SM150808-10
SM150808-10
    DBUNLIMITED
    8 Ohms 通用 扬声器 1 W 850 Hz ~ 10 kHz 顶部 矩形
SM150808-10 数据手册
4 3 2 1 Part Number: DRAWN SM150808-10 5/30/2018 CJ CHECKED 5/30/2018 C.H. Description: D APPROVED Dynamic Speaker 5/30/2018 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Side View (1) 11 ± 0.1 C Bottom View Date Code Marking "17 K" 17=2017, K=Nov. 0.75 ± 0.2 2.5 ± 0.1 3.2 6.95 ± 0.2 C 0.7x0.8 C 15 ± 0.1 XX X 12.56 ± 0.1 0.45 8.56 ± 0.1 Recommended Land Pattern 6.15 Top View D B 2.5 1.6 Max. Vibration 0.3mm B Side View (2) 4.15 ± 0.25 A Items Specifications Conditions Sound Pressure Level 93 dB (@ 10cm) Resonant Frequency 850 Hz Frequency Range 850 ~ 10,000 Hz Nominal Power 1 W Max. Power 1.5 W Impedance 8 Ω Cone Material Polymer NOTES Mount Type Flush Mount 1) All dimensions are in mm unless otherwise noted REVISION HISTORY REV 1 DESCRIPTION DATE APPROVED Released from Engineering 5/30/2018 C.E. Updated date code location on bottom view 6/19/2019 C.E. IP Rating IPX7 Storage Temperature -40 ~ +85 °C 3) All parts meet RoHS Operating Temperature -30 ~ +70 4) Subject to change or redrawn without notice Weight 1.4 °C g 4 2) All tolerances are ± 0.15 mm unless otherwise noted 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SM150808-10 价格&库存
很抱歉,暂时无法提供与“SM150808-10”相匹配的价格&库存,您可以联系我们找货
