FOOD-GRADE HEAT SHRINK - 3/8"
DIAMETER 12" LONG
PRODUCT ID: 1020
We decided to stock this food-safe heat shrink specifically for people who were
building beer-brewing or sous-vide projects using our waterproof DS18B20+
digital temperature sensors. This heat shrink is FDA Compliant for contact with
food. The end of the sensor is stainless steel, but the jacketing is PVC, not good
for dunking into your food or drink! But this heat shrink makes it easy - simply
slip it on, allowing about 1 cm of the stainless steel sensor cap to be exposed,
then heat it up to seal it on. The heat shrink will make a seal over the cap, so
that no PVC touches your food project.
This product is just 12" long piece of heat shrink, it does not include
the waterproof DS18B20+ digital temperature sensors so be sure to pick up one
of those too.
TECHNICAL DETAILS
Clear, food-grade heat shrink
Acrylated olefin tubing
Shrink Ratio: 2 to 1
3/8" diameter before shrinking, 3/16" after
12" long piece, can be cut down as much as you'd like
Shrink Temperature: 250°F (120 °C)
Usage Temperature Range: -67° to +250° F / -55°C to +120 °C
https://www.adafruit.com/product/1020 7‐13‐18
很抱歉,暂时无法提供与“1020”相匹配的价格&库存,您可以联系我们找货
