LCD-16777
LCD-16777
    SPARKFUNELECTRONICS
    LCD 1.8" 显示 OpenMV 平台评估扩展板
LCD-16777 数据手册
https://openmv.io AUGUST 2018 OpenMV LCD Shield. 1 Features 2 Description • • • The LCD Shield enables OpenMV cameras to display images captured from the image sensor. It features a 1.8" 128x160 16-bpp (RGB565) TFT LCD display with a controllable backlight. ST7735R LCD controller. 1.8", 128x160 pixels, 16-bit color. Backlight control pin. Device Information PART NUMBER OPENMV-LCD-SHIELD 3 Applications • Video display. . 1 BODY SIZE (NOM) 1.49 in × 1.87 in https://openmv.io AUGUST 2018 Table of Contents 1 FEATURES .............................................................................................................................................. 1 2 DESCRIPTION ......................................................................................................................................... 1 3 APPLICATIONS ....................................................................................................................................... 1 4 PIN CONFIGURATIONS AND FUNCTIONS ................................................................................................ 3 5 ELECTRICAL CHARACTERISTICS ............................................................................................................... 4 5.1 6 RECOMMENDED OPERATING CONDITIONS...................................................................................................... 4 MECHANICAL INFORMATION ................................................................................................................. 5 2 https://openmv.io AUGUST 2018 4 Pin Configurations and Functions Pin Functions Pin Header Description No Name 1 P0 SPI data in. 2 P1 NC 3 P2 SPI clock. 4 P3 SPI chip select (10K pull-up) 5 P4 NC 6 P5 NC 7 P6 LED control. 8 3.3 3.3v input 1 RST NC 2 BOOT NC 3 SYN NC 4 P9 NC 5 P8 RS 6 P7 RESET 7 VIN NC 8 GND GND J1 Pin Configuration J1 J2 Pin Configuration J2 3 https://openmv.io AUGUST 2018 5 Electrical Characteristics 5.1 Recommended Operating Conditions SYMBOL VIN T RATINGS MIN MAX External input supply voltage range. 2.8 3.3 V Operating Temperature -30 80 °C 4 UNIT https://openmv.io AUGUST 2018 6 Mechanical Information The following information is the most current data available for the designated device. This data is subject to change without notice and without revision of this document. 5
LCD-16777 价格&库存
很抱歉,暂时无法提供与“LCD-16777”相匹配的价格&库存,您可以联系我们找货
