15541.2
    CONTA-CLIP
    RELAY, ENCAPSULATED DESIGN
15541.2 数据手册
Data sheet 15541.2 PRS 2/110V DC Plug-in miniature power relay, Encapsulated design with power contact, 2 CO contact, Input voltage: 110 VDC Business data Article number 15541.2 Article name PRS 2/110V DC GTIN (EAN) 4044211117924 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 13.7 g Weight per piece (including packaging) 15.53 g Unit of weight G Customs number 85364900 Country of origin AT Product description Relay, encapsulated construction Creation date 16.12.2023 20:30:01 Subject to technical changes 1 Data sheet 15541.2 PRS 2/110V DC Technical data Dimensions Length 29 mm Width 12.7 mm Height 15.7 mm Ratings Overvoltage category III Contamination degree 3 (250 VAC) / 2 (400 VAC) Input data Working voltage >77,0 VDC - Drop-out voltage 11,0 VDC Coil voltage 110 VDC - Power consumption 0,42 W Coil resistance 28800 Ohm Output data Switching voltage / switching voltage max. 250 / 400 VAC Continuous current max. / Inrush current max. 8 / 15 A Contact configuration 2 CO contacts Switching capacity, max. 2000 VA Electrical lifespan (AC1) 1x10⁵ Mechanical lifespan 30x10⁶ Bounce time at close of the NO/NC contact 8/6 ms Materials Contact material AgNi 90/10 Working temperature, min. -40 °C Working temperature, max. 70 °C Further technical data Degree of protection RTII Insulation voltage coil/contact 5 kV Response/release time 8 / 6 ms Insulation voltage contact/contact 1 kV Vibration resistance NO/NC 20/5 g Pinning 5 mm Creation date 16.12.2023 20:30:01 Subject to technical changes 2 Data sheet 15541.2 PRS 2/110V DC Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:30:01 Subject to technical changes 3 Data sheet 15541.2 PRS 2/110V DC Approvals Standards and regulations CE compliant Creation date 16.12.2023 20:30:01 yes Subject to technical changes 4 Data sheet 15541.2 PRS 2/110V DC Media Creation date 16.12.2023 20:30:01 Subject to technical changes 5 Data sheet 15541.2 PRS 2/110V DC Accessories ##INVERSE##CONTA-ELECTRONICS Relay socket base PRS, for miniature power relay with 2 CO contacts, Screw connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15136.2 PRS 2 4044211046194 1 ST Relay socket base PRS, for miniature power relay with 2 CO contacts, Screw connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15320.2 PRS 2 G 4044211047115 1 ST Relay socket base PRS, for miniature power relay with 2 CO contacts, Tension-spring connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15789.2 PRS 2 Z 4044211135256 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 110 VDC Article number Article name GTIN (EAN) Packaging unit 15722.2 PRSU 2/110V DC 4044211138424 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 110 VDC Article number Article name GTIN (EAN) Packaging unit 15723.2 PRSU 2G/110V DC 4044211138431 1 ST Creation date 16.12.2023 20:30:01 Subject to technical changes 6 Data sheet 15541.2 PRS 2/110V DC ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Tension-spring connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contact, Input voltage: 110 VDC Article number Article name GTIN (EAN) Packaging unit 15794.2 PRSU 2Z/110V DC 4044211135386 1 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 2 CO contact, Input voltage: 220 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15921.2 PRC 2 220...240V AC/DC 4044211137366 10 ST Relay socket base PRS, for miniature power relay with 2 CO contacts, Push-in connection, Plug-in option for input/suppression modules and cross connections, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 16503.2 PPRS 2 4044211236298 20 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15926.2 PRCU 2 240V AC/DC 4044211137441 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15929.2 ZPRCU 2 240V AC/DC 4044211137472 10 ST Creation date 16.12.2023 20:30:01 Subject to technical changes 7 Data sheet 15541.2 PRS 2/110V DC ##INVERSE##CONTA-ELECTRONICS Relay socket base PRS, for miniature power relay with 2 CO contacts, Push-in connection, Plug-in option for input/suppression modules and cross connections, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 16503.2 PPRS 2 4044211236298 20 ST Creation date 16.12.2023 20:30:01 Subject to technical changes 8
15541.2 价格&库存
很抱歉,暂时无法提供与“15541.2”相匹配的价格&库存,您可以联系我们找货
