabletThis USB-C hub allows you to connect up to three USB peripherals to your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. This lets you expand the potential of your device by connecting USB peripherals, such as an external hard drives, flash drives, power meters and printers. USB Ports Transfer Data from Peripheral to Device at Fast USB 3.1 Gen 1 SpeedsBoth USB-A ports and the USB-C port transfers data at speeds up to 5 Gbps, which is 10 times faster than USB 2.0. The USB ports are backward compatible with previous USB generations, so you can continue using older peripherals while getting high-speed performance from new devices.Note: Host must support USB OTG (On-the-Go)Dual Memory Card Slots Are Ideal for Moving Large Files You can also insert memory cards into their corresponding slots to transfer data at USB 2.0 speeds up to 480 Mbps. The memory card readers support MicroSD and SD/MMC cards for convenient access to digital photos, camcorder videos, smartphone data and other essential files. Both memory card slots can be used simultaneously for maximum access to external storage. Built-In USB-C Cable Connects in Either DirectionConnect the reversible USB-C plug to your source device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. Ready to Use Right Out of the PackageThe plug-and-play USB Type-C hub is specifically designed for use with the MacBook, Google Chromebook Pixel and other laptops, tablets and devices equipped with a USB-C or Thunderbolt 3 port. It requires no software, drivers or external power. The aluminum housing is about the size of a credit card to make it easy to carry in a pocket, backpack or laptop bag for use anywhere. Specifications OVERVIEW 1/4 System Requirements ● Device with USB-C or Thunderbolt 3 port (USB 3.1 port needed to achieve USB 3.1 speeds) Package Includes ● U460-002-2AM-C1 USB 3.1 Gen 1 USB-C Portable Hub/Adapter ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332218353 Product Type Multiport Adapter Technology USB 3.x Host Connector USB C (MALE) VIDEO Number of Monitors Supported 1 Extended Mode No Mirror Mode No DATA Data Ports (2) USB A (FEMALE); USB C (FEMALE) Data Ports Details (2) USB-A - USB 3.2 Gen 1 (5 Gbps); USB-C - USB 3.2 Gen 1 (5 Gbps) STORAGE Card Slots SD (FEMALE); MICRO SD (FEMALE) Card Slots Details SD 3.0 Memory Card slots (SD and MicroSD) - both can be used simultaneously INPUT Built-In Cable Length (in.) 5.91 Built-In Cable Length (cm) 15 Bus Powered Yes Product Length (in.) 4.49 Product Length (cm.) 11.35 Product Length (ft.) 0.372 Product Length (m) 0.113 BATTERY Battery Charging (5V/1.5A Port) No USER INTERFACE, ALERTS & CONTROLS LED Indicators White (Connection) PHYSICAL Color Silver Material of Construction Aluminum Cable Jacket Material PVC Cable Outer Diameter (OD) 4.5 +/- 0.15 mm 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Wire Gauge (AWG) 24/30 Housing Color Silver Included Mounting Accessories No Unit Dimensions (hwd / in.) 0.530 x 1.310 x 4.470 Unit Packaging Type Box Unit Weight (lbs.) 0.154 Unit Weight (kg) 0.07 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -14° to 140°F (-10° to 60°C) Relative Humidity 0 ~ 90% RH CONNECTIONS Number of Ports 5 Side A - Connector 1 USB C (MALE) Side B - Connector 1 (2) USB 3.0 A (FEMALE) Side B - Connector 2 MICRO SD (FEMALE) Side B - Connector 3 SD (FEMALE) Side B - Connector 4 USB C (FEMALE) FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 3 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Data Transfer Rate 5 Gbps SD Card Specification Micro SD; SD Driver Required No STANDARDS & COMPLIANCE TAA Compliant Option N Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U460-002-2AM-C1 价格&库存
很抱歉,暂时无法提供与“U460-002-2AM-C1”相匹配的价格&库存,您可以联系我们找货
