1000 Eaton Boulevard
Cleveland, OH 44122
United States
Industrial 4-Port USB-C Hub - USB 3.x Gen 2
(10Gbps), 2x USB-A & 2x USB-C Ports, 15 kV
ESD Immunity
Highlights
Adds barcode scanner, serial
device, sensor—up to 4
devices—to your host computer
Supports USB 3.2 Gen 2 rates
up to 10 Gbps to ensure
lightning-fast data transfers
Rugged metal housing designed
to withstand harsh warehouse
and factory environments
ESD protection to ±15 kV cuts
potential static damage to your
connected peripherals
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: U460-2A2C-IND
Applications
Rugged industrial hub adds 2 USB-C and 2 USB-A ports to your computer for connecting industrial
printers, sensors and other USB devices.
Connect up to 4 USB devices
and peripherals to your
computer or laptop
Add easy-to-access USB ports
to computers stored in a
cabinet, behind furniture or other
hard-to-reach location
Mount to a wall or DIN rail in a
harsh environment, such as a
factory, construction site, supply
room or warehouse
Features
Industrial-Grade USB 3.2 Gen 2 Hub Adds up to 4 USB Devices to Your ComputerThis USB 3.2 Gen
2 hub with a heavy-duty all-metal housing connects as many as four USB devices, such as external hard
drives, industrial printers, barcode scanners, serial devices and sensors, to your host computer. The
durable metal housing withstands harsh physical conditions in industrial and commercial applications,
such as factories, construction sites, supply rooms and warehouses. Note: Host must support USB OTG
(On-the-Go).
Transfers Data at Lightning-Fast USB 3.2 Gen 2 Speeds and Charges Mobile DevicesAll four
downstream USB ports transfer data at speeds up to 10 Gbps, which is twice as fast as USB 3.2 Gen 1. In
addition to accepting USB peripherals, the two USB-C and two USB-A ports provide up to 0.9 amps each
for charging and powering mobile devices simultaneously. Because the ports are BC 1.2-compliant, they
can deliver up to 2 amps of fast-charging power to mobile devices (when connected to power).
USB-C Ports Help Prevent Your Devices from Becoming DisconnectedEquipment vibrations in
industrial environments can loosen cable connections over time. This hub’s USB-C ports, including the
host port, support USB cables with locking connectors that can prevent devices and peripherals from
accidentally coming loose. All USB-C and USB-A ports are backward compatible with previous USB
generations, so you can continue using older peripherals while getting high-speed performance from new
devices.
Protects Your Devices against Electrostatic Discharge (ESD) and OvercurrentMachines on the shop
floor can generate electrostatic discharges, wiping out data and damaging sensitive electronics. This fourport hub includes ESD protection to ±15 kV, reducing potential static damage to your connected
peripherals. This feature works in tandem with ±2.5kV-per-port overcurrent protection to safeguard your
connected devices against damage and data loss from power surges.
Reversible USB-C Cable Connects in Either DirectionConnect the included two-foot USB-C cable
between your source device’s USB-C or Thunderbolt 3 port and the hub’s host port. The fumble-free USBC plugs connect in either direction to ensure fast, easy connection every time.
1/4
System Requirements
Compatible with all USBenabled operating systems
(USB 3.2 Gen 2 port needed to
achieve USB 3.2 Gen 2 speeds)
Package Includes
4-Port Industrial-Grade USB 3.2
Gen 2 Hub
USB 3.2 Gen 2 Type-C cable, 2
ft.
2-wire terminal block
External power supply (Input:
100–240V, 50/60 Hz, 0.6A;
Output: 5V 4A)
(4) International plug adapters
(North America, Europe, U.K.,
Australia)
Owner’s manual
Cleveland, OH 44122
United States
Plug-and-Play Hub Offers Flexible Power and Mounting OptionsThe U460-2A2C-IND requires no
software or drivers to download and install. You can power the unit by connecting the included power
adapter to a standard AC outlet, or you can use the included 2-wire terminal block to draw power from a
power terminal. The hub mounts easily to a wall or other flat surface using the built-in brackets and usersupplied hardware.
TAA-Compliant for GSA Schedule PurchasesThe U460-2A2C-IND is compliant with the Federal Trade
Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and
other federal procurement contracts.
Specifications
OVERVIEW
UPC Code
037332236319
Product Type
Hub
Technology
USB 3.x
Host Connector
USB C (MALE)
VIDEO
Number of Monitors Supported
Extended Mode
No
Mirror Mode
No
DATA
Data Ports
(2) USB A (FEMALE); (2) USB C (FEMALE)
Data Ports Details
(2) USB-A - USB 3.2 Gen 2 (10 Gbps); (2) USB-C - USB 3.2 Gen 2 (10 Gbps)
INPUT
AC Power Adapter Plug(s)
AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America
AC Power Adapter Input Specs (V /
Hz / A)
100-240V / 50/60Hz / 0.6A
AC Power Adapter Output Specs (V
/ A)
5V / 4A
AC Power Adapter Cord Length (ft.)
3
AC Power Adapter Cord Length (m)
0.08
Voltage Compatibility (VAC)
100; 110; 120; 125; 127; 200; 208; 220; 230; 240
Input Frequency
0.6A
Input Current
100-240V
Bus Powered
No
Product Length (in.)
6
Product Length (cm.)
15.24
2/4
Cleveland, OH 44122
United States
Product Length (ft.)
0.5
Product Length (m)
0.15
BATTERY
Battery Charging (5V/1.5A Port)
No
POWER
Power Source Type
AC Adapter
AC Adapter
Input: 100–240V, 50/60 Hz, 0.6A; Output: 5V 4A
DC Barrel Plug
OD: 5.5 x 2.1 x 11mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
1.75
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
x1 Power (Blue) and x4 device activity (Green)
CHARGING
Charging Ports / Amps
(4) 2A
PHYSICAL
Color
Black
Material of Construction
Steel
Included Mounting Accessories
Yes
Shipping Dimensions (hwd / in.)
2.48 x 9.06 x 7.80
Shipping Weight (lbs.)
1.32
Unit Dimensions (hwd / in.)
1.000 x 4.200 x 2.500
Unit Dimensions (hwd / cm)
2,5 x 10,7 x 6,4
Unit Packaging Type
Box
Unit Weight (lbs.)
0.50
Unit Weight (kg)
0.23
ENVIRONMENTAL
Operating Temperature Range
32° to 122°F (0° to 50°C)
Storage Temperature Range
14° to 176°F (-10° to 80°C)
Relative Humidity
0% to 90% RH, Non-Condensing
BTUs
5.9675
Power Provided to Connected
Device(s)
900mA
ESD Protection
+/- 15 KV
3/4
Cleveland, OH 44122
United States
EFT Protection
+/- 2.5KV
CONNECTIONS
Number of Ports
4
Side A - Connector 1
USB C (FEMALE)
Side B - Connector 1
(2) USB 3.0 A (FEMALE)
Side B - Connector 2
(2) USB C (FEMALE)
Connector Plating
Nickel
Contact Plating
Nickel
FEATURES & SPECIFICATIONS
Over Current Protection
Yes
USB Hub Ports
Yes
Number of USB Hub Ports
5
USB Specification
USB 3.2 Gen 2 (Up to 10 Gbps)
UASP Support
Yes
Auto MDIX Support
No
Full Duplex Support
No
Suspend Mode Support
No
Remote Wakeup Support
No
Driver Required
No
STANDARDS & COMPLIANCE
TAA Compliant Option
Y
External Power Supply Certifications
CB; FCC; GS; PSE; TUV; UL; cUL
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
