ITEM
CONTENTS
UNIT
LCD Type
Size
Viewing Direction
Gray Scale Inversion Direction
LCM (W × H × D )
Active Area (W × H)
Dot Pitch (W × H)
Number Of Dots
Driver IC
Backlight Type
Surface Luminance
Interface Type
Color Depth
Pixel Arrangement
Surface Treatment
Input Voltage
With/Without TSP
Weight
TFT/Transmissive/Normally white
5.0
12:00 (without image inversion)
6:00
120.70 ×75.80 × 5.00
108.00 × 64.80
0.045×0.135
800 x (RGB) × 480
HX8664B+HX8264D
12 LEDs
510
24bit RGB
16.7M
RGB Vertical Stripe
Clear
3.3
Projected Capacitive Touch Panel
88.66
Inch
O’ Clock
O’ Clock
mm3
mm2
mm2
cd/m2
Note 1: RoHS compliant
Note 2: LCM weight tolerance: ± 5%.
V
g
Rev.1.0
RVT50AQTNWC00
REVISION RECORD
REVNO.
1.0
REVDATE
CONTENTS
2015-08-06
Initial Release
REMARKS
CONTENTS
REVISION RECORD ................................................................................................................................... 2
CONTENTS ............................................................................................................................................... 2
1
MODULE CLASSIFICATION INFORMATION ...................................................................................... 3
2
MODULE DRAWING ........................................................................................................................ 4
3
ABSOLUTE MAXIMUM RATINGS...................................................................................................... 5
4
ELECTRICAL CHARACTERISTICS ........................................................................................................ 5
5
BACKLIGHT CHARACTERISTICS ........................................................................................................ 5
6
ELECTRO-OPTICAL CHARACTERISTICS ............................................................................................. 5
7
INTERFACE DESCRIPTION ................................................................................................................ 7
8
LCD TIMING CHARACTERISTICS ....................................................................................................... 8
8.1
AC electrical characteristics..................................................................................................... 8
8.2
Clock and data input time diagram ......................................................................................... 9
8.3
Parallel RGB timing table ......................................................................................................... 9
9
CAPACITIVE TOUCH SCREEN PANEL SPECIFICATIONS ................................................................... 10
9.1
Mechanical characteristics .................................................................................................... 10
9.2
Electrical characteristics ........................................................................................................ 10
9.3
Interface description ............................................................................................................. 10
9.4
CTP Interface timing characteristics ...................................................................................... 11
9.5
CTP timing configuration ....................................................................................................... 11
9.6
Communication of the I2C interface with Host ..................................................................... 12
9.7
Touch data read protocol ...................................................................................................... 12
9.8
Data description .................................................................................................................... 13
9.9
Interrupt Trigger Mode ......................................................................................................... 14
10
RELIABILITY TEST........................................................................................................................ 15
11
LEGAL INFORMATION ................................................................................................................ 16
Rev.1.0
RVT50AQTNWC00
1 MODULE CLASSIFICATION INFORMATION
1.
2.
3.
4.
1.
BRAND
2.
PRODUCT TYPE
5.
6.
7.
8.
9.
RV – Riverdi
T – TFT Standard
F – TFT Custom
35 – 3.5”
3.
DISPLAY SIZE
43 – 4.3”
50 – 5.0”
70 – 7.0”
4.
MODEL SERIAL NO.
5.
RESOLUTION
A (A-Z)
Q– 800x480 px
T – TFT LCD, RGB
6.
INTERFACE
L – TFT LCD, LVDS
C – TFT + Controller
7.
FRAME
8.
BACKLIGHT TYPE
N – No Frame
F – Mounting Frame
W – LED White
N – No Touch Panel
9.
TOUCH PANEL
R – Resistive Touch Panel
C – Capacitive Touch Panel
10.
VERSION
00 (00-99)
10.
Rev.1.0
RVT50AQTNWC00
2 MODULE DRAWING
Rev.1.0
RVT50AQTNWC00
3 ABSOLUTE MAXIMUM RATINGS
PARAMETER
SYMBOL
MIN
MAX
UNIT
Supply Voltage For Logic
Input Voltage For Logic
LED forward current (each LED)
Operating Temperature
Storage Temperature
Humidity
VDD
VIN
IF
TOP
TST
RH
-0.3
VSS-0.5
-20
-30
4.0
VDD+0.3
60
70
80
90% (Max 60°C)
V
V
mA
°C
°C
RH
4 ELECTRICAL CHARACTERISTICS
PARAMETER
SYMBOL
Supply Voltage For Module
Input Leakage Current
Input Voltage ' H ' level
Input Voltage ' L ' level
VDD
ILKG
VIH
VIL
MIN
TYP MAX UNIT NOTES
3.0
0.8VDD
-0.3
3.3
3.6
VDD
0.2VDD
V
µA
V
V
5 BACKLIGHT CHARACTERISTICS
ITEM
SYMBOL
Voltage for LED backlight
Current for LED backlight
Power consumption
LED Life Time
MIN
Vl
Il
WBL
TYP
17.4
30
522
30000
MAX
18.3
40
732
50000
19.6
50
980
UNIT
V
mA
mW
Hrs
Note:
The LED Supply Voltage is defined by the numbers of LED at Ta= 25±2⁰C and 60%RH±5%.
The LED life time is defined as the module brightness decrease to 50% original brightness at Ta=25°C.
The LED time life will be reduced if LED is driven by high current, high humidity and temperature
ambient conditions.
6 ELECTRO-OPTICAL CHARACTERISTICS
ITEM
SYMBOL
Response Time
Contrast Ratio
Tr+Tf
Cr
Luminance Uniformity
Surface Luminance
δ WHITE
Lv
θ
Viewing Angle Range
Red
Green
CIE (x, y)
Chromaticity
Blue
White
x
y
x
y
x
y
x
y
CONDITION
θ=0°
∅=0°
Ta=25
∅ = 90°
∅ = 270°
∅ = 0°
∅ = 180°
θ=0°
∅=0°
Ta=25
MIN
TYP MAX UNIT REMARK NOTE
ms
Figure 1
Figure 2
4
1
75
80
467
40
60
60
60
0.540
0.300
0.298
0.520
0.095
0.060
0.270
0.310
510
50
70
70
70
0.590
0.350
0.348
0.570
0.145
0.110
0.320
0.360
Figure 2
3
0.640
0.400
0.398
0.620
0.195
0.160
0.370
0.410
cd/m2
deg
deg
deg
deg
Figure 2
Figure 3
Figure 3
Figure 3
Figure 3
2
6
Figure 2
5
Rev.1.0
RVT50AQTNWC00
Note 1. Contrast Ratio(CR) is defined mathematically as below, for more information see Figure 1.
Contrast Ratio =
Average Surface Luminance with all white pixels (P1, P2, P3, P4, P5)
Average Surface Luminance with all black pixels (P1, P2, P3, P4, P5)
Note 2. Surface luminance is the LCD surface from the surface with all pixels displaying white. For more
information see Figure 2.
Lv = Average Surface Luminance with all white pixels (P1, P2, P3, P4, P5)
Note 3. The uniformity in surface luminance δ WHITE is determined by measuring luminance at each
test position 1 through 5, and then dividing the maximum luminance of 5 points luminance by
minimum luminance of 5 points luminance. For more information see Figure 2.
δ WHITE =
Minimum Surface Luminance with all white pixels (P1, P2, P3, P4, P5)
Maximum Surface Luminance with all white pixels (P1, P2, P3, P4, P5)
Note 4. Response time is the time required for the display to transition from white to black (Rise Time,
Tr) and from black to white (Decay Time, Tf). For additional information see FIG 1. The test equipment
is Autronic-Melchers’s ConoScope series.
Note 5. CIE (x, y) chromaticity, the x, y value is determined by measuring luminance at each test
position 1 through 5, and then make average value.
Note 6. Viewing angle is the angle at which the contrast ratio is greater than 2. For TFT module the
contrast ratio is greater than 10. The angles are determined for the horizontal or x axis and the
vertical or y axis with respect to the z axis which is normal to the LCD surface. For more information
see Figure 3.
Note 7. For viewing angle and response time testing, the testing data is based on Autronic-Melchers’s
ConoScope series. Instruments for Contrast Ratio, Surface Luminance, Luminance Uniformity, CIE the
test data is based on TOPCON’s BM-5 photo detector.
Note 8. For TFT module, Gray scale reverse occurs in the direction of panel viewing angle.
Figure 1. The definition of response time
Rev.1.0
RVT50AQTNWC00
Figure 2. Measuring method for Contrast ratio, surface luminance, Luminance uniformity, CIE (x, y) chromaticity
Figure 3.The definition of viewing angle
7
PIN NO.
1
2
3
4
5-12
13-20
21-28
29
30
31
32
33
34
35
36
37
38
39
40
SYMBOL
DESCRIPTION
VLEDVLED+
GND
VDD
R0-R7
G0-G7
B0-B7
GND
CLKIN
STBYB
HSYNC
VSYNC
DEN
NC
GND
NC
NC
NC
NC
Back Light Power Ground
Back Light Power Supply
Power Ground
Power Supply Voltage
Red Data
Green Data
Blue Data
Power Ground
Dot Clock signal.
Standby mode control pin
Horizontal Synchronized Signal input
Vertical Synchronized Signal input
Data Enable
NC
Power Ground
No Connect
No Connect
No Connect
No Connect
NOTE
Note: For digital RGB input data format, both SYNC mode and DE+SYNC mode are supported. If ENB
signal is fixed low. SYNC mode is used. Otherwise, DEN+SYNC is used.
Rev.1.0
RVT50AQTNWC00
Figure 4 Block diagram
8 LCD TIMING CHARACTERISTICS
8.1 AC electrical characteristics
PARAMETER
HS setup time
HS hold time
VS setup time
VS hold time
Data setup time
Data hold time
DE setup time
DE hold time
DVDD Power On Slew rate
RESET pulse width
DCLK cycle time
DCLK pulse duty
SYMBOL
Thst
Thhd
Tvst
Tvhd
Tdsu
Tdhd
Tesu
Tehd
TPOR
TRst
Tcoh
Tcwh
MIN
8
8
8
8
8
8
8
8
10
TYP
50
MAX UNIT
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
NOTES
From 0 to 90% DVDD
Rev.1.0
RVT50AQTNWC00
8.2 Clock and data input time diagram
Figure 5. Horizontal input timing diagram
Figure 6. Vertical input timing diagram
8.3 Parallel RGB timing table
PARAMETER
Horizontal Display Area
DCLK Frequency
One Horizontal Line
HS pulse width
HS Blanking
HS Front Porch
Vertical Display Area
VS period time
VS pulse width
VS Blanking
VS Front Porch
SYMBOL
MIN
TYP
MAX
UNIT
Thd
Fclk
Th
Thpw
Thb
Thfp
Tvd
Tv
Tvpw
Tvb
Tvfp
889
1
1
513
3
1
800
30
928
48
88
40
480
525
3
32
13
50
1143
255
255
767
255
255
DCLK
MHz
DCLK
DCLK
DCLK
DCLK
TH
TH
TH
TH
TH
Rev.1.0
RVT50AQTNWC00
9 CAPACITIVE TOUCH SCREEN PANEL SPECIFICATIONS
9.1 Mechanical characteristics
DESCRIPTION
INL SPECIFICATION
Touch Panel Size
Outline Dimension (OD)
Product Thickness
Glass Thickness
Ink View Area
Sensor Active Area
Input Method
Activation Force
Surface Hardness
5.0 inch
120.3mm x 75.4mm
1.9mm
0.7mm
109.00mm x 65.80mm
110.0mm x 66.8mm
5 Finger
Touch
≥7H
REMARK
Cover Lens Outline
9.2 Electrical characteristics
DESCRIPTION
Operating Voltage
Power Consumption (IDD)
SPECIFICATION
Active Mode
Sleep Mode
Interface
Controller
I2C address
Resolution
DC 2.8~3.3V
TBD mA
TBD μA
I2C
FT5306
0x38 (7 bit address)
800*480
9.3 Interface description
PIN NO.
1
2
3
4
5
6
7
8
9
10
SYMBOL
VSS
VDD
SCL
NC
SDA
NC
/RST
/WAKE
/INT
VSS
DESCRIPTION
Power Ground
Power For CTP
I2C SCL
No Connect
I2C SDA
No Connect
Reset pin
No Connect
Interrupt signal from CTP
Power Ground
REMARK
Rev.1.0
RVT50AQTNWC00
9.4 CTP Interface timing characteristics
PARAMETER
MIN
MAX
UNIT
4.0
250
4.7
4.0
400
kHz
μs
μs
ns
μs
μs
SCL Frequency
Bus Free Time Between a STOP and START Condition
Hold Time (repeated) START Condition
Data Setup Time
Setup Time for Repeated START Condition
Setup Time for STOP Condition
9.5 CTP timing configuration
Figure 7I2C Serial Data Transfer Format
Figure 8. I2C master write, slave read
Figure 9. I2C master read, slave write
MNEMONICS
S
A[6:0]
W
R
C
P
DESCRIPTIO
I2C Start or I2C Restart
Slave address
A[6:4]: 3’b011
A[3:0]: data bits are identical to those of I2CCON[7:4] register.
1’b0: Write
1’b0: Read
ACK
STOP: the indication of the end of a packet (if this bit is missing, S will
indicate the end of the current packet and the beginning of the next packet)
Rev.1.0
RVT50AQTNWC00
9.6 Communication of the I2C interface with Host
Figure 10Comunication of the I2C interface with Host
9.7 Touch data read protocol
ADDRESS
00h
01h
02h
03h
04h
05h
06h
07h
08h
09h
0Ah
0Bh
0Ch
0Dh
0Eh
0Fh
10h
11h
12h
13h
14h
15h
16h
17h
18h
19h
1Ah
1Bh
1Ch
1Dh
1Eh
NAME
BIT
7
BIT
6
BIT
5
BIT
4
BIT
3
BIT
2
BIT
1
DEVIDE_MODE
GEST_ID
TD_STATUS
TOUCH1_XH
TOUCH1_XL
TOUCH1_YH
TOUCH1_YL
Device Mode[2:0]
Gesture ID[7:0]
TOUCH2_XH
TOUCH2_XL
TOUCH2_YH
TOUCH2_YL
2nd Event Flag
2nd Touch X Position[7:0]
2nd Touch ID[3:0]
2nd Touch Y Position[7:0]
2nd Touch X Position[11:8]
TOUCH3_XH
TOUCH3_XL
TOUCH3_YH
TOUCH3_YL
3rd Event Flag
3rd Touch X Position[7:0]
3rd Touch ID[3:0]
3rd Touch Y Position[7:0]
3rd Touch X Position[11:8]
TOUCH4_XH
TOUCH4_XL
TOUCH4_YH
TOUCH4_YL
4th Event Flag
4th Touch X Position[7:0]
4th Touch ID[3:0]
4th Touch Y Position[7:0]
4th Touch X Position[11:8]
TOUCH5_XH
TOUCH5_XL
TOUCH5_YH
TOUCH5_YL
5th Event Flag
5th Touch X Position[7:0]
5th Touch ID[3:0]
5th Touch Y Position[7:0]
5th Touch X Position[11:8]
1st Event Flag
1st Touch X Position[7:0]
1st Touch ID[3:0]
1st Touch Y Position[7:0]
BIT HOST
0 ACCESS
Number of touch points[3:0]
1st Touch X Position[11:8]
RW
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
Rev.1.0
RVT50AQTNWC00
9.8 Data description
DEVICE_MODE
This register is the device mode register, configure it to determine the current
mode of the chip.
ADRESS
00h
BIT ADRESS
6:4
REGISTER NAME
Device Mode [2:0]
DESCRIPTION
000b Work Mode
100b Factory Mode – Read Raw Data
GEST_ID
This register describes the gesture of a valid touch.
ADRESS
01h
BIT ADRESS
7:0
REGISTER NAME
Gesture ID [7:0]
DESCRIPTION
Gesture ID
0x10 Move Up
0x14 Move Down
0x18 Move Right
0x48 Zoom In
0x49 Zoom Out
0x00 No Gesture
TD_STATUS
This register is the Touch Data status register.
ADRESS
02h
BIT ADRESS
3:0
REGISTER NAME
Number of Touch Points
[2:0]
DESCRIPTION
How Many Points Detected
1-5 is Valid
7:4
TOUCHn_XH(n:1-10)
This register describes MSB of the X coordinate of the nth touch point and the
corresponding event flag.
ADRESS
03h
BIT ADRESS
7:6
REGISTER NAME
Event Flag
DESCRIPTION
00b: Put Down
01b: Put Up
39h
10b: Contact
11b: Reserved
5:4
3:0
Reserved
Touch X Position [11:8]
MSB of Touch X Position in Pixels
Rev.1.0
RVT50AQTNWC00
TOUCHn_XL(n:1-10)
This register describes LSB of the X coordinate of the nth touch point.
ADRESS
04h
BIT ADRESS
7:0
REGISTER NAME
Touch X Position [7:0]
DESCRIPTION
LSB of the Touch X Position in Pixels
3Ah
TOUCHn_YH(n:1-10)
This register describes MSB of the Y coordinate of the nth touch point and
corresponding touch ID.
ADRESS
BIT ADRESS
REGISTER NAME
DESCRIPTION
05h
7:4
Touch ID[3:0]
Touch ID of Touch Point
3:0
MSB of Touch Y Position in Pixels
3Bh
TOUCHn_YL(n:1-10)
This register describes LSB of the Y coordinate of the nth touch point.
ADRESS
05h
BIT ADRESS
7:0
REGISTER NAME
DESCRIPTION
LSB of the Touch Y Position in Pixels
3Bh
9.9 Interrupt Trigger Mode
Figure 11. Interrupt trigger mode timing
Rev.1.0
RVT50AQTNWC00
10 RELIABILITY TEST
NO.
TEST ITEM
1
High Temperature Storage
80±2°C/240hours
2
Low Temperature Storage
-30±2°C/240hours
3
High Temperature
Operating
70±2°C/240hours
4
Low Temperature Operating
-20±2°C/240hours
Temperature Cycle
-30±2°C~25~80±2°C × 20 cycles
(30min.) (5min.) (30min.)
Damp Proof Test
60°C ±5°C × 90%RH/240hours
7
Vibration Test
Frequency 10Hz~55Hz
Amplitude of vibration : 1.5mm
Sweep: 10Hz~55Hz~10Hz
X, Y, Z 2 hours for each direction.
8
Package Drop Test
Height:60 cm
1 corner, 3 edges, 6 surfaces
9
ESD Test
Air: ±4KV 150pF/330Ω 5 times
Contact: ±2KV 150pF/330Ω 5 time
5
6
TEST CONDITION
Rev.1.0
RVT50AQTNWC00
11 LEGAL INFORMATION
Riverdi makes no warranty, either expressed or implied with respect to any product, and specifically
disclaims all other warranties, including, without limitation, warranties for merchantability, noninfringement and fitness for any particular purpose. Information about device are the property of
Riverdi and may be the subject of patents pending or granted. It is not allowed to copy or disclosed
this document without prior written permission.
Riverdi endeavors to ensure that the all contained information in this document are correct but does
not accept liability for any error or omission. Riverdi products are in developing process and published
information may be not up to date. Riverdi reserves the right to update and makes changes to
Specifications or written material without prior notice at any time. It is important to check the current
position with Riverdi.
Images and graphics used in this document are only for illustrative the purpose. All images and graphics
are possible to be displayed on the range products of Riverdi, however the quality may vary. Riverdi is
no liable to the buyer or to any third part for any indirect, incidental, special, consequential, punitive
or exemplary damages (including without limitation lost profits, lost savings, or loss of business
opportunity) relating to any product, service provided or to be provided by Riverdi, or the use or
inability to use the same, even if Riverdi has been advised of the possibility of such damages.
Riverdi products are not fault tolerant nor designed, manufactured or intended for use or resale as on
line control equipment in hazardous environments requiring fail – safe performance, such as in the
operation of nuclear facilities, aircraft navigation or communication systems, air traffic control, direct
life support machines or weapons systems in which the failure of the product could lead directly to
death, personal injury or severe physical or environmental damage (‘High Risk Activities’). Riverdi and
its suppliers specifically disclaim any expressed or implied warranty of fitness for High Risk Activities.
Using Riverdi products and devices in 'High Risk Activities' and in any other application is entirely at
the buyer’s risk, and the buyer agrees to defend, indemnify and hold harmless Riverdi from any and all
damages, claims or expenses resulting from such use. No licenses are conveyed, implicitly or otherwise,
under any Riverdi intellectual property rights.
