5908.3
    CONTA-CLIP
    RELAY MODULE
5908.3 数据手册
Data sheet 5908.3 RIM8S/1W/24V+ Multiple relay module with manual actuation, Screw connection, With 8 miniature relays, 1 CO contact each, Plugged in, With illuminated display, Positive switching, Input voltage: 24 VDC Business data Article number 5908.3 Article name RIM8S/1W/24V+ GTIN (EAN) 4044211070540 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 343.9 g Weight per piece (including packaging) 419.5 g Unit of weight G Customs number 85364900 Country of origin NL Product description Relay module Creation date 15.12.2023 11:49:22 Subject to technical changes 1 Data sheet 5908.3 RIM8S/1W/24V+ Technical data Dimensions Length 87 mm Width 150 mm Height 74 mm Ratings Overvoltage category III Contamination degree 2 Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 0.08 mm² Wire cross-section single-core (rigid), max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Stripping length 7 mm Torque 0.6 Nm Input data Input voltage 24 VDC Number of channels 8 Plus switching (source) 1 Power consumption 0,6 W reverse-polarity protection diode 1 Output data Switching voltage / switching voltage max. 250 / 250 VAC Continuous current max. / Inrush current max. 6 / 10 A Contact configuration 1 CO contact Switching capacity, max. 2000 VA Electrical lifespan (AC1) 1,5x10⁵ Mechanical lifespan 10x10⁶ Creation date 15.12.2023 11:49:22 Subject to technical changes 2 Data sheet 5908.3 RIM8S/1W/24V+ Technical data Materials Contact material AgNi 90/10 Working temperature, min. -20 °C Working temperature, max. 55 °C Further technical data Protection class IP20 Insulation voltage coil/contact 4 kV Status display red Free-wheel diode Response/release time 9 / 7 ms Pinning 3.5 mm Manual/Off/Automatic switching Operating voltage indicator LED Pluggable relay Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 11:49:22 Subject to technical changes 3 Data sheet 5908.3 RIM8S/1W/24V+ Approvals Standards and regulations CE compliant yes Standards / specifications DIN VDE 0110 / EN 50178 Creation date 15.12.2023 11:49:22 Subject to technical changes 4 Data sheet 5908.3 RIM8S/1W/24V+ Media Creation date 15.12.2023 11:49:22 Subject to technical changes 5 Data sheet 5908.3 RIM8S/1W/24V+ Accessories Creation date 15.12.2023 11:49:22 Subject to technical changes 6
5908.3 价格&库存
很抱歉,暂时无法提供与“5908.3”相匹配的价格&库存,您可以联系我们找货
