6485.2
    CONTA-CLIP
    RELAY, ENCAPSULATED DESIGN
6485.2 数据手册
Data sheet 6485.2 PRS 2/230V AC Plug-in miniature power relay, Encapsulated design with power contact, 2 CO contacts, Input voltage: 230 VAC Business data Article number 6485.2 Article name PRS 2/230V AC GTIN (EAN) 4044211074241 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 12.9 g Weight per piece (including packaging) 14.57 g Unit of weight G Customs number 85364900 Country of origin AT Product description Relay, encapsulated construction Creation date 14.12.2023 18:58:30 Subject to technical changes 1 Data sheet 6485.2 PRS 2/230V AC Creation date 14.12.2023 18:58:30 Subject to technical changes 2 Data sheet 6485.2 PRS 2/230V AC Technical data Dimensions Length 29 mm Width 12.7 mm Height 15.7 mm Ratings Overvoltage category III Contamination degree 3 (250 VAC) / 2 (400 VAC) Input data Working voltage >172,5 VDC - Drop-out voltage 34,5 VAC Coil voltage 230 VAC - Power consumption 0,74 W Coil resistance 32500 Ohm Output data Switching voltage / switching voltage max. 250 / 400 VAC Continuous current max. / Inrush current max. 8 / 15 A Contact configuration 2 CO contacts Switching capacity, max. 2000 VA Electrical lifespan (AC1) 1x10⁵ Mechanical lifespan 5x10⁶ Materials Contact material AgNi 90/10 Working temperature, min. -40 °C Working temperature, max. 70 °C Further technical data Degree of protection RTII Insulation voltage coil/contact 5 kV Insulation voltage contact/contact 1 kV Vibration resistance NO/NC 20/5 g Pinning 5 mm Creation date 14.12.2023 18:58:30 Subject to technical changes 3 Data sheet 6485.2 PRS 2/230V AC Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 18:58:30 Subject to technical changes 4 Data sheet 6485.2 PRS 2/230V AC Approvals Standards and regulations CE compliant Creation date 14.12.2023 18:58:30 yes Subject to technical changes 5 Data sheet 6485.2 PRS 2/230V AC Media Creation date 14.12.2023 18:58:30 Subject to technical changes 6 Data sheet 6485.2 PRS 2/230V AC Accessories ##INVERSE##CONTA-ELECTRONICS Relay socket base PRS, for miniature power relay with 2 CO contacts, Screw connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15136.2 PRS 2 4044211046194 1 ST Relay socket base PRS, for miniature power relay with 2 CO contacts, Screw connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15320.2 PRS 2 G 4044211047115 1 ST Relay socket base PRS, for miniature power relay with 2 CO contacts, Tension-spring connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15789.2 PRS 2 Z 4044211135256 1 ST Pre-assembled relay module PRS..., Tension-spring connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contact, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 15797.2 PRSU 2Z/230V AC 4044211135416 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 15236.2 PRSU 2G/230V AC 4044211046743 10 ST Creation date 14.12.2023 18:58:30 Subject to technical changes 7 Data sheet 6485.2 PRS 2/230V AC ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 15812.2 PRSU 2G/230V AC Var. 4044211146511 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 15172.2 PRSU 2/230V AC 4044211046491 10 ST Relay socket base PRS, for miniature power relay with 2 CO contacts, Push-in connection, Plug-in option for input/suppression modules and cross connections, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 16503.2 PPRS 2 4044211236298 20 ST Creation date 14.12.2023 18:58:30 Subject to technical changes 8
6485.2 价格&库存
很抱歉,暂时无法提供与“6485.2”相匹配的价格&库存,您可以联系我们找货
