1119
    ADAFRUIT
    开关套件 触动式
1119 数据手册
Tactile Switch Buttons (12mm square, 6mm tall) x 10 pack PRODUCT ID: 1119   Description Medium-sized clicky momentary switches are standard input "buttons" on electronic projects. These work best in a PCB but can be used on a solderless breadboard as shown in this tutorial. http://www.ladyada.net/learn/arduino/lesson5.html The pins are normally open (disconnected) and when the button is pressed they are momentarily closed. They come in a pack of 10, they're pretty handy so you'll want to keep them around. You can find an EAGLE cad package for these in switch-omron:B3F-40XX Technical Details Example 12mm x 12mm x 6mm tall tactile switch datasheet https://cdn-shop.adafruit.com/datasheets/B3F-1000-Omron.pdf                                Engineered in NYC Adafruit ® https://www.adafruit.com/product/1119 6‐28‐17
很抱歉,暂时无法提供与“1119”相匹配的价格&库存,您可以联系我们找货
    • 5+21.87135
