15917.2
    CONTA-CLIP
    CONVERTER UNIT
15917.2 数据手册
Data sheet 15917.2 CML-DCDC/15-0,5 DC/DC converter module, regulated, Screw connection, Mounting type: Mounting rail TS 35, Input: 1-phase, Output: 15 VDC/0.5 A Business data Article number 15917.2 Article name CML-DCDC/15-0,5 GTIN (EAN) 4044211142087 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 55.3 g Weight per piece (including packaging) 79.3 g Unit of weight G Customs number 85423990 Country of origin NL Product description Converter unit Creation date 14.12.2023 20:40:46 Subject to technical changes 1 Data sheet 15917.2 CML-DCDC/15-0,5 Technical data Dimensions Length 93.1 mm Width 6.2 mm Height TS 35/7.5 102.5 mm Ratings Overvoltage category III Contamination degree 2 Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 0.2 mm² Wire cross-section single-core (rigid), max. 2.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Stripping length 12 mm Torque 0.6 Nm Input data Input voltage DC min. 22 V Input voltage DC max. 65 V Input current with max. load 225 mA Zero-load current
15917.2 价格&库存
很抱歉,暂时无法提供与“15917.2”相匹配的价格&库存,您可以联系我们找货
