3701.2
    CONTA-CLIP
    END PLATE
3701.2 数据手册
Data sheet 3701.2 ZAP 2,5/3A BG End plate, Width: 2 mm, Colour: Beige Business data Article number 3701.2 Article name ZAP 2,5/3A BG GTIN (EAN) 4044211060053 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 2.6 g Weight per piece (including packaging) 2.7 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3701.2 Product description End plate Creation date 15.12.2023 16:51:45 Subject to technical changes 1 Data sheet 3701.2 ZAP 2,5/3A BG Technical data Dimensions Length 71.3 mm Width 2 mm Height 30.8 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 16:51:45 No Subject to technical changes 2 Data sheet 3701.2 ZAP 2,5/3A BG Media Creation date 15.12.2023 16:51:45 Subject to technical changes 3 Data sheet 3701.2 ZAP 2,5/3A BG Accessories ##INVERSE##CONTA-CONNECT Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Greenyellow Article number Article name GTIN (EAN) Packaging unit 1714.2 ZSL 2,5/3A Ex GNYE 4044211110956 100 ST Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3501.2 ZRK 2,5/3A BG 4044211151690 100 Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3511.2 ZSL 2,5/3A GNYE 4044211151737 100 ST Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1705.2 ZRK 2,5/3A Ex BG 4044211110925 100 ##INVERSE##CONTA-CONNECT Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3511.2 ZSL 2,5/3A GNYE 4044211151737 100 ST Creation date 15.12.2023 16:51:45 Subject to technical changes 4
3701.2 价格&库存
很抱歉,暂时无法提供与“3701.2”相匹配的价格&库存,您可以联系我们找货
