15334.2
    CONTA-CLIP
    RELAY, ENCAPSULATED DESIGN
15334.2 数据手册
Data sheet 15334.2 PRS 2/48V DC Plug-in miniature power relay, Encapsulated design with power contact, 2 CO contacts, Input voltage: 48 VAC Business data Article number 15334.2 Article name PRS 2/48V DC GTIN (EAN) 4044211047160 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 12.9 g Weight per piece (including packaging) 14.72 g Unit of weight G Customs number 85364900 Country of origin AT Product description Relay, encapsulated construction Creation date 16.12.2023 20:25:44 Subject to technical changes 1 Data sheet 15334.2 PRS 2/48V DC Technical data Dimensions Length 29 mm Width 12.7 mm Height 15.7 mm Ratings Overvoltage category III Contamination degree 3 (250 VAC) / 2 (400 VAC) Input data Working voltage >33,6 VDC - Drop-out voltage 4,8 VDC Coil voltage 48 VDC - Power consumption 0,417 W Coil resistance 5520 Ohm Output data Switching voltage / switching voltage max. 250 / 400 VAC Continuous current max. / Inrush current max. 8 / 15 A Contact configuration 2 CO contacts Switching capacity, max. 2000 VA Electrical lifespan (AC1) 1x10⁵ Mechanical lifespan 30x10⁶ Bounce time at close of the NO/NC contact 8/6 ms Materials Contact material AgNi 90/10 Working temperature, min. -40 °C Working temperature, max. 70 °C Further technical data Degree of protection RTII Insulation voltage coil/contact 5 kV Response/release time 8 / 6 ms Insulation voltage contact/contact 1 kV Vibration resistance NO/NC 20/5 g Pinning 5 mm Creation date 16.12.2023 20:25:44 Subject to technical changes 2 Data sheet 15334.2 PRS 2/48V DC Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:25:44 Subject to technical changes 3 Data sheet 15334.2 PRS 2/48V DC Approvals Standards and regulations CE compliant Creation date 16.12.2023 20:25:44 yes Subject to technical changes 4 Data sheet 15334.2 PRS 2/48V DC Media Creation date 16.12.2023 20:25:44 Subject to technical changes 5 Data sheet 15334.2 PRS 2/48V DC Accessories ##INVERSE##CONTA-ELECTRONICS Relay socket base PRS, for miniature power relay with 2 CO contacts, Screw connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15136.2 PRS 2 4044211046194 1 ST Relay socket base PRS, for miniature power relay with 2 CO contacts, Screw connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15320.2 PRS 2 G 4044211047115 1 ST Relay socket base PRS, for miniature power relay with 2 CO contacts, Tension-spring connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15789.2 PRS 2 Z 4044211135256 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 48 VDC Article number Article name GTIN (EAN) Packaging unit 15411.2 PRSU 2/48V DC 4044211080778 1 ST Pre-assembled relay module PRS..., Tension-spring connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contact, Input voltage: 48 VDC Article number Article name GTIN (EAN) Packaging unit 15792.2 PRSU 2Z/48V DC 4044211135362 1 ST Creation date 16.12.2023 20:25:44 Subject to technical changes 6 Data sheet 15334.2 PRS 2/48V DC ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 48 VDC Article number Article name GTIN (EAN) Packaging unit 15415.2 PRSU 2G/48V DC 4044211080822 1 ST Relay socket base PRS, for miniature power relay with 2 CO contacts, Push-in connection, Plug-in option for input/suppression modules and cross connections, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 16503.2 PPRS 2 4044211236298 20 ST Creation date 16.12.2023 20:25:44 Subject to technical changes 7
15334.2 价格&库存
很抱歉,暂时无法提供与“15334.2”相匹配的价格&库存,您可以联系我们找货
